12 V battery replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by CathyO, Mar 31, 2015.
  1. CathyO
    CathyO New Member
    south carolina
    I just replaced my 12V battery and now the car won't start. It will take a jump and show "ready" on the dash but as soon as the car is turned off, it won't start again - no lights, nothing. Any ideas. I checked some fuses and they looked fine.
  2. Mylar
    Mylar Member
    163
    37
    Cincinnati, OH
    2019 Prius
    Is the new 12-volt battery fully charged? Did you reconnect the negative battery lead to the car?
  3. ursle
    ursle Gas miser
    1,049
    192
    NH
    By chance had the car been idle for a period?
  4. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    either you popped fuse(s), hooked something up wrong (or didn't hook it up), or the new battery is junk. go back and recheck your work. make sure all connections are tight. check the fuses and check the voltage at the battery.
  5. bisco
    52,889
    did u jump the battery or the charge point under the hoodie?
  6. mikefocke
    4,083
    1,865
    Sanford, NC
    Is the polarity of the battery the same as the one you removed? Meaning is the plus post on the same side and hooked to the same cable? In installing, did you disconnect the cable from a ground to the chassis of the car?
  7. wirelessjava
    wirelessjava Member
    105
    23
    Union City, CA
    How much does this entirely cost?
  8. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    To replace a 12V? About $200 plus your time. If you reverse jump the car? Potentially, thousands....
  9. N.J.PRIUS
    N.J.PRIUS Member
    140
    50
    Fort Lee, NJ
    2013 Prius Plug-in
    When I had to change out my 12v battery (not being mechanically inclined at all) Toyota dealer charged me $290. I thought that was high, however, it was done right and any problems I just take it back to them. I guess peace of mind in that respect.
    One of the tip offs that my 12v battery was going bad was that I had to reset my digital clock 3-4 times because it would not keep the correct time. After that it has been perfect since the new 12v.
  10. bisco
    52,889
    actually, $290. isn't bad for a dealer. some have reported over $400.
    N.J.PRIUS likes this.
  11. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    But it WORKS when jumped to another battery.
    That rules out fuses and installed with the wrong polarity.
    Either......the connections are not good OR the new battery is dead, because it's defective or not charged.
    Eclipse1701d likes this.
  12. lar.smith42
    lar.smith42 Active Member
    203
    118
    Double Oak , Texas
    Were did you get the battery. Is it a Toyota battery or a cheap battery. Cheap battery may be your problem. Just had mine replaced at dealer for $265.
