12 volt battery does not seem to be charging correctly.
Discussion in 'Gen 4 Prius Main Forum' started by Ozark Man, Jun 1, 2021.
  1. Ozark Man
    Ozark Man Member
    173
    64
    Mississippi
    Four Touring
    I keep a battery tender on my battery and usually only take short trips of about 16 miles. When I do it usually takes the tender about 30 minutes to an hour to charge it back up when I return. Today I drove about 60 miles or so and it took about 3 hours to get back up to 80%. ( a green light blinks at that point and becomes solid at 100%). I know from the service records that the previous owner had to replace it under warranty when the car was only 3 years old because of a dead cell. It only has 23,000 miles now. I just wonder if the car isn't charging correctly. Forgive my ignorance but I'm not sure what charges it, I think one of the electric motors. I bought it certified two and a half months ago so I have a year warranty. I'm wondering if I should take it to a dealer and have it checked out. I don't see why it should be discharging that much while it is being driven. But I do know that little tender must be just a trickle charger, it is about like the size of a TV plug. Any suggestions?
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    The system works completely differently from what we're used to with a "normal" belt alternator/voltage regulator type system.
    Did the previous owner replace it with the proper battery? I assume so, if it was warranty.
    I haven't been able to understand it - my battery is just over 5yrs old. From what I gather, it doesn't insist on getting to max charge and keeping it there - as it doesn't do much - well, compared to a car with a starter motor.
    Basically - it's got a brain of its own - and it's something us mere mortals maybe won't ever understand: These diagrams are from a 2016 TOYOTA document - totally different from anything I've seen before, and I won't try to second guess what's going on.
  3. Ozark Man
    Ozark Man Member
    173
    64
    Mississippi
    Four Touring
    Yes, I see what you mean. It was replaced with a Toyota 8 yr battery just like the original. I guess it could have been because the previous owner didn't drive much either judging by the miles. He may not have ever charged it like I am. Thanks for your help though. You seem to be a lot more knowledgeable about these cars than I am.
  4. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    The "electric motors" only charge the high voltage battery. Then the high voltage battery charges the 12V battery, but only when the car is in READY mode. If you want to monitor the 12V "charging" voltage in real time, put one of these in your front 12V outlet. The outlet is OFF until you press the Power button. Pressing Power without the Brake pedal once puts you in ACC mode, and you'll read around 12V. Pressing Power again without the Brake pedal puts you in ON mode and the voltage reading will drop slightly as more systems are powered. Pressing the Brake pedal and Power again will put the car in READY mode, and the voltage should now indicate over 14V, which signals the high voltage battery is charging the 12V battery. If you keep the device in the outlet while driving, you'll see the reading drop below 13V periodically as the smart charging circuit modulates the charging voltage. It will return above 14V when the circuit detects the 12V needs more charge.
    alanclarkeau and Ozark Man like this.
  5. Ozark Man
    Ozark Man Member
    173
    64
    Mississippi
    Four Touring
    Thanks for that good info. I had seen videos about putting it in on mode not ready or acc and wondered how it was done. Guess it is in the owners manual and I haven't seen it. I found another thread on here that said several 2017 owners have had the 12 volt fail in the 3rd year so evidently this must be a weakness in the 4th gen or maybe just the 2017's. Anyway I think I will be ok if I keep the tender on it. It's not a real inconvenience since I have an electrical outlet in my carport.
  6. Mendel Leisk
    42,345
    Instead of charge duration, consider getting it tested with an electronic load tester. Dealerships have them, but likely won’t test for free. Automotive retailers selling batteries often have the testers, and likely WILL test for free. You can also DIY test, with something like Solar BA9 (retails around $60~80 in the States?).
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    First, you need to test the "float" voltage of your tender and the charging voltage while the car is running.
    If both of those looks good.......13.2 to 13.8......and too high is often just as bad as too low, then you need to get a thorough test on the battery. It might be going bad. More likely if you don't recognize the brand name.
    Ozark Man likes this.
  8. sam spade 2
    7,035
    2,804
    2017 Prius c
    Good advice.
    BUT.....one should not trust a single test.
    It needs to be repeated 3 times in a row with about a minute in between each test.
    That is if it tests "good" the first time.
  9. Ozark Man
    Ozark Man Member
    173
    64
    Mississippi
    Four Touring
    It's a dealer installed Toyota battery installed last year by the previous owner according to the service records.
  10. sam spade 2
    7,035
    2,804
    2017 Prius c
    It still could have failed.
  11. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    What @alanclarkeau said. (y) The Gen 4 doesn't try to maintain a 100% charge on the aux battery. Mine is the original in a 2017. I don't obsess over it. But on the times I've checked it, it was never at 100%. It's never been a problem. I rarely drive more than an hour at a stretch; usually about 20 minutes or so.
    I do have a little readout plugged into the 12V outlet. It shows 14.1 volts right after I start the car. As the battery's SOC increases, the voltage on the display drops, indicating that the DC/DC converter is reducing its charge rate.
  12. Ozark Man
    Ozark Man Member
    173
    64
    Mississippi
    Four Touring
    I agree. I'm just going to keep doing what I'm doing and not worry about it.
    jerrymildred likes this.
  13. MichelleStone
    MichelleStone Senior Member
    549
    819
    Mariposa, CA
    I had to replace mine at just a little over three years old. I have a 2016 4 model.
  14. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    Same here. Had mine replaced a few months ago at around 3 to 3.5 years old. It got completely depleted twice over the past year due to lockdowns and not being used for a couple of weeks at a time and then only used for a few minutes, again and again. After a cold spell (-16C / 3F), at the start of the year, it would deplete in only a couple of days to the point of being unable to unlock the doors or go into Ready mode.
    To my surprise, it was replaced free, under warranty, after a compulsory overnight discharge test.
    In my experience, every lead acid battery I've ever owned has shown significant performance degradation after around 3 years. By that I mean that I notice it... Dimmer than normal interior light, dimming lights while starting, slow starter motor, etc. I've always had to replace the battery, in every car, at some point between 3 and 4 years, with the exception of an AGM style battery that lasted an extra year.
    The Prius 12V battery is tiny, because it doesn't need to be able to turn a starter motor. However, that does mean that things like the alarm will drain it more quickly when compared to other vehicles. I suspect lockdown hurt a lot of Prius batteries, more than other cars, because they were more likely to run low during that period. Discharging a lead acid battery too low takes months of its life every time it happens.
    SM-T813 ?
  15. Ozark Man
    Ozark Man Member
    173
    64
    Mississippi
    Four Touring
    Like I said this seems to be more usual in the gen 4's. Or it could be because the older ones have already passed their 3 year mark some time ago and been replaced. But I don't remember reading much about this subject in the older posts either.
    That could have been the reason why mine was replaced by the previous owner. My Mazda that I traded in was on it's 5th year and still going strong, even in winter. Toyota must know there is some kind of problem, though, by them replacing yours free. That should only be within the first two years I think. Of course it could different in U. K.
    #15 Ozark Man, Jun 2, 2021
  16. alanclarkeau
    7,045
    7,593
    It very much depends on the car I think. I had a Mitsubishi Starwagon (Delica) with the battery under the driver's seat near the engine - and it was always hot there - and I didn't get much over 2 yrs. In contrast, the VW Aircooled Microbus - the intake air for the cooling and induction flowed over the battery - and they lasted a long time - I had well over 6 years from one. And the VOLVO 240 series, the battery had a big intake vent just in front of the battery - I had mine for 4 years, and the battery wasn't new when I got it.
  17. RGeB
    RGeB Member
    119
    Australia
    Thanks alanclarkeau! Is that from New Car Features, or could you give a reference to the document?
    Do you know of anywhere that Toyota details how (ie the algorithms by which) specific 'battery condition' and 'electric load' parameters are used to calculate the voltage requested from the DC-DC converter?
  18. Graz
    Graz Member
    179
    28
    I have an '05 with 230k miles. I've put 5 yellow tops in her.
    Via Prius Chat for Android
    kenoarto likes this.
  19. alanclarkeau
    7,045
    7,593
    It's only headed by "Features" - but the name of the file is NCF... I'm not sure where you'd get a hold of it.
    I "acquired" my copy - but it's ¼gb in size.
  20. Tideland Prius
    16,680
    https://techinfo.toyota.com. The 2-day subscription is US$20 and you can download whatever you wish for that 48 hours.
    alanclarkeau likes this.
