12 volt battery Cold Cranking Amps
Discussion in 'Prime Technical Discussion' started by D Beloy, Apr 4, 2020.
  1. D Beloy
    D Beloy New Member
    Hawaii
    2018 Prius Prime
    The battery in my Prius Prime says 295CCA(EN) and this morning at the dealer , they tested the battery and it is putting out 344CCA. Does that make sense? It is rated at 295 and it is putting out 344. I called their parts department and their replacement battery which costs about $180 has a rating of 470CCA. I’m confused. Why does the label on the battery that is installed in my prius saying 295 but it is putting out 344? Do I need my battery replaced by the dealer? The battery did say (EN) which means European Norm. So what does that mean? Thanks for your thoughts on this issue.
  2. schja01
    schja01 Senior Member
    1,842
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    I think cold cranking amps is almost meaningless as it doesn’t need much more than two lantern batteries to “start”. The traction battery does all the heavy lifting. The 12 just boots the computer and powers some 12v accessories when not in READY Mode.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    It tests BETTER than nominal. Why would you think that is a problem ?
    It isn't.
    BUT that alone isn't a really good test either.
    Why are you having it tested in the first place ?
    At only 2 years old, it likely is just fine.
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    "Cold Cranking Amps (CCA) CCA is a rating used in the battery industry to define a battery's ability to start an engine in cold temperatures. The rating refers to the number of amps a 12-volt battery can deliver at 0°F for 30 seconds while maintaining a voltage of at least 7.2 volts." - Cold Cranking Amps (CCA) | How to Choose Your Battery | Autobatteries.com | Clarios
    I am betting it was not 0°F in Hawaii.
    frederw1701 likes this.
  5. Elektroingenieur
    2,515
    3,287
    Three Touring
    Yes; as @JimboPalmer kindly pointed out, the test conditions were probably more favorable than those used to determine the rating on the label. As long as the battery can provide at least its rated current, the CCA test passes. Other tests might pass or fail, depending on the battery’s condition.
    As @schja01 kindly mentions, the auxiliary (12-volt) battery on a Prius car is never required to deliver its full current, since the engine is started by MG1 in the transaxle, using energy from the much larger HV battery, but CCA remains a useful measure of battery performance.
    In the Repair Manual (more info), Toyota writes, “When replacing the auxiliary battery with a new one, use an auxiliary battery with the same physical dimensions (LN 1), a cold cranking ampere (CCA) 295 A or more, and a 20-hour rate capacity of 45 Ah or more.”
    Not unless there’s some other problem that you haven’t told us about.
    If you do need a replacement, it doesn’t have to be from a Toyota dealer, unless they’d provide it for free under warranty. Batteries of the correct size and rating are now widely available; see my January 2019 posting.
    My posting linked above discusses the EN battery standards.
    illumiN8i likes this.
  6. Mendel Leisk
    41,867
    It's very normal for a battery to measure higher than rated CCA. If it were lower, then I'd get concerned.
  7. Xterra72
    Xterra72 Senior Member
    1,437
    1,681
    Would anyone know the CA cranking Amps for the Toyota Prius 2013 12 volt battery?
    I’ve looked at the battery and all I could find was the CCA Cold Cranking amps at 325 A.
  8. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    You'd find more information about your 2013 Prius 12V battery in the Gen 3 sections. Gen 3 and earlier use a completely different battery than Gen 4. We never had to replace a Gen 3 battery, but we did put an Optima Yellow Top battery in our 2005 Gen 2. I believe Gen 2 and Gen 3 use the same 12V battery. I also seem to recall Gen 2/3 use AGM batteries while Gen 4 use normal flooded lead-acid batteries.
