11,000 miles overdue for oil change
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bspriusbs, Mar 21, 2012.
  1. bspriusbs
    bspriusbs New Member
    socal
    so i got lazy/swamped and never got around to getting an oil change in my 2007 prius and once i hit 11k miles overdue my engine blew up. i had not a single drop of oil in the engine and my pistons blew 3 holes in the block...ive had other cars in the past and 11,000 miles overdue seems quite short for such a catastrophic event to happen and such a short time for the engine to eat all 4qts of oil.. anyone ever heard of such a thing happening?
  2. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    I have not heard of such a thing happening, but nor have I heard of someone going 11,000 miles past the recommended change interval.
    Just have to ask, but prior to this were you good about changing the oil at regular intervals?
  3. billinmd
    billinmd Member
    184
    28
    Bel Air, MD
    2020 Prius Prime
    I've never heard of such a thing either, but 11,000 miles overdue seems like an awful long time to wait.
  4. bspriusbs
    socal
    yes i was changing it between 3 and 5k miles. i know i pushed it past the limits but it just seems odd for that much oil to be eaten and my engine to be bone dry..
  5. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    How does it seem odd when you obviously don't ever check it?
    Even if you don't change the oil (for whatever reason) you MUST check the levels and add oil if required.
    I think you've learnt an important and expensive lesson. Oil and oil changes are much cheaper than a new engine.
  6. bspriusbs
    socal
    @GrumpyCabbie thanks mom.
  7. fotomoto
    fotomoto Senior Member
    5,597
    3,771
    So. Texas
    Too late now to ascertain with big holes in the block but you could have had an oil leak (loose filter or drain plug). You also could have holed the crankcase.
  8. stevemcelroy
    873
    194
    Boulder, CO
    Perhaps, but remember that issues with oil just compound on themselves - as the oil breaks down it looses it ability to lubricate and it thickens up and you get added heat and wear which causes the oil to break down even more quickly - you can go from marginal to bad pretty quickly.
  9. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    I tell it as it is. Don't check or change your oil for 11,000 miles and question why your engine went bang? Come on mate, what you playing at? :rolleyes:
  10. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Those on here that think checking the oil level is a waste of time and plan to depend on the "oil light" to let them know when they are low on oil need to read this thread :)
    2 people like this.
  11. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    when i first read the title... i thought to myself, "i wonder if your oil has gotten low" (thinking to myself that you at least topped it off)
    it seems natural that it blew up. my brother made the same mistake with my grandpas el camino. even if i dont change the oil, i still have to top it off.
    its 3.5 quarts... not 4.
    you didn't hear the engine getting loud upon a non lubricated startup? they get rather clicky and vibrate.
    i did a very overdue oil change last week. i wont say how overdue... i did add in a good 4 quarts if not more over that period of time. i could only imagine what the inside of that oil filter looks like (or the engine itself...)
  12. billinmd
    billinmd Member
    184
    28
    Bel Air, MD
    2020 Prius Prime
    So, does 11k miles overdue mean that you actually hadn't changed the oil in 14k miles, 16k miles, or more?
  13. wjtracy
    wjtracy Senior Member
    11,312
    3,588
    Northern VA (NoVA)
    I agree with you it's a surprise to me, +11k is your bad but Prius is kind and gentle little engine. Was it synthetic oil? it might have survived. It could have leaked out somehow or bad service (no refill oil) at the getgo. if you have high miles on the vehicle that is a factor.
  14. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Quite a handle our OP has: BS prius BS.
    I'll not waste my time here.
  15. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    More than likely a loose oil filter. That's why it is recommended to check your fluids everytime you fill up. Personally, I don't do that. I do however check the oil when the sun is out and it isn't too windy. Pop the hood, grab a rag, and you're done 20 seconds later. Mine doesn't eat any oil... yet.
    I also use pure synthetic. I know the oil will last 10K miles minimally, 20K miles with more than likely no issues. 10K mile oil changes are normal outside of the sue-happy USA. But there are also inspections that check this sort of thing even if you don't and they can deny your car being on the road if you fail.
    The lack of oil is what made the engine explode. That will happen to anything. The problem was not that you didn't change it every 3K miles, it is that you didn't check the oil level at all during this period. Oil is pretty cheap, and it is very important. Lesson learned. Perhaps you might have a warranty case if your "maintenance required" light never illuminated. But if it did and you ignored it, then double shame.
  16. Britprius
    Britprius Senior Member
    5,194
    1,912
    Herefordshire England
    Gumpy I could not agree with you more, not changing the oil at 10k foolish not checking the level even once a month criminal.
    The oil light is not there to say your low on oil it's there to say stop the engine could blow any second, you have zero oil pressure.
  17. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Whatever the game, it obviously doesn't require a full deck.
    2 people like this.
  18. smokiejoe
    smokiejoe Member
    178
    30
    PA
    Probably burned it up after going 16-21K. Bam!!
  19. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    I've been in charge of fleet maintenance before - once for a company and once for the taxi company, and have seen some cars run down to virtually zero oil by some idiots, yet the car has still run. You can run a car right down on oil and it'll still go for a considerable distance, giving more and more warning signs that something is wrong - the loud clatter when you first start it is a pretty good clue.
    On this subject, I remember chatting to the taxi fleet mechanic where we were on about idiots not checking their cars and ignoring obvious defects. He said the worst he had seen was a guy who dropped the car off overnight and left a note saying it was making a funny noise. The mechanic started it to see what the noise was - BANG BANG BANG, so he switched it off quickly. Turned out the crankshaft had actually snapped in half! He was amazed the car had run, that the driver had coaxed it to the garage under its own power and not impressed with the 'making a funny noise' understatement.
    :rolleyes:
  20. uart
    uart Senior Member
    4,215
    1,200
    Australia
    To bs-OP-bs. The problem is not so much going 15k+ miles without changing the oil, it's going 15k+ miles without checking the oil.
