12 volt battery failing to start the car
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Louis19, Sep 27, 2023.
  1. Trollbait
    12,534
    The 30 day operation was for Canada and Alaska, though it wouldn't be surprising if there was a way to turn that on for cars outside those markets. You can get a North American i3 REx working like the European one after all.
  2. Gokhan
    Gokhan Senior Member
    6,197
    2,452
    Paramount CA
    A/C charger does not charge the 12-V battery. 12-V battery will only charge when the car is in the READY mode.
    I left the car undriven for over six weeks in warm weather and there were no issues with the 12-V battery.
    Do not leave the A/C charger plugged in when the car is not driven for more than a day, as the vehicle systems could drain the 12-V battery.
    #42 Gokhan, Oct 20, 2023
    Bill Norton likes this.
  3. Mr.Vanvandenburg
    1,352
    571
    2020 Prius Prime
    #43 Mr.Vanvandenburg, Oct 20, 2023
  4. Mr.Vanvandenburg
    1,352
    571
    2020 Prius Prime
    Is this the twilight zone?
  5. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    What page of the manual is that noted on?
  6. Gokhan
    6,197
    2,452
    Paramount CA
    What are you talking about?
  7. Gokhan
    6,197
    2,452
    Paramount CA
    This was reported by many owners here. When the charger is connected, the electronic systems operate, checking the status of the cable, which drains the 12-V battery.
    On page 123, it instructs not to leave the cable connected for a long time—probably because it drains the 12-V battery as the owners here experienced.
  8. Louis19
    Louis19 Active Member
    392
    369
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Wait a minute ;)
    if you read the post , it was intended to newcomer in the Hybrid and Phev from an ICE only era . The car can sit longer than a few weeks in optimal conditions . Quite a few,on this board babysit ,when gone on vacation .All I am saying is that the 12V battery is much smaller in capacity and does not endure a great deal of abuse ( listening the radio in ACC mode )
    as for the manual , if the 12V battery is left in a low state of charge , here is what the manual states. Capture d’écran 2023-10-20 155527.png
    #48 Louis19, Oct 20, 2023
  9. bisco
    51,910
    It depends upon the health of the battery.
    The older and weaker, the less time it can sit without being driven, or maintained.
    this is true for all modern cars but more so for Prius because of the small battery.
    prime was notorious for dead batteries in the early years, and the amount of drain when off was documented and charted by @Salamander_King and others in a thread here.
    I can’t say about the newer or gen 5, but this is a thread about dying 12volts
    Louis19 likes this.
  10. Gokhan
    6,197
    2,452
    Paramount CA
    If you poorly operate your carusing the ACC mode, sitting in the car with the lights on and car not in the READY mode, only doing short trips, leaving the AC-charger cable plugged, etc.—of course the battery is going to drain in no time.
    As I said, I left the car undriven for more than six weeks, and there were no issues whatsoever. I am pretty sure that there would be no issues if I left it undriven for six months. That is because I know what I am doing and keep the 12-V battery at 100% SOC at all times when the car is driven.
    #50 Gokhan, Oct 20, 2023
  11. bisco
    51,910
    well, it's certainly good that one person here knows what they're doing
  12. Gokhan
    6,197
    2,452
    Paramount CA
    It is certainly good that one person here who didn't even ever own a Prius Prime knows all about it. ;)
    You keep bringing up the few threads about some Gen 4 12-V battery failures here; yet, you ignore the fact that 99% of us Gen 4 Prius Prime owners have had no problem with their 12-V batteries whatsoever.
    #52 Gokhan, Oct 20, 2023
  13. bisco
    51,910
    i never mentioned percentages, and have no idea what they are.
    like all things priuschat, we can only see what is reported here, and what happens 'out there' is impossible to know.
  14. Gokhan
    6,197
    2,452
    Paramount CA
    No, we can also see our own cars in action. That's why you should let the actual Prius Prime owners share their experiences rather than endlessly speculating merely based on a couple of anecdotal threads.
    I just looked at the Consumer Reports reliability surveys, and Gen 4 Prius Prime PHEV actually had fewer electrical problems (including the 12-V battery) than Gen 4 Prius HEV. Gen 3 Prius HEV is worse than Gen 4 Prius Prime PHEV as well. This confirms my thought that the few 12-V battery failures reported here were likely caused by owner neglect than anything else.
  15. bisco
    51,910
    your car is one data point.
    what does the cr report say about the 12v?
  16. Gokhan
    6,197
    2,452
    Paramount CA
    As I said, the electrical problems reported include the 12-V battery problems.
  17. Mr.Vanvandenburg
    1,352
    571
    2020 Prius Prime
    Are you hearing something or someone? Like familiar voices? I read something in the 2023 manual about what you wrote about, that the battery discharges more, but not how much more, and it’s due to checking. That was quite a bit of time to find it. I don’t know what its checking, but since the power is off it must use the 12 v to check? Maybe I just imagine I read it at this point.
    I always assumed the 12 v was charging during charging, no wonder mine runs down so much. So if it isn’t charging during charging I guess it still is checking.
    That’s for the 2023.
    I know we often say talking when referring to writing. Just a joke.
  18. Gokhan
    6,197
    2,452
    Paramount CA
    I thought you were since you mentioned the twilight zone. ;)
    Gen 5's PHEV-charging and 12-V system should be more or less the same as Gen 4's.
    • 12-V battery only charges when the car is in the READY mode.
    • PHEV battery only charges when the car is not in the READY mode.
    • AC charger does not charge the 12-V battery.
    • 12-V battery operates the charging system when the car is plugged in; so, that will slowly drain the 12-V battery, even when the car is not actively charging. I don't know the details though—perhaps the new-car features manual explains it.
    From page 80:
    ■If the vehicle is not used for a
    long time
    ●The 12-volt battery may discharge.
    In this event, charge the
    12-volt battery. (P.589)
    In order to prevent the hybrid battery
    (traction battery) from becoming
    extremely low in charge,
    charge the hybrid battery (traction
    battery) from external power
    source or start the hybrid system
    at least once every 2 or 3 months,
    and turn the power switch off after
    the gasoline engine has stopped
    automatically. (If the gasoline
    engine does not start up even
    after approximately 10 seconds
    have passed since the “READY”
    indicator came on, the power
    switch can be turned to off without
    any further action.)
    When the 12-volt battery is discharged,
    refer to P.589, “If the 12-
    volt battery is discharged” and
    perform the correction procedure.
    ●When the vehicle is left with the
    AC charging cable connected, the
    electricity consumption amount of
    the 12-volt battery increases due
    to controls, such as the system
    checking, operating. When the AC
    charging cable is not needed,
    remove it from the vehicle.
    #58 Gokhan, Oct 20, 2023
  19. Bill Norton
    Bill Norton Senior Member
    2,152
    734
    MONW, Ks.
    Is this clearly stated in the Owner's Manual?
    If you 'don't know what your doing' , how does one not get 'the 12V to 100% SOC when driven'?
  20. Bill Norton
    2,152
    734
    MONW, Ks.
    To me this is an unexceptable way to design a PHEV, or a BEV.
    If the car is plugged into a power source, I see no reason to drain the 12V by asking it for power, while the HV Battery is getting power from the grid.
    And then it asks you to walk out to the car and "unplug it when not needed"....
    You're supposed to go the the car after 'Charge Complete'???
    What about the Thermal Management System when it's 0° or 110° F? Does the car heat or cool the HV pack as required?
    What does the Prime have for TMS?
    Is there any other PHEV or BEV that lets the 12V battery drain all the way to failure, even if it's plugged in?
    Good grief, will toyota's BEV's have this same problem?:(
