12 volt battery failing to start the car
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Louis19, Sep 27, 2023.
  1. Approximate Pseudonym
    106
    55
    Colorado
    2024 Prius Prime
    XSE Premium
    2024-03-22 1230 miles
    New battery may have fixed the problem. Maybe? It’s hard to tell, since I haven’t had any issues in over a week. Except for a couple of longer drives, the car has been driven too regularly for it to drain. However, my first 12v battery was failing under fairly regular use, and plenty of battery maintenance precautions taken before failures even started, so I have some justified paranoia about the car.
    I bought a Noco Genius 10 battery maintainer to check charge, and to save me from having to jump start my car. It’s something that will benefit me anyway since I can keep my battery in good health, but I had to rush getting one because I don’t want to be in the dark if the problem reoccurs. I am not exactly the target market for needing a battery maintainer since this household only has one car and it’s a near-daily driver, but it will be cheap insurance anyway.
    #181 Approximate Pseudonym, Mar 22, 2024
    GcinFl and RandyPete like this.
  2. RandyPete
    RandyPete Active Member
    403
    167
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    That appears to be a 10A battery maintainer. Is the 10A rating the best size for maintining the 2024 PP battery ?
  3. Approximate Pseudonym
    106
    55
    Colorado
    2024 Prius Prime
    XSE Premium
    I don’t know for sure. My understanding is that the main difference between the Noco models is the amp rating, but it’s still only trickle-charging the 12v battery and not doing anything harmful to the battery. My reason for getting the 10 amp charger is to reduce charging time, should I actually need to recharge a battery from a low state. In maintenance mode, it should function the same as lower amp models, unless I am mistaken?
    My thinking is that the 2 or 5 amp models will be less useful to me on a road trip (if I decide to take it with me), while the 10 amp model could be really helpful at a destination with AC power, and will avoid needing a jump start in some cases. An overnight charge is also extremely convenient for home use, since I don’t prefer to leave it plugged in all the time unless I am not using the car for an extended period.
    If anyone wants to weigh in and let us know about appropriate specs for Noco chargers, feel free.
  4. onthesalt
    onthesalt New Member
    17
    seattle, wa
    2024 Prius Prime
    XSE Premium
  5. SlovenePharmD BCPS
    SlovenePharmD BCPS New Member
    Knoxville, TN
    2024 Prius Prime
    XSE Premium
    I thought the battery warning light was for the traction battery?
  6. SlovenePharmD BCPS
    Knoxville, TN
    2024 Prius Prime
    XSE Premium
  7. Gokhan
    Gokhan Senior Member
    6,197
    2,452
    Paramount CA
  8. Trollbait
    12,534
    Cars these days have protection circuits for the 12V with a warning light.
    Problems with the traction battery would trigger the warnings for the hybrid system.
  9. Gokhan
    6,197
    2,452
    Paramount CA
    The low-battery warning, which is not a light but a written message on the display, is for the 3-V lithium-metal coin cell for the smart-key fob—not for the 12-V battery. There is no low-battery warning for the 12-V battery.
    In conventional cars, the battery-warning lamp only lights when the alternator is broken. There is no alternator in Prius, and the battery is charged by the DC–DC converter. It turns out that there is a warning lamp [​IMG] for the DC–DC converter having been broken. It is accompanied by a message basically saying that the charging system has failed and the car should be towed to the dealer. This is apparently not what they saw.
