Gen 4 12 Volt battery.
Discussion in 'Gen 4 Prius Technical Discussion' started by padroo, Feb 13, 2018.
  1. Prodigyplace
    12,720
    11,852
    Central Virginia
    NAPA had a direct replacement? I believe it is Japanese size.
  2. Mendel Leisk
    42,384
    Can you post the battery's identifier stats, name, part number or whatever? Thanks. (y)
    Prodigyplace likes this.
  3. Elektroingenieur
    2,515
    3,288
    Three Touring
    It’s a Japanese adaptation of a European size. As @padroo pointed out in post #1 of this thread, BCI now has a group number, 140R, with the same 207 mm × 175 mm × 190 mm case size and terminal arrangement.
    From the photos @KeanuMok kindly shared, I believe it’s the NAPA BAT 75140R.
    PtPri, Mendel Leisk and Prodigyplace like this.
  4. padroo
    padroo Senior Member
    2,763
    2,253
    You would think we would have the Gen 4 Prius 12 V battery all sorted out by now.:)
  5. Prodigyplace
    12,720
    11,852
    Central Virginia
    That’s what @Elektroingenieur is saying. It has been sorted out by a new size designation. 140R.
  6. padroo
    2,763
    2,253
    Here is a battery from Advance Auto and says it is an exact fit and it says it is a group H4, there is no mention of 140R
    Advance Auto Parts - Down for Maintenance
    The one from O'rilley auto parts store is a 140R and it says it doesn't fit.
    #66 padroo, Jan 5, 2019
  7. Elektroingenieur
    2,515
    3,288
    Three Touring
    Part of the problem has been that there are multiple designations and designation systems, some of which have only recently been used to describe batteries available in the U.S. aftermarket, and not all of which are used consistently by sellers. Toyota didn’t help matters with their “no size listing” statement, either, though the 2017 edition of their battery application guide (PDF) mentions the “H4” designation.
    The case size (207 × 175 × 190 mm) and terminal layout came from the European EN 50342-2 standard (successor of EN 60095-2), which also defines other sizes; that one is known as size “LN 1.” That standard was adapted for Japanese use, as previously described. BCI subsequently assigned 140R as their group number.
    At this point, I think it’s safe to say that any LN 1, 140R, or H4 battery would fit physically in a fourth-generation Prius or Prius Prime car, and most would also be suitable electrically, considering the relatively undemanding requirements. Since the battery is under the hood, a flooded (wet cell) lead acid battery, as Toyota installs, will do; an AGM battery is required only for previous models that have the battery in the passenger compartment.
    We also had a report of a successful replacement with a battery having the BCI group number 26R. This group has a similar case size, 208 × 173 × 197 mm, and could be a reasonable second choice if an LN 1, 140R, or H4 battery isn’t available.
  8. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I can't see why MPG would be different with 12v battery - it should be unrelated.
    When you sat in the parking lot charging your phone, did you have your car running, or just on Auxiliary?
    ralph seifer and DonJuan1943 like this.
  9. Prodigyplace
    12,720
    11,852
    Central Virginia
    There have been reports of mpg affected by bad 12 volt. Likely the inverter is using extra energy from the traction battery trying to charge the bad 12 volt battery.
    krmcg, kithmo and Raytheeagle like this.
  10. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    It's like a flashlight using batteries that are drained and need to be replaced. You can still turn on the flashlight and it'll have enough charge to throw out some light, but not as bright as if the batteries are new. Likewise, a discharged 12v battery will still allow the car to turn on and run, but not as efficiently as a new fully charged battery.
    SM-T820 ?
    krmcg likes this.
  11. alanclarkeau
    7,045
    7,593
    I can understand that the inverter will be sending some power to the 12v battery to charge it. As long as there's enough in the 12v to START the Hybrid system you'll get going - and the inverter will gradually charge the 12v battery. The relatively low powered 12v battery is using only a small fraction compared with the charge in the hybrid battery and the other electrical systems going on. I can't see how it will make a difference to MPG. A hybrid battery with only 2 bars will use more MPG as it charges.
  12. Prodigyplace
    12,720
    11,852
    Central Virginia
    The engine needs to run more to replace the extra electricity used from the traction battery trying to charge a 12 volt battery that never gets fully charged.
  13. alanclarkeau
    7,045
    7,593
    But it's not going to be much. It's like I wonder why race-cars drive with headlights on - but I was told that it's just a drop in the ocean compared with the amount of power driving the car itself.
  14. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    Does anyone know whether you need to add distilled water once in a while to our battery? I tried to search myself and cannot seem to figure out to try and add or not.
  15. Prodigyplace
    12,720
    11,852
    Central Virginia
    @Elektroingenieur what does the service docs say?
    I believe you can check & add water as needed but I do not think it should be needed.
    #75 Prodigyplace, Jan 25, 2019
    alanclarkeau likes this.
  16. Mendel Leisk
    42,384
    The caps look to be readily accessible, no sticker over them. The case is completely black/opaque, or is that just the top? A translucent case affords a much easier view of the electrolyte levels.
    My past experience: removing a battery, about mid-way through it's "life span", I'll see electrolyte levels starting to drop. The case side walls were usually translucent, and IIRC there was a reference line showing the top-up level. I topped the cells up with distilled water, then hooked the battery up to a charger. Then cleaned the posts and clamps and reinstalled.
    PtPri and padroo like this.
  17. padroo
    2,763
    2,253
    You could check the electrolyte level but as long as it is over the plates it is OK.
    Like Mendel said use only distilled water.
    Anyone ever notice the strange battery terminal clamps?
    alanclarkeau and Mendel Leisk like this.
  18. Prodigyplace
    12,720
    11,852
    Central Virginia
    It is just the top & the bracket. They even mark a Lower level.
    Why are we doing the work for those too lazy to check? There are shadows in the photo so you cannot see my battery level.
    IMG_0676.JPG ?
    PtPri and Mendel Leisk like this.
  19. Mendel Leisk
    42,384
  20. Prodigyplace
    12,720
    11,852
    Central Virginia
    I thought the sides were clear but I just went outside & checked..
    I know you do not have a Gen 4 so I looked for you.
    Apparently that is too difficult for some people here. o_O
