12 ft long x 1 ft wide board
Discussion in 'Gen 2 Prius Main Forum' started by jcrply, May 1, 2013.
  1. jcrply
    jcrply Junior Member
    Has anyone carried a board that is 12 feet x 1 foot x 2 inches in a Prius? If so, how did you fit it in? Thanks!
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I can get a single 10 foot 2by4 in a Gen 2 Prius, 12 foot is going out a window.
  3. jcrply
    Do you think it would work with part out the window? I won't know until I try it but hate to think of buying the lumber and then not able to transport it.
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    jcrply likes this.
  5. jcrply
    I'm going to try it. Thanks! and thanks for the link to that great treehouse.
  6. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    If you do haul that 2x12 in your Prius, I would suggest you put some HEAVY towels under every place where the 2x12 touches the car. Otherwise, there will be a lot of marks to the area where the 2x12 is resting.
    Whatever you do, be careful. If the edge of that board got caught on something with you going down the road, there will be considerable damage to the Prius. Not to mention that it might end up being a catastrophic event.
    I don't want to sound like a killjoy or something like that, you just never know what might happen out there on the road.
  7. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    Great advice. Just sold my pickup truck today. Don't plan to used my three month old Prius as I did the truck. Both Lowes & Home Depot rent trucks for transporting large items. Had the pickup for sixteen years and I'm sure I'll miss it. With too many vehicles, it was the most expendable and I'll learn to live without it.
  8. jcrply
    I've used my 2009 Prius for hauling bags of mulch and rocks and sand, hundreds of plants, hay, 8 ft Christmas trees, dogs of course, and many other things including a rabbit hutch. It will hold 20 large bags of mulch without crowding the sides and without touching the roof or blocking the rear window (well, it blocks it a little but not much). I use plastic and cloth tarps and am careful. The car still looks great.
  9. bisco
    52,883
    bring a red flag with you and tie it to the end sticking out. i open the rear passenger window and lide the board in to the passenger footwell. run a tape measure along the path to see how far it will stick out.
  10. dmm
    dmm Junior Member
    I've been looking at getting a trailer hitch and a cheap harbor freight/craigslist trailer for my gen II. I know towing is not recommended but I figure a few hundred pounds for <10 miles shouldn't do too much harm.
  11. chpskt
    chpskt Junior Member
    It's not going to fit. The length limit for inside the car is about nine feet. The width of your board would probably make nine feet a stretch. A plank that size is also too big to go out the passenger side window. If it's just a mile or so you could leave the tailgate up, but you'll need to figure out how to secure the board. It would be best to borrow a truck. A twelve foot board will be a challenge even for a pickup unless it has a ladder rack.
  12. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    Out a window? You guys are seriously talking about car jousting? Darwin applauds your efforts!
    The safest way, IMO, is to lay the board down along the center of the car, with the rear seats folded down. Use the tie-downs to hold the lumber in the car. Then tie the lumber to the hatch, to hold the hatch closed against the lumber. Put a red flag at the end of the lumber. Done.
    Geez, you guys really scare me sometimes.
    krmcg, richard schumacher and garglo like this.
  13. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    maestro8 is right. That board is too heavy to stick out the window. It just gets a little breezy inside.
  14. jcrply
    Here it is: 12ft x 1ft board P1000506.JPG P1000509.JPG P1000510.JPG
  15. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    What prevents the board from sliding out ?
  16. jcrply
    The angle is really not steep. It's not as steep as it looks like in that first photo. Plus the board was quite heavy. The hatchback was held down with a bungee cord. There was never any question of the board slipping.
    Judy
  17. SageBrush
    11,627
    2,533
    Southwest Colorado
    Probably true, for typical driving. You might of had a different outcome in an accident.
  18. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    When I haul dimensional lumber I take the head rests off, slide the front seat forward, and reclined all the way. Now you can put 10 ft dimensional lumber from the foot well area all the way back and still get the lid closed.
    10 is the max, but here's what 16 footers look like. By the way the CRV in the background is useless for hauling anything.
    ftl likes this.
  19. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Instead of a pick up I got a Curt Hitch from E-trailer on eBay (they advertise here) and the external power supply for the lights too which was plug & play.
    I was going to buy a trailer but that's just another thing I have to store & maintain so instead I rent there smallest I think 5x10 U-Haul trailer for $25 for the day anytime I need it. Car pulls that heavy trailer around town real good.
    SageBrush likes this.
