12 v battery replacement - won't run
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by HOVZOOM, Mar 26, 2008.
  1. HOVZOOM
    HOVZOOM New Member
    37
    Fairfax, VA
    2002 Prius
    I'll try that in the morning and report back Patrick.
  2. rick57
    rick57 Member
    572
    Circleville, Ohio
    Think your going in the wrong direction looking at the battery voltage. It will probably be ok. I still think maybe circuit opening relay or MAF sensor dirty. Did you have the air filter out by any chance?
  3. Patrick Wong
    18,200
    6,502
    Hi Rick,
    These also are reasonable to check. Not sure whether HOVZOOM has the ability to test the circuit opening relay or remove/clean the MAF sensor.
    Going back to basics, a gasoline engine requires compression, spark, and fuel to start. I am assuming compression is OK.
    If HOVZOOM can do this, how about removing one igniter & spark plug, then connect the wiring harness to the igniter, ground the spark plug shell & see if there's spark and fuel odors when the car is trying to start.
    Another concern is that the traction battery charge may be rather depleted by now. Does the MFD show SOC at an acceptable level?
  4. HOVZOOM
    HOVZOOM New Member
    37
    Fairfax, VA
    2002 Prius
    To be clear, the ICE does start, runs normally for about 10 seconds, and then something shuts it down. Check engine light is on the whole time as well as the blinking last bar in the fuel gage. So, the ICE is getting fuel & spark, at first. Air filter is brand new. Not sure how to clean the MAF sensor but I have to think it is OK because the car ran just fine until last Wednesday when I did the 12v battery replacement and all of this started.
    Is there a way to clear (without disconnecting the 12v battery) the check engine light?
    The car will be towed to the dealer Monday morning if I can't solve this today.
    Thanks, again, for all the help.
  5. patsparks
    10,664
    567
    Adelaide South Australia
    The ice spins, how do you know it starts?
    The electric motor will spin the ice at about 1000RPM (Idle speed) with no "starter motor" noises. It will spin for 10 seconds then if the engine hasn't fired it gives up. Can you rev the ICE within that 10 seconds? floor it and see if the revs go up.
  6. HOVZOOM
    HOVZOOM New Member
    37
    Fairfax, VA
    2002 Prius
    I can rev the ICE, the ready light comes on, and move the car if I put it in gear during those 10 sec.
  7. HOVZOOM
    HOVZOOM New Member
    37
    Fairfax, VA
    2002 Prius
    Well, good news – the car appears to have fixed itself! Here is what happened today in case it can help anybody else with a similar problem:
    I went to start it and the ICE remained on (did not shut off in 10 sec like before) but check engine light, red triangle are illuminated and last bar on gas gage blinking like before. I let the ICE run in park for about 2 min then put it in D & R and drive back and forth in front of my house a few times (don’t trust it to drive further than that).
    Then I put it in park and let the ICE idle until it shuts off normally for battery only operation.
    I turn off the ignition and restart.
    The ICE starts, check engine light is on, last bar on gas gage is blinking BUT the red triangle is off. Put the car in gear and drive back and forth a few times. ICE shuts off normally.
    This time the ICE starts BUT no red triangle AND no check engine light. Last bar of gas gage still blinking. Drive car around the block (I got brave) and all seems normal.
    ICE starts, all warning lights off AND gas gage showing almost a full tank! Drive car around the block several times and all seems normal.
    ICE starts and all is normal.
    I’m very pleased but still nervous something is still wrong. I’ll start it later today to make sure all is still OK before I commit to driving it to work tomorrow.
    Thanks again.
  8. Jiipa
    Jiipa MGySgt USMC (Ret)
    314
    Oahu, Hawaii
    Wow, I knew my Prius was good but I didn't realize that it was that good!:)
  9. Patrick Wong
    18,200
    6,502
    That's great. What is the traction battery SOC now?
    I suggest that you drive it at least 30 minutes today and ensure that the car continues to work, before you embark on your weekday commute.
  10. HOVZOOM
    HOVZOOM New Member
    37
    Fairfax, VA
    2002 Prius
    Traction battery is fully charged (after driving around a bit).
  11. Patrick Wong
    18,200
    6,502
    Good.
    Thinking ahead, if you experience similar symptoms in the future, then it is quite possible that you need a new engine ECU, which allows more time for the engine to start before logging a DTC. The specific DTC involved are P3191/P3101. TSB EG011-03 is the relevant service bulletin on this issue.
    For fun, you can try finding the engine ECU which is located behind the glove box. The current part number is 89661–47054. If your ECU has a number below that, then you would benefit from getting the current ECU installed.
    If your car has less than 80K miles, this should be covered under the federal emissions warranty. If your car is no longer covered by warranty, then you can try buying a salvage part and installing yourself.
    If it is not possible to obtain the current version engine ECU, then you can try tuning up the car as follows, which might improve the engine start time so that you no longer have problems:
    If the iridium spark plugs had not been changed at 60K miles, I suggest that you change those now. You've said that your engine air filter is new so you are good to go there.
    Test the circuit opening relay (I suggest replacing if the resistance across the switched terminals is 0.2 ohm or more) and clean the MAF sensor with brake parts cleaner as Rick suggested. In addition the throttle body and throttle plate should be cleaned using throttle body cleaner.
  12. HOVZOOM
    HOVZOOM New Member
    37
    Fairfax, VA
    2002 Prius
    Thanks for all the info Patrick. I did replace the plugs about 2,000 miles ago and the car has about 89,000 miles on it now so I'm past the warrantee you mention. I will check out the ECU as you suggest.
    BTW, I see you are from OC. I lived in Huntington Beach for 10 years. I really miss it.
  13. Walker1
    Walker1 Empire
    911
    FL
    I used to own race cars & go to the strip. I always went by one rule- if the car is not running right I made only 1 change/adjustment between runs as to find out what happened. You stated that both batteries have enough volts in them. The only other item(s) you changed were the plugs. But, that was 2,000 miles ago. Did the car run fine for the last 2,000 miles? Did you change or perhaps move any electrical wires or perhaps not tighten all your connections? Take back steps & think of anything else that could have been disturbed when you did the battery change out.
    It could be a fluke, but electrical systems can be strange as they get older. I wonder if Toyota has a code book & meter you can plug into the diagnostic port of the Prius. My last computer car was a Buick Grand National & I had a code book & meter I bought from GM that helped me isolate hard codes. In this case if you can't find a loose connection or something related to what you did then the dlr. will have to find it for you.
    My only other thought is the old battery was good & just a little weak from age. You put a new battery in the car & it wouldn't stay running.You then put the old battery back in & got the same results.
    My guess is something got disturbed & is causing the new problem.
  14. SaxyBiz
    SaxyBiz Junior Member
    I may be totally wrong, but if the old battery was weak, and if the new battery was only partially charged...when attempting to start the ICE for the first time, neither one had the lasting current capacity to maintain and sustain the voltage needed for all of he CPU functions to clear. On your last try, the voltage on the new battery may have stayed above the threshold needed to keep the ICE running long enough to charge it sufficiently. I'll let the experts speculate on this theory...I've experienced extreme battery voltage drops during testing while under load conditions. What do the Senior Engineers Think?:unsure:
  15. DREAM845
    DREAM845 New Member
    newyork
    2001 Prius
    try turning the key on and off about 8 to 10 times ,this will give the computer time to reset any time i have removed the cable for work being done on car i had to turn the swith on /off to reset.
  16. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Old thread, but just replaced the battery in my wife's 2002 ($130 - 10% at Larry Miller Toyota), and had the same exact symptoms (caution + hybrid warning on the screen). Some times the engine was allowed to run, others, it was "forced to stall". New battery wasn't pre-charged, so charging it at 12V/2A is in order. BTW - label on the battery says no more than 3.5A and 10 hours max charge.
    During the error condition at it's worst, ICE basically sounds as if it's stalling some of the time (too much load?), and gas gauge varies between two bars and flashing 1 bar. Other times, it will continue to idle.
    I then let the battery charge 10-15 min at 2A, and then started the car a few times and the error condition cleared. I was able to drive to a gas station and put gas in (didn't take more than 8 gal so the gas guage was "wrong").
    Lesson learned - new batteries must be charged prior to installation. I'm letting it complete the charge (charger still shows ~40-50% charged, but the car isn't "dead".
    Hope this helps others.
  17. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Just curious, while the engine was running, did you try the " Force charge method"? ie: All brakes on, put in Drive, push accdelerator to the floor. This will charge the HV to green and thereby charge the 12V aux. Oops, I didn't notice thread date, Oh well, next time.................
