12 V battery Voltage
Discussion in 'Gen 2 Prius Technical Discussion' started by frosh, Jan 23, 2008.
  1. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i've already posted this question on This thread... then again there are probably several dozen 12v battery threads...
    my battery clearly stats to never exceed 4.3amps ( i think it's .3) while charging. it's on a yellow sticker under the +terminal.. under all that plastic.
    anyone else?
  2. Blue Nimhrod
    Blue Nimhrod New Member
    Ashland, MA
    You guys are making me nervous.
    14.1 Volts running powered up
    11.9 Volts after 12 hours parked not powered up
    I have never had any problems even after parking 5 days at the airport
  3. frosh
    frosh New Member
    35
    Virginia
    no worry for you! I never had a problem other than inside my garage, car unlocked. Thanks for your contribution.
    frosh
  4. V8Cobrakid
    3,790
    152
    Can anyone read that? "never add water nor charge quickly. when you charge battery, charging current should not be higher than 4.2amps and charging time should be within 10 hours"... etc...
  5. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Yep, I can read it. My buggered up cover has the same label. Yet the Prius PDI states to use the Toyota AUtomatic Battery Charger - made by Associated - set at 10 amps
    They warn that a setting of 2 amps will result in very long charging times. For those with a completely dead 12 vdc battery, a 2-5 amp setting will probably not do much.
    For a normal battery, the VDC Battery Minder puts out around 1 amp max. The VDC manual cautions that the Battery Minder will only condition and maintain a float charge on a fully charged battery. A dead battery still requires charging with a regular battery charger
    I'm in agreement with David Beale that given the huge assortment of battery chargers out there - especially the cheaper ones that put out too much voltage - Toyota had to make a blanket suggestion on the side of caution
  6. jayman
    13,439
    641
    Winnipeg Manitoba
    You probably won't experience any issues unless there is a cold snap and the car is parked outside
  7. satwood
    satwood Member
    107
    16
    Webster, MA, New England, USA
    2014 Prius v wagon
    It is also important to note where you are making the measurement from. If you are measuring the voltage from the ACC plug, you could be getting a voltage drop dure to the long wiring and other loads on the circuit when the car is in ACCY mode. If you are measuring directly on the battery terminal, then I would expect to see more like 12 - 12.4. However, if we're quibbling over 1/10th of a volt with commercial meters then we don't really have a problem to solve. I'm worried about the numerous posts that look like dead battery issues.
  8. jayman
    13,439
    641
    Winnipeg Manitoba
    I agree. However, if using a quality DMM directly on the battery indicates voltage lower than it should be, and the car has been going dead, there is either a parasitic drain or the battery is chronically undercharged.
    If the battery is going low or dead in bitter cold temps, it needs proper charging. When I had trouble with my Prius in winter of 2004, the dealer couldn't find any parasitic drain and the resting current was around 30 mA. I checked and also couldn't find any unusual current draw
    I think a combination of the constant voltage source, bitter cold temps down to -40, headlights always on, Max Heat, and constant electric rear window defrost all took their toll. It should be noted that since I started using the Battery Minder, no more problems
    If there was excess parasitic draw, or a shorted cell, the Battery Minder would be unable to charge. My model is current limited to 1 amp, and voltage limited to 14.2 vdc
  9. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    I think you are right. I've never thought about that in the 1st place. The plug has no power, when the Prius is powered down. So I guess if I really want to charge my 12V batt in the future, my best bet is to just open the rear compartment and go directly to the batt leads. What is your take on this? :confused:
  10. jayman
    13,439
    641
    Winnipeg Manitoba
    Unfortunately, if the battery is dead the hatch won't open. Could always use the underhood jump point
  11. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    There is an inexpensive wiring kit to make the front cig (oops, aux power outlet) active when your Prius is off. You can order it from: Prius Accessories
    JeffD
  12. jackmilas
    jackmilas Junior Member
    60
    Wrocław, Poland
    Thanks to this forum I switched on maintenance monitor and I saw a horrifying 9.8V in accessory mode. Actually you can see that dashboard and interior lights are dimmed prior to switching the car to "ready" mode.
    I am replacing the battery next week. The car is 6 years old and has 75.000 kilometers.
  13. Bob.H
    Bob.H Junior Member
    38
    Findlay, Ohio
    Is this true?
    How do I know the FOB is too close?
    If so I think I found the reason we abused our 12 Volt battery to death this winter.
    Bob
  14. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Hi Frosh. Mine are similar but you really should post the conditions under which you're measuring, because there are lots of factors that will affect it.
    Here are some measurement I made a while ago here : http://priuschat.com/forums/gen-ii-...-troubleshooting/72319-tested-my-battery.html
  15. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    oh
  16. frosh
    frosh New Member
    35
    Virginia
    Thanks uart,
    I was measuring with a voltmeter at the fuse panels, both in off position and the second one with external charger.
    Well, in the meantime I found a couple of reasons why the battery drains.
    First of all, this is small "alarm system like" battery.
    Leaving the driver or passenger door not 100% closed burns up the battery in 24-48 hours because of the bottom door lamps (not highly visible, even in darkness)
    Forgotten to switch off the dome light, same effect as above
    I wish they had put in an electronic switch-off after some 30 minutes, like one would expect from a car priced like this.
    Thanks for you comments,
    frosh
  17. frosh
    frosh New Member
    35
    Virginia
    One more observation,
    once the 12V battery was empty, the mileage starts out at 42-43, only to pick back up to 51-52 after about 3000 miles no matter if summer or winter...
  18. jackmilas
    60
    Wrocław, Poland
    The battery has been replaced! I wonder if there is any explanation for that I feel the car works a bit smoother and uses more electric motor and keeps the engine on lower revs than before replacement? I noticed fuel economy improvement. I did 40 kms in city traffic today and I got 4.6l/km. Before I would get something around 5l/100km in the same conditions.
  19. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    well of course there is an explanation.
    your dead 12 volt battery was exactly that, dead weight!!
    run 100 yards while timing it.
    then run 100 yards carrying a 2 year old (how bad can it be, they only weigh 20 lbs right??) see the difference in time. should it be that much?? after all the kid only weighs 20 lbs.
    well your Pri is the same way. its a mother helping out its child by ensuring the 12 V battery is fully charged, but the battery is dead and can no longer keep what mother is giving it, but ya know how mothers are. they have 100% faith in their children no matter what, so they keep feeding power into that tiny little mouth with total love in their eyes. so, that teeny tiny insignificant drain on the system is significant.
  20. Eug
    Eug Swollen Member
    970
    223
    Earth (for now)
    Technology
    So, here are my numbers from that Signal Check screen, on my 2004 Prius with 100750 km on it.
    Maintenance mode: 12.0 V
    Press power again: 11.8 V, or 11.7 V with the heater fan on low and 3rd party GPS plugged in.
    Ready mode: 14.1 V
    Temp outside is about 2 degrees C (or about 36F).
    Do I need a new battery, or am I still OK for a while? That elearnaid page seems to suggest that it's OK (albeit not great).
    BTW, has anyone shipped from them to Canada? If so, which shipping method? Air Mail seems to be the proper one at $71.50, but it's not entirely clear from their website. If $71.50 it'd be $251.50, plus probably a handling fee at the border so about $260 plus tax.
    What is the cost in Canada for the OEM battery? If it's only about $150, then maybe I'd just get that, if it's easy to install, and if I actually need one that is.
    P.S. I don't know how to turn on the rear windshield heater in Maintenance mode.
    P.P.S. No I haven't tried a voltmeter yet. I guess I should do that first.
