12 V battery, gone for 2 months
Discussion in 'Gen 2 Prius Technical Discussion' started by derh2o, Apr 1, 2009.
  1. Patrick Wong
    18,210
    6,526
    Since Russ, who originally posed the question, was concerned that his 12V battery was not being charged, it makes sense to measure voltage directly at the battery to rule out the possibility that there's a bad connection between the battery's positive terminal and the dedicated jumpstart terminal at the front of the vehicle.
  2. eatdrumss
    eatdrumss Junior Member
    57
    cleveland
    12v battery charging?
    Can you charge the 12V with a regular car battery charger?
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Yes, but try not to exceed 2 amps. The 12 vdc battery is quite small, too high an amperage setting could cause the battery to vent electrolyte
