12 V battery finally gives up the ghost
Discussion in 'Prius c Main Forum' started by davidc83, Apr 13, 2026.
  1. davidc83
    davidc83 Member
    116
    51
    Scottsburg, Indiana
    2015 Prius c
    I bought my 2015 Prius C level 2, new in October 2015. I had never had to replace the 12 v battery as it never failed to 'ready' mode the Prius. Starting this past Friday (3 days ago), I had to turn the key 2 times to get in 'ready' mode. I thought it was weird but the rest of the day it operated fine. Saturday, it took me 4 times to turn the key before 'ready' mode and I went ah oh. Yesterday (Sunday), it took me 6 turns before 'ready' mode. All the days, after it finally got to 'ready' mode and I did my errands (takes me 20 minutes to get to town), the car turned on ok. I have a solar battery tender with odbt2 connector so I hooked it up yesterday afternoon after I got back home. This morning, I had to go to a Dr appointment, unhooked the tender and 'ready' mode was first turn. When done with dr, got in the car and 'ready' mode was first turn. drove around the town to do another appointment (20mph or less), got done with appointment and boom, no 'ready mode'. Took me 12 turns of the key before it went to 'ready' mode. Bit the bullet and for $260 got a replacement 12v. A diehard S34B20R battery (perfect fit). It has 340 CCA and 425 CA. By the way, Toyota no longer has that battery on their websiet and 2 dealerships in 2 different cities told me (I called them) Toyota discontinued the S34B20$ battery, only 3r party available now. Put the new battery in and all is well. I cant complain though, I got almost 11 years out of that OEM battery. The DIehard battery has a 4 year warranty.
  2. rjdriver
    rjdriver Active Member
    411
    172
    Rhode Island
    I thought I did well to get almost 7 years from my OEM. Pretty sweet to make it close to 11. With Toyota discontinuing theirs, and me approaching the 7th year on its replacement. it's good to know there is a Die Hard out there as an option. As I recall, there weren't a lot of choices when I shopped around 7 years ago.
  3. VelvetFoot
    VelvetFoot Senior Member
    1,408
    545
    New York State
    2026 Prius
    11 years! In Indiana! I'm impressed!
  4. Kerrynzl
    Kerrynzl Member
    60
    28
    New Zealand
    2016 Aqua
    That is a miracle?
    These batteries don't have much capacity and will go flat on standby reasonably quickly.
    My battery was new in January and I left the car in storage for 2 months while overseas. [I disconnect alarms before I do this]
    I asked the crowd running the car park to move it every 3 weeks or so to give the battery a "kick in the guts"
    But they didn't.............
    Anyway I returned last week to a flat battery and the carpark people were too frightened to jump start a hybrid [So I showed them]
    I've also been caught out being parked at the beach drinking coffee and listening to music and the battery goes flat
    So a jumper pack should be in the car's arsenal of tools.
    I have jump started an Aussie Falcon [4.0 24v EFI Barra engine] with an 18v 3ah Makita Li-ion battery and it worked great.
    But I'm a bit reluctant to shove 18v-21v into the Prius C electrics.
    Also the Prius will Self Start after a few seconds of being parallel connected so the Jumper needs to be diode protected from the Prius.
    I might make my own jumper pack as a DIY project and maybe post a "How-To" here if anybody is interested.
    I have piles of dead Makita Batteries and clones lying around [I have a tool addiction]
    #4 Kerrynzl, May 14, 2026
    VelvetFoot likes this.
  5. bisco
    52,841
    always make the car 'ready' when listening to the radio, and etc
  6. ColoradoBoo
    ColoradoBoo Senior Member
    1,348
    972
    Monument, Colorado USA
    Wow that's amazing! I have a battery tester so always test ours when doing oil changes. My 2021 Prius is, still, saying 100% of life left (65,000 miles) while my wife's 2024 Corolla Hybrid is testing at just 73% with 7,000 miles on her.....strange!
  7. Kerrynzl
    Kerrynzl Member
    60
    28
    New Zealand
    2016 Aqua
    Did you test the 2024 Corolla battery directly off the posts?
    I had a brand new battery in a Ferrari that tested 860CCA on the bench [direct off the posts] but when it was installed ,it tested 500CCA off the jumper posts which are only a few inches away from the battery.
    And yes ,the posts and clamps were cleaned before the install
    I replaced my battery on my Hybrid in January after simply going dead while I was listening to the radio and detailing the car
    I no longer trusted it, so it was cheap with my trade discount to replace [NZD $100+ Tax or USD $60+Tax]
    Ironically after replacing the battery I gave the old battery a re-charge with a Motorcycle C-Tek charger [0.8a] and have used it ever since powering a DIY spot welder machine
    #7 Kerrynzl, May 17, 2026
  8. ColoradoBoo
    1,348
    972
    You're right....I re-tested her battery but on the larger part of the Positive post and got 100% health...phew....I didn't want to have to run to the dealer to get the battery swapped out under warranty. (She'll be two years old in September)
    Kerrynzl likes this.
  9. Kerrynzl
    Kerrynzl Member
    60
    28
    New Zealand
    2016 Aqua
    It's a "Man Cave" issue :D
    I think our wives have the best approach and leave it up to us to fix [or create] problems.
    After 55 years of modifying cars and playing with race cars etc I chose a hybrid so I wouldn't touch the damn thing.
    But I didn't learn
    Now there is a whole new set of skills to learn all over again
