12 v Battery Drain
Discussion in 'Gen 2 Prius Main Forum' started by jfs2010, Dec 15, 2025.
  1. BiomedO1
    BiomedO1 Senior Member
    3,779
    1,969
    SacTown, Ca
    1. You used one of those random number generator battery tester; those numbers are derived from a 3-5W load resistor within the unit.
    2. It showed you 10Ah and you seem to know what an OEM battery should be, so how did you reconcile that one and how did it fool you????
    3. You didn't use a carbon-pile load tester - Even the cheapest carbon-pile load tester would've failed that battery. No calculations needed.
    enough said; I'm done.....
    #21 BiomedO1, Dec 18, 2025
  2. BiomedO1
    3,779
    1,969
    SacTown, Ca
    loose connection or bad ground point somewhere??? Obviously not in the traction pack, since it worked in the other car. I'd be looking at the motor/transmission ground cables.
    #22 BiomedO1, Dec 18, 2025
  3. pasadena_commut
    pasadena_commut Senior Member
    2,696
    806
    Southern California
    The testers were both the type that use frequency tests on the battery to estimate its properties. They don't actually load the battery at all as part of the test, other than by drawing some current to power themselves. That is the method used by pretty much any small electronic tester these days, including the Midtronics one encounters at the Toyota dealership. Conveniently, for the dealers, these testers cannot fail a battery for lack of capacity.
    The 10Ah capacity was derived from checking the voltage after extended discharge and unloaded recovery, not from the electronic testers. As I said, the few electronic battery testers that claim to provide an Ah reading are just making it up. For instance:
    Battery University | Perception of a Battery Tester
    begins with
    Various sources put the fraction of lead acid battery failures from "capacity fade" at just under 50%.
    A carbon pile load tester will fail a battery if its internal resistance has gone up high enough. In the battery which was replaced it was not yet very high. The Prius and many other EVs and hybrids that do not use a starter motor only pull a few tens of amps to start the car. That is the appropriate sort of load to apply when testing them. They aren't designed to put out 200A, some of these batteries might fail permanently if they were presented with a load that large. These are essentially storage batteries (toughened up to survive the environment in a car), not starter batteries, and the large current test methods appropriate for the latter are not right for the former.
  4. pasadena_commut
    2,696
    806
    Southern California
    That was just an example for the current state of that battery. Another way to think about this is, if the battery new had N Ah, and 4 years later you measure N/4 Ah, then the writing is on the wall that it will be even lower than that some time later. Ideally one could attach a device, press a button, and conveniently measure the capacity. As things stand now, measuring the capacity takes a long time and is not at all convenient. Eventually it will get down to the point where the car won't start - quite possibly without failing a test on an electronic tester even at the end. (Or it could develop an actual fault, then it would fail, but capacity fade isn't that kind of fault.)
  5. jfs2010
    jfs2010 Junior Member
    26
    Hudson Valley
    Thanks all. I bought a Ctek 5.0 and the car is charged nicely & it is sitting in my garage now on trickle for the holidays. However, I just went down to turn it on & run it a bit and it turned on fine but the dash lights did not turn on. Fixed it quickly pressing the climate button and turning on and off the headlights. However, this has never happened before. Would it have anything to do with the car not being driven in the past couple of weeks and on a trickle charger? Thanks again for any advice.
  6. jfs2010
    26
    Hudson Valley
    Thank you. This is what I ended up doing and the car charged nicely and is on trickle charge now during the holidays.
  7. bisco
    52,084
    never heard of the climate button putting the car in ready, doubt it's related to the battery
  8. BiomedO1
    3,779
    1,969
    SacTown, Ca
    You probably have a failing capacitor in your instrument cluster power supply. There's a bunch of YouTube videos on how to fix that. Those videos recommend that you go with a higher capacitance; I prefer to stick with the factory values - perhaps up the voltage value; that'll keep the circuit balanced. Make sure to replace with a high temp electrolytic capacitor or you'll be repairing it again in a few years. The interior of you car gets really hot during the summer months.
    Good Luck.....
    pasadena_commut likes this.
  9. Mendel Leisk
    41,634
    Consider also getting an electronic battery tester. I’ve an older version of this, find it easy to use.
    there’s been comments questioning the reliability of this sort of tester; I’ve come to rely on mine, an earlier iteration (Solar BA5), seems its verdicts are accurate.
    #29 Mendel Leisk, Dec 27, 2025
    jfs2010 likes this.
  10. jfs2010
    26
    Hudson Valley
    If this is in reply to my comment above, the car was in ready but the dashboard did not light up so I could not see any lights or the ready lit up. I was able to drive in reverse in my garage (with door open) for a foot or two to test if the car was working, before trying the climate/headlight trick that I found on youtube that resolved the issue & turned the dashboard back on.
