110 VAC inverter installation
Discussion in 'Gen 3 Prius Technical Discussion' started by bwilson4web, Jul 14, 2012.
  1. NiHaoMike
    NiHaoMike Member
    98
    16
    You'll need more inductance than just putting ferrite cores on the wires. Some old PC power supplies might have the right kind (they'll feel heavy and the inductor you want would be screwed to the case), but an easier source is to find some old microwave oven transformers and cut the welds so that the part of the core that looks like an "I" can be removed. Then remove the secondary winding and put a 0.5mm or so non metallic spacer and put that piece of the core back. (If you have an inductance meter, use it to get the spacing just right.)
    The inductance is not going to cause any problems for the inverter since the H bridge will have catch diodes. They don't like capacitance and standing waves, which is what the series inductors prevent.
  2. Jimbo69ny
    Jimbo69ny Active Member
    712
    107
    Ithaca, NY
    Ive been following this thread since it was started and you guys are just way to technical for me.
    Id like to install an inverter that will power as much as possible in the event of an outage. I cant tell you how many watts I would be using because I dont know. I just want a solution that I can use as an option if/when the grid goes down and I need power. Sure the added benefit of having the option of using ac power while camping would be nice too.
    Do you guys have any solutions yet? Is it possible to run an inverter off the HV battery (i have a plug in prius) or can I only connect it to the 12 v battery?
  3. joedirte
    joedirte Member
    281
    58
    ohio
    2003 Prius
    I
    Well running connected to the 12V with the car in READY is running it off the HV battery and the ICE to recharge the HV battery/run MG1. There are some losses from going through a DC-DC converter then losses over the wires to the battery then to the new inverter which makes a 120VAC pseudo signal and sustains a conversion loss.
    So you have losses, but it is reasonable amount compared to a gasoline generator. You just can't get more than 1kW.
    Hypothetically running straight off the HV battery could enable using 240VDC inverters and maybe get tens of kW from the ICE. But likely you would throw a bad battery code of something and need to redo the ECU software.
  4. bwilson4web
    16,533
    This is my second, 12V inverter install in a Prius, the first is in our 2003 Prius. Since this is our second Prius, a 2010 ZVW30, I'm going for the upper limit and my sine-wave, inverter 1.5kW/3kW, is oversized. But for more conservative owners, I would recommend:
    • 1kW/1.2kW surge - I've already seen 30-45 seconds at 1.2kW with the existing battery. Although I don't have a 1kW, sustained load test, our 2003 Prius worked OK so I think it is a fair risk.
    • permanently mount inverter - I really don't like the Anderson connector losses and clamp-on cords are risky and as lossy as the Anderson. I would mount to the battery cover but to the side would work provided the battery cover can still be removed.
    • directly connect 4 awg to battery post clamps - don't fiddle around as there are going to be losses BUT compared to a gas generator, the improved hybrid cycle, absence of toxic carbon-monoxide, quiet, and large tank is a big winner.
    • sine-wave inverters are nearly as efficient as modified sine-wave - if you're not into load testing, go with a sine-wave and be happy. Just make sure you test the output voltage with a true RMS meter as my inverter shows 110VAC, not 120VAC. A lower voltage increases the current draw and that is undesirable.
    Yes but I've only studied one and it was designed for fixed operation in a home. Personally, I think the right answer is to modify the Prius inverter, MG2 circuit, to provide AC power. The technical aspects are simple to outline but not trivial to implement:
    • serious switch between MG2 and AC outlets - it needs to be mounted in the engine bay which is already pretty tight. It also has to be weather proof and pretty robust.
    • switch inverter interface from HV ECU to microcontroller - less risky than the high power side, this is still tricky since these are shielded leads from the HV ECU.
    • reverse engineer the inverter drive circuits - Toyota has not provided open source for how the inverter signals works. Good Prius Friend Hobbit has done some initial work and I've some ideas. But this is where it gets really tricky. My understanding is a modulated, 10kHz signal operates the inverter but we don't know if there are special setup or undocumented digital communication between the inverter and HV ECU. This really is 'black box' magic.
    In theory, we should be able to draw about as much power as MG1 can provide, 18kW in the 2001-03 Prius. This is three times the nominal 6kW power of ordinary houses. Since we already know one house-sized solution provided 3kW, the true number is somewhere between 3kW and 18kW.
  5. bwilson4web
    16,533
    One last update before rebuilding. I added a variable 0-250W load and found:
    • 900W AC, 84A @13.2 V - this is about the limit for this configuration
    • 840W AC, 79A @13.3V - stable operation for over 10 minutes
    The B+ output of the 120A, circuit breaker got hot, 110-115F. So we're losing major power here. The ambient was 57F and I measured 70-75F on the Anderson connectors.
    My goal is stable operation at 1kW AC with a surge capability to operate a portable air conditioner in the event of a power outage. I believe when I rework it to directly connect to the 12V battery, this can be achieved. I will be using the rear mount, accepting the (I**2)*R losses from the front to the rear. The operational advantage of having the inverter permanently mounted and available for cross country use out weights the additional 150W lost.
  6. Jimbo69ny
    712
    107
    Ithaca, NY
    It lastes 10 minutes on the power from the 12v battery alone or was the car "Ready"?
    I'd like to start looking for an inverter to install. Do you have any specific brands that you recommended?
  7. Jimbo69ny
    712
    107
    Ithaca, NY
  8. bwilson4web
    16,533
    All of my testing is with the car in "READY" and the original, 12V battery.
    I have no brand preference but would recommend:
    • 1kW maximum - anything more won't be supported for long and risks overloading vehicle systems
    • sine wave - avoids a lot of issues with modified sine-wave or less expensive inverters
    • direct connect - minimize loss for maximum emergency power but installation takes more care and planning
    • kill-a-watt instrument - great for load measurement and balancing
  9. Jimbo69ny
    712
    107
    Ithaca, NY
    So whatever you were running @ 840 watts only ran for 10 minutes in "Ready"?? Did it deplete your 12v and hv batteries? Did the gasoline engine turn on to recharge hv?
    What did you connect to the power inverter to consume 840 watts?
  10. bwilson4web
    16,533
    I used a portable space heater to put ~730W load. Then yesterday, I bought a dimmer rated to 600W, hardware, and a 250W heat lamp for the variable load. With both plugged in, I used the dimmer to add the extra load and monitored the battery voltage. After 5 minutes, the battery voltage stabalized but I let it run for an additional 5 minutes, car always in READY, to make sure. Then I took my first set of measurements.
    Since my goal is 1kW, I increased the load and again took measurements. Since i knew the 120A, cirrcuit breaker and Anderson connectors were wasting power, I didn't feel the need to go any higher in this configuration.
    My next test will be after I reconfigure the inverter to power it directly from the 12V battery. I expect to get a sustained, 1kW with enough surge to power our portable air conditioner (steady state load 930W.) At this point, I will be done . . . no further development of the 12V solution.
    There have been suggestions to power the inverter from the front, possibly using the jumper post in the forward fuse box. I think this has merit BUT it also has risks. There is a 125A fusible link from the DC-to-DC converter and now the battery is on the wrong side of the cables needed to provide surge current. Worse, it is unavailable while driving down the road. So it would not work for us.
    All of my load testing is with the car in READY and the gas engine cycles as needed to refresh the traction battery charge. Normally I would measure the fuel burn at different power settings but I do not plan to keep this configuration. Once the circuit breaker and Anderson connectors are gone and it is directly connected to the 12V battery, I'll run a complete set of tests including fuel burn at different power levels.
  11. NiHaoMike
    NiHaoMike Member
    98
    16
    True sine wave is actually not necessary for most loads, definitely not for most electronics and motors. Even the Prius inverter outputs square waves at high speeds.
    Prius inverter outputs square waves? | PriusChat
    You do, however, want a good quality inverter. Also, adding filter inductors would prevent the standing wave problem with long lengths of cable and also prevent interference issues.
  12. MPG Seeker
    MPG Seeker 20k miles and counting
    Central Mass.
    Just wondering why this thread seems to have abruptly ended back in August. I have been following it with great interest as I plan to assemble an emergency back-up power system to supply a few basic appliances (not simultaneously) consisting of a natural gas fired water heater that needs AC for the ignition and the fridge. I'm thinking of a 2 Kw/3Kw true sine wave inverter connected to deep cycle 12v battery that would be external to my Prius. I would then run heavy cable from the 12v battery of the car using an isolator and a 100A fuse that would connect to the deep cycle battery. I would keep the sustained load to less than 1 Kw but want the larger inverter to
    allow for the in-rush load when the compressor of the fridge starts. The deep cycle battery should absorb the surge without taxing the Prius 12v system.
    Does anyone see any flaws in this approach?
    Dave Scarlett
  13. bwilson4web
    16,533
    Not much to report.
    I bought an Odyssey PC930 to replace the original 12V battery. Unfortunately, other events had precluded my work on the new configuration.
  14. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    A 12V battery at full charge is not going to be able to charge another 12V battery to full charge, it will need a higher voltage.
    Most inverters are rated for sustained load, and will achieve a higher peak load. Check the specs.
  15. bwilson4web
    16,533
    Hi Dave,
    The biggest problem is the high currents needed at 12V. My testing showed I was losing about 10-15% of my total energy just in the Anderson connector and the 120A, 12v circuit breaker. My new plan:
    • minimize 12V connectors - eliminate the Anderson connector and 12V circuit breaker
    • 12V circuit breaker backup to 140A fusible link - on the theory that loss of the 140A fusible link renders the car unusable, the backup circuit breaker is kept 'OPEN' unless needed.
    I am replacing the stock battery with one designed to have both deep discharge and surge capability. For now, I'm assuming the stock fusible links will protect the DC-to-DC converter but . . . I don't feel good about it. The existing DC-to-DC converter has a 125A fusible link.
    Once the voltage steps up to 110-120 VAC, longer distances become practical.
  16. MPG Seeker
    Central Mass.
  17. MPG Seeker
    Central Mass.
    I'm hoping to resume my project soon. The Prius has been out of commission for over six weeks now due to a bad rear-end collision.
    Any progress on your end Bob?
    Dave
  18. bwilson4web
    16,533
    I've been a little busy too.
  19. MPG Seeker
    Central Mass.
  20. MPG Seeker
    Central Mass.
    Considering the forecasted hurricane and that I live fairly near the east coast (~45 minutes west of Boston) I sure hope the fact that I've not put my emergency system together yet doesn't come back to bite me.
