12 Volt Battery Intermittently Dies
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Robert Vary, Jun 25, 2019.
  1. Robert Vary
    Robert Vary New Member
    Whiting, NJ
    I've had to jump start my 2012 Prius twice in the past 1 1/2 months. The first time was after it had been sitting for a couple weeks while we were on vacation. The second time was after a couple days of heavy rain. I don't know if these events had anything to do with it. I've hooked up a charger and the meter has been indicating that the battery is holding a charge.
    What could cause the drainage? Is the battery starting to die? As far as I know it's the original battery.
  2. alanwagen
    alanwagen Member
    122
    79
    FORT WORTH
    2018 Prius
    You have to "load" test your battery. If it IS the original battery, yes, you need to replace it. Usual life is only 5 years. You got 7 so that is pretty good.
    Grit, Pluggo and tankyuong like this.
    52,822
    welcome!
    you would have to measure the drain with the car off and compare to toyota spec in the repair manual.
    if you're keeping the car, replace the battery and go from there. hopefully, that solves it. once you drain these little batteries, they don't recover well.
    Grit likes this.
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Regular wear and tear not able to hold stable charge NE more. 12v bat will typically last 5 years, yours is original and got 7 years out of it, great run. I’d shop around now for best price with some time left to spare if it’s my bat.
  5. Mendel Leisk
    42,323
    What's the charger?
    Yeah concur with others: Appreciate that batteries are expendables, and they gradually deteriorate, with years and abuse.
    Read up a bit, lots of 12 volt info.
