110 - 113 F. 'Vegas temps hurts hybrid battery
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Eric "v", Jun 28, 2015.
  1. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    There is nothing wrong with the battery. I can recreate the problem just by running AC continuously. Doesn't have to be hot.
    51,961
    yard sale!!!(y) take it all down to the pawn stars.:)
  3. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    lol,
    I was horrific yesterday. It was 26c in the house, 31c outside in the car. I know the Americans will all laugh but we only get it once every 10 years or so, so it's not worth installing a/c in your house for 3 days a decade.
    Is the air conditioning in your garage the same as mine? A dodgy roof, knackered wooden side door and big gaps everywhere?
    Oh and London is hot because of all the hot air that comes out of their mouths.
    Tony D likes this.
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Gloat all you want, we know better.
    Your humidity makes almost any temperature nasty.
    The country of Moldemort
  5. mmmodem
    2,732
    1,703
    Bay Area, CA
    Wait a minute! You gave us that Fahrenheit garbage that makes no sense and then switched over to the unversality of Celsius? Oh, I hate this country's refusal to move to metric. How much brain power would it save me not having to calculate what it is at 31C?
  6. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    It's easy and takes about a month to fully sink in IF you change all your electronic thermometers to celcius and insist on using it. Change any that give you the option, though I think the US Prius is hardwired to fahrenheit.
    I guess 100f sounds much hotter than 37c, but if you change, others will follow.
    And while you're at it, change your clocks to 24h (y)
  7. Mendel Leisk
    41,474
    The one sticking point for me for Celsius conversion is body temp. If someone's sick, especially me, I want to know in Fahrenheit.
    Shutting AC off a few blocks from your destination is always a good tactic. Besides possible battery preservation, it helps dispel water from the systems, stops mold from taking hold.
  8. mmmodem
    2,732
    1,703
    Bay Area, CA
    I work in a production laboratory so I insist all my projects be measured in metric. When I write a date, I do year/month/day. I also write time in 24 hours. The only non metric units I allow are fringes and waves HeNe which gives you an idea of what I do. Inevitably, there will be a drawing written in standard and it makes more sense to convert to their units during production. I hate it.
    Yup, shut off AC about 30 seconds depending on ambient temperature from your destination for all cars, not just hybrids. In addition to what is already said above, it's 30 seconds less energy you'll be using lowering your fuel consumption by just a tad. Time it so the vents will still be cold enough at full blast to keep you cool before opening the doors. That's about 30 seconds when it's 80 degrees or so with an F.
  9. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    You'll save a LOT more energy by running the car in ECO mode with the HVAC in auto mode than you ever will by shutting the HVAC off when you near home.
  10. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Oh mine.. this is like sitting in meat freezer!
  11. Eric "v"
    Eric "v" Member
    229
    45
    'Vegas, NV, Baby
    2013 Prius v wagon
    OK Modem,
    it could just be me running the AC all the time. I have to B/C of the dangerously high temps. here in 'Vegas. So far we have had 18 consecutive days above 105 F.
    Mr. Grimes, I nearly always run the car in ECO and the AC in auto. It's only in PWR on freeway entrance ramps.
  12. mmmodem
    2,732
    1,703
    Bay Area, CA
    You don't have to feel guilty using AC. The point is, your battery is low because of AC. Nothing is wrong with the battery. Heat is not your problem. Nothing is wrong with the car. You don't have to clear out your garage or move or sweat. The car is perfectly fine.
    #32 mmmodem, Jul 4, 2015
  13. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    This quote does not mention anything about AC. I could worry about battery drain...
    iPad ?
