10K Service Interval: Do You Ever Check Your Oil Level?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by seilerts, Mar 7, 2012.
  1. Never
    11 vote(s)
    22.9%
  2. A Few Times
    18 vote(s)
    37.5%
  3. Every 1000 Miles
    8 vote(s)
    16.7%
  4. Every Time I Get Gas
    11 vote(s)
    22.9%
  5. Every Time The Oil Light Comes On
    0 vote(s)
    0.0%
  1. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    Oil consumption is a problem that affects a small fraction of Gen IIs, generally ones with over 100,000 miles. It is an insidious problem, because it happens suddenly, and the first indication for most drivers is a brief flash of the Red Triangle plus the Oil Light. Oil pressure is measured by switch, rather than by gauge, and the threshold is 4 psi. By then, the damage is done: piston rings suffer wear and the consumption rate will increase. In chronic cases, it may damage the catalytic converter and/or prompt engine replacement.
    I believe the 10,000 mile change interval for 2010+ Prii creates a sense of complacency. I encourage everyone to check their oil level at least a few times between service. I'd like to know if anyone has had to add oil in between services as well.
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Old habits die hard. I check fluid levels and tire pressures about once every week or two. When I'm on a trip I usually check every morning before I start out.
  3. frodoz737
    frodoz737 Top Wrench
    4,811
    2,562
    33
    Fluids and tire pressures every fill-up.
  4. Mendel Leisk
    42,376
    I haven't checked ours in quite a while (change interval still 5000 miles up here), thanks for the reminder. As far as I can see, it's been consuming no oil between changes, so far (coming up to 20000 km's). That's a first for me: any other car we've had, Honda's up to now, has always consumed a little.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Like Tumbleweed, I check fluid levels and tire pressure just about every weekend.
    I have about 42k miles to date and have never had to add oil.
  6. Former Member 68813
    3,524
    983
    US
    I added 0.5qt in the middle of first 10,000 (break-in?). So far so good in the middle of second 10,000.
  7. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    No wonder why this group is paranoid about oil. Checking at every fill up is a bit OCD.
  8. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    ^I don't check that frequently, but any time I have a condition that creates a knocking engine situation, I get skurred. :D
  9. frodoz737
    4,811
    2,562
    33
    Some people use their tools to maintain the machine.
    Some people just act like a tool.
  10. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    You're right. You're going to look like a tool by paranoidly checking the oil at every fill up :D
  11. frodoz737
    4,811
    2,562
    33
    This is neither the place or format for measuring Sir. You have a nice day. :)
  12. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    I don't know what the recommended oil change interval is on the Gen III but for the Gen II the reminder for "maintenance" shows up after 4500 miles. That's when I change the oil.
    IMHO, driving 10,000 miles before changing conventional motor oil is taking an unnecessary risk. It's penny wise and pound foolish.
    Engine oil has many important jobs to do in an ICE. More jobs than most people realize. Motor oil aids in transferring most of the heat of combustion through the piston compression rings to the cylinder wall to the coolant jacket around the cylinders, cools the underside of the piston crown, provides the critical oil film between the piston skirts and cylinder wall, lubricates the piston and connecting rod pin bores, lubricates the camshaft and crankshaft, provides the oil film for the rod bearings and main bearings, lubricates the valve stems, carrries away metallic wear debris from the engine components to the filter, etc.
    If your Prius doesn't consume much or any motor oil over 5000 miles, that's fantastic! But it doesn't mean the oil that has been in the engine over those 10,000 miles will perform as well as the day it was poured in. Nor will that $4 oil filter. What's a filter for? Hey, the name says it all, doesn't it? Don't you think that the filter might reach a point when it no longer can filter out all the bad stuff its supposed to remove from the engine?
    As the old Fram oil filter commercial said.......
    You can pay me now, or pay ME (Joe) later.
    Peace.
  13. ETC(SS)
    7,576
    I check mine about every other fill up.
    I used to be anal enough to do it every time I get gas, but none of my vehicles use measurable amounts of oil, and I'm getting lazier in my old age.
    As far as the 10K interval...."my" G3 is a company car, so I don't have any rudder input on this.
    Well...that's not completely true, since I did stop them from using 20W50 (same oil from the same drum that they use in all the other vehicles, which are mostly trucks) but it took several nasty emails to get that done. I "believe" that they now use 10w30 every 5K.
    Reason #42 for "Why you should never buy a used fleet vehicle."
    If "my" G3 were MY G3, I'd probably go with a 5K interval, which is what I use for all of my four wheeled vehicles. The bikes get new oil every 3K or in April, whichever comes first.
    I'm just not comfortable going for 10K with the same oil in the crankcase, and oil changes are good for doing a detailed visual check under the hood and underneath the vehicle. As long as I’m dragging the jack and ramps out, I’m going to swap out the oil and rotate the tires.
    YMMV ;)
    frodoz737 likes this.
  14. vinnie97
    1,430
    277
    Somewhere out there
    UOA after UOA shows that the 10,000-mile interval is sufficient enough to protect the engine.
  15. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Yes, so why are half of you checking at every fill up? Are you worried that it'll somehow disappear into thin air? Isn't that what check oil light is for?
  16. jadziasman
    1,355
    488
    District 6
    What check oil light are you taking about - the friendly maintenance reminder or the pretty little red oil can that lights up sometimes on your dash?
    If you mean the latter, then it's an oil pressure warning light which if it lights up pretty much tells you to put some oil in the engine right away or the engine will become a nice paperweight real soon.
    Actually it's an idiot light, because if you see it and haven't hit a groundhog or something else on the road, you are an idiot for not checking the oil level once in a while.
    Perhaps the time has come for the really stupid and lazy to get electric cars. Then all they need to be concerned about is: did I charge it and is there enough air in the tires. Sheesh.
  17. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Once in a while is fine. I'm talking about at every fill up, which seems a bit excessive and pointless.
  18. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    I have OCD and i wouldn't take the time to check the oil at every fill up. Every other weekend or so is good for me.
  19. seilerts
    3,326
    1,520
    38
    Santa Fe, NM
    The threshold for the low oil light is 4 psi. By that time, the pickup is probably sucking air, and in short order, the rings will be sucked out the exhaust, along with the main bearing surfaces. It is not just that the oil pressure falls to 4 psi, it is basically 0. This happens when oil doesn't even show up on the dip stick, about 2 quarts low.
  20. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I think I am going to check my oil now...
