110,000 maint. service questions
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 2ewes4me, Mar 5, 2012.
  1. 2ewes4me
    2ewes4me Junior Member
    33
    My 2007 has never had the rear brakes checked, so I called to make an appt.
    For $111 they inspect the brakes, boots, linkage, CV boots, ball joints, drive shaft bolts, belts, hoses and fluids.
    The dealership said I should also have a throttle body cleaning @ $60 and a coolant service @ $90.
    I read here that some do their own throttle body cleaning, so $60 seems wasteful, but I'd need some instructions on how to do it myself, if someone is willing to detail it for me please.
    Is the coolant service @ $90 something I should have them do?
    thanks-
  2. jdenenberg
    jdenenberg EE Professor
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    There are two coolant loops in a Prius. I doubt that $90 covers both of them. They were due to be refreshed at 100k miles.
    JeffD
  3. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    $60 for a throttle body service seems reasonable if you have no mechanical knowledge. It takes about 20 minutes to do, and the throttle body is likely to be dirty at 110k. However, I am not sure that you will notice any performance improvement from having this done.
    At 110k you should also have the transaxle fluid replaced.
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    The throttle body service is foremost a preventative against the plate getting stuck in the gummy carbon stuff from the PCV that coats the bore. It is a good idea at 100K. They should also include a MAF sensor cleaning in the price. Now, you could see if they would combine these with spark plug replacement. That whole service is 1 hour or less of labor and should around $200.
    Both coolants and transaxle fluid should be changed.
    Rear brake service, well, if they aren't making any noise, let sleeping dogs lie.
