12 volt battery failing to start the car
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Louis19, Sep 27, 2023.
  1. Gokhan
    Gokhan Senior Member
    6,197
    2,452
    Paramount CA
    You must have missed my post where I posted an excerpt from the owner's manual.
    ●When the vehicle is left with the
    AC charging cable connected, the
    electricity consumption amount of
    the 12-volt battery increases due
    to controls, such as the system
    checking, operating. When the AC
    charging cable is not needed,
    remove it from the vehicle.
    The AC-charging cable must be disconnected when charging is complete; otherwise, it will drain the 12-V battery as the owner's manual explains.
    How are you going to plug in a cable to heat/cool the lithium-ion battery if you park on the street or in a parking lot if some OEM had provided such a feature?
  2. Hammersmith
    Hammersmith Senior Member
    2,315
    2,341
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    You haven't thoroughly read pages 108-110 of the manual. There's some ambiguity as to whether the standard battery heating function is continuous with the AC cord attached, but there's no ambiguity about the Alaska/Canada battery heating function. While the cord is attached, the car will use the traction battery to power the warming system to keep the battery above a certain temp. Once the traction battery is depleted to a certain point, charging will automatically resume to recharge it. This system will continue to cycle for up to 31 days before turning itself off. It does not say exactly what temps trigger the system to operate, but another source said the car might not be able to start below -20(I don't know if F or C), so it's likely something above that.
    As for the standard battery heating function(non Alaska/Canada), it could be read that it only functions to prep the battery for charging, or it could be read that it does the same thing as the above system. What is clear is that it only operates for 3 days before shutting itself off.
    I think this is a case where you're both right. Leaving the AC cord plugged in can indeed slowly drain your 12V. But leaving it plugged in can also keep your car at a safe operating temp in extremely cold climates. If you live in one of those climates, you just have to balance your needs and maybe install a trickle charger that's easy to plug in to keep your 12V batt topped off.
    mountaineer and Gokhan like this.
  3. Mr.Vanvandenburg
    1,352
    571
    2020 Prius Prime
    The 12 v drains with or without the cable attached. The question I have is how much more in amps does the 12 v drain with the cable versus no cable. Writing without numbers goes on forever. Have the number, all done, know what is going on.
  4. Gokhan
    6,197
    2,452
    Paramount CA
    In Southern California, I don't need to worry about battery heating.
    That said, this feature only seems to be there to heat the battery before charging—not to heat it during storage. It is connected to scheduled charge. In fact, it stops for good after three days. Therefore, I don't see any point in leaving the cable plugged in for storage, hoping that it will heat the battery.
  5. Gokhan
    6,197
    2,452
    Paramount CA
    You can perhaps find out. Nevertheless, I don't need to, as Toyota recommends unplugging the cable when charging is finished to preserve the 12-V battery charge. Even a small amount of drain is too much drain for my purposes. I even changed the default auto-off setting for the lights so that they go off as soon as I open the door and do not drain the 12-V battery.
    #85 Gokhan, Oct 22, 2023
  6. Louis19
    Louis19 Active Member
    392
    369
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    I can speak of battery heating on Canadian models since I have one, and live in a region where cold snaps hit occasionnally during winter.Typical temps during these events ranges bettween -17 degC on days and -30 degC on nights.So my battery heater function is set to ON and the car is plugged . So once the car is fully charged, I leave the car plugged .After a few hours of sitting there fully charged, the temperature dips and when the traction battery dips close to freezing ......the brick turns on .....you hear a slight buzzing sound under the hood........ charging the 12 V battery ...very logical because the heater circuits are powered by the 12V circuit and the car needs to keep that small battery charged to warm up the traction battery. This is why the onboard charger has a dc to dc converter. When the battery temp reaches approx 5degC ...the brick turns off.This will cycle automatically when needed.
    So yes, when the battery heater function is activated , leaving the car plugged in very cold temp will keep the 12V battery and the traction battery happy up to 31 days .I leave my car plugged in polar temp .....and start the car without any problem.In winter,when a cold snap occurs, I usually use the car every 2 days.
    @Hammersmith You are right on Canadian models , but I agree that there is some ambiguity in the text probably a lousy Japaneese to English translation.
    As i understand it ,the heater function monitors the traction battery temperature and triggers the EVSE (the brick) when needed , if the heater function is enabled and the car is plugged in.Keep in mind that the heater circuit is powered by the 12V battery hense the need to plug the car to provide power to the onboard charger . The onboard charger has it's own DC to DC converter to supply 12 volt power to the heater and keep the 12V battery charged.The traction battery is completely disconnected when the car is off so it does not contribute to heat the battery. This special mode is active for 3 days for US models and 31 days for canadian and alaska models.
    I do not know if this applies for Gen 5 prime
    #86 Louis19, Oct 22, 2023
    mountaineer, bisco and Gokhan like this.
  7. Hammersmith
    2,315
    2,341
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Confirmed via TIS that the battery management system continues to keep the battery above a target temp for up to three days if left plugged in and the option is enabled in the settings(31 days for Canada/Alaska).
    The exception is if start-stop charging mode has been selected. In that case, it will warm up the HV battery so it's ready to be driven at the scheduled stop time. Once that time has passed, the heater will shut off and not reactivate. (does not apply in Canada/Alaska below certain temps)
    TIS is also clear that the heating mode is so the car can run in EV mode from the very start of the drive and does not have to do with prepping the battery for charging.
  8. Gokhan
    6,197
    2,452
    Paramount CA
    Where/how in TIS?
    Interestingly, according to NCF in TIS, battery starts charging regardless of how cold it is, which brings the usefulness of the battery heater into question.
  9. Bill Norton
    Bill Norton Senior Member
    2,152
    734
    MONW, Ks.
    Where did you come up with this theory?
    I realize you are new to Li-ion batteries.
    They have very little 'Self-Discharge' and when the power contactor is open there is no drain at all on the pack.
    Also, Li-ion always have a 'Low Voltage Cut-Off'. The can't discharge to a bricked state, (well maybe in years of storage, possibly.)
    And, if it somehow one got to the Low Volt Cut-Off' it would just need a bit of HV charging to get it back online.
    What about when it gets above 100°F (and since the pack is in the cabin of the car it most likely is much hotter than ambient temps)?
    Should you worry about Cooling the pack. (n)
    Again: What does the Prime have for TMS?
    (I guess I could do my own research, but "Frankly my dear......")
    A Li-ion pack should be in the happy temp range for charging ,and most importantly, while be driven.
    All quality PHEV and BEV have a TMS to
    Heat and Cool the pack as required.
    Are you now questioning why any of the cars with Li-Ion batteries need a TMS?:whistle:
  10. Mr.Vanvandenburg
    1,352
    571
    2020 Prius Prime
    I will eventually , but have no need to as I never leave the cable plugged in as I always am charging at free places. It’s just your words, “otherwise, it will drain the 12-V battery as the owner's manual explains.” The manual says more drain than disconnected, not all. How much more. My car drains the 12 v pretty fast all disconnected, and I have had two of the same year cars.
  11. Trollbait
    12,534
    Li-ion cells below 0C will be damaged if charged at normal rates. The PiP charged at a very low rate until the pack got over that temperature. Everything else has some type of external heating.
    So, how warm does the Prime's battery get from the heater alone? Can it get a pack at sub freezing temperatures to room temps, or just above the damage threshold, and let the charging process heat the battery up more?
    Louis19 likes this.
  12. Louis19
    392
    369
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    According to prof John Kelly from Weber State University , the prime (2017-2022)heater turns on at 36 degree F and turns off at 43degree F
    if activated and plugged in .There are 2 heater circuits if the 2 are required it's total power is a bit under 200 W
    #92 Louis19, Oct 23, 2023
    Gokhan likes this.
  13. Hammersmith
    2,315
    2,341
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Sorry, I could have been a little clearer. The battery is indeed warmed up prior to/during charging, but that's just part of the standard charging routine. There's also a specific 'battery heating' function in the settings that is solely to get/keep the battery up to temp so you have access to full torque from the HV battery immediately upon starting the car. Both systems use the same heating elements under the battery cells. I'd give exact temps for each function, but they weren't listed in the TIS section where those functions were described.
  14. Trollbait
    12,534
    That's just above freezer settings to refrigerator levels.
  15. Hammersmith
    2,315
    2,341
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    New Car Features -> Engine / Hybrid System -> Hybrid Battery Control -> Plug-in Charge Control System -> Plug-in Charge Control
    They even show graphs of the temps over time so there's no way to misinterpret how the system operates.
    Louis19 likes this.
  16. Gokhan
    6,197
    2,452
    Paramount CA
    If your car is draining the 12-V battery fast with all disconnected, there is definitely something wrong. As I said, I left mine for over six weeks, which is a significant length of time, with no issues.
    If the cable-plug-in drain weren't an issue, Toyota wouldn't explicitly mention it in the manual.
  17. Hammersmith
    2,315
    2,341
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Actually, just refrigerator levels. ;)
    Home refrigerator/freezers should be set to 40F/5C or a little below for the fridge and 0F/-18C or lower for the freezer.
    Sorry, food safety is a thing for me. :)
    Louis19 and Trollbait like this.
  18. Gokhan
    6,197
    2,452
    Paramount CA
    Yes, I have the NCF as I mentioned. I didn't notice the "31 days" you claimed, which is in the owner's manual but not in the NCF. I also pointed out that the battery starts charging regardless of the temperature.
    They did improve the figures in the 2023 NCF by adding the control "hysteresis," but it is otherwise identical to the Gen 4 NCF.
    #98 Gokhan, Oct 23, 2023
  19. Trollbait
    12,534
    Oops, got the F and C crossed for fridges there.
    Was once involved in a shelf life project for hot dogs where one set was stored at 10C for weeks. It got unpleasant at times.
    Louis19 likes this.
  20. Gokhan
    6,197
    2,452
    Paramount CA
    No, as I pointed, it is not. Look at the figures more carefully: The battery starts charging immediately regardless of the temperature, and there is no preheat before charging. Heating and charging start at the same time when the car is plugged in.
