118k Spark plug maintenance, what else should be done
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Soobz, Jun 7, 2016.
  1. Soobz
    Soobz Junior Member
    LA, CA
    I
    I just bought my prius with 118k mile and I am getting ready to change the spark plugs
    I was just curious about any other things to change while I have all those parts off to access the spark plugs
    I read somewhere that the PCV valve should be changed too
  2. Former Member 68813
    3,524
    983
    US
    i would clean the EGR and replace coolant at the same time.
  3. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    When I asked my local dealer to change the plugs, they suggested to me that the PCV be changed at the same time, and they would only charge me the cost of the part, since they were doing the plugs at the same time, and so the labour was included.
  4. Soobz
    Soobz Junior Member
    LA, CA
    I
    The EGR was replaced under recall I believe, so I am thinking to not even bother with that.
  5. Soobz
    Soobz Junior Member
    LA, CA
    I
    I figured the same. It's like a $7 part, wouldn't hurt to replace it.
  6. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,752
    1,780
    Bay Area
    spark plugs
    pcv valve
    EGR pipe cleaning
    engine and inverter coolant drain and refill
    Brake checks, lube sliding pins if haven't done so
    brake flush
    transmission drain and refill if haven't done so
    engine and cabin air filter
    HV battery fan clean
    and Throttle body cleaning.
    Have fun :D
  7. Soobz
    Soobz Junior Member
    LA, CA
    I
    Sounds fun haha , seen all your videos on YouTube, huge thanks
    NutzAboutBolts likes this.
  8. Former Member 68813
    3,524
    983
    US
    what EGR recall?
  9. Soobz
    Soobz Junior Member
    LA, CA
    I
    Not sure owner said it was replaced at the dealer from a recall,
  10. Mendel Leisk
    42,020
    Maybe the intake manifold was replaced?? Think I read something about that being done, or was it for the "violent" start up issue? Or was that tied to EGR clogging?
    Oy vey!
  11. ETC(SS)
    7,384
    While you have the intake apart clean the MAFS (carefully!)
  12. Former Member 68813
    3,524
    983
    US
    no, there was no recall. maybe he confused TSB with recall?
