12 volt battery question
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by CanyonKid, Feb 2, 2015.
  1. CanyonKid
    CanyonKid Junior Member
    31
    I made a business trip from LA to NYC 2 months ago, 6 days, when I got back to my 2010 Prius in the parking lot at 1am, in the rain, totally dead, no lights, no nothing (nothing left turned on), so had to call AAA and get a jump, no problem, car running fine ever since.
    But now, I have to make the same trip, except it's 16 days this time...I don't want to be in the same predicament again. If I leave the car home, and ask a neighbor to start the car every couple of days, will it stay charged?
    Optionally, thinking about getting replacement battery from elearnaid.com, my battery is 5 years old anyway, but would this battery stay charged for 16 days??
    Thanks in advance,
    Mike
  2. Mendel Leisk
    38,873
    After any event like that you really should hook the battery up to a smart charger, completely recharge it, and subsequently monitor it's voltage with a digital multimeter. It's likely "running on empty" now, but until you get proactive about monitoring it you don't really know.
    Yeah, at this point I'd ask your neighbour to drive it, say every 4 days. And they should really use it, say run an errand or two, each time.
  3. mikefocke
    3,719
    1,662
    Sanford, NC
    After 5 years with the original battery and after a total discharge, I'd replace it. Easier and cheaper to replace with a quality battery when it isn't dark, raining, not convenient, etc.
    But I'd also look for something drawing current. A bad switch or some lights or anything plugged into the car that wasn't OEM.
  4. CanyonKid
    31
    The GPS is always plugged in but turns itself off when I park. Could it draw current like that? Everything else is OEM and when I got jumped at the airport before, no lights or anything came on when the power came back.
  5. GregP507
    GregP507 Senior Member
    3,002
    480
    Two things are working against you. First, the battery going flat and being boosted has probably damaged it to some degree, a situation made worse by the age of the battery. If it's going dead more easily than you expect, it could be discharging internally (a situation which could have been made worse by it going dead) or you could have parasitic drain from accessories.
    It would be nice if the Prius used a deep-cycle battery, and it would also be nice if it had some sort of low-battery cutout protection, but I've already added those things to the wish-list for the Prius in this forum.
    I'm reasonably sure that the power socket supplying your GPS also shuts off when the car is turned off.
    #5 GregP507, Feb 2, 2015
  6. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    It would be MUCH better to get a battery tender type small automatic charger and leave it plugged in while you are gone.
    Just firing up the car takes a certain amount of current from the battery; then the car has to stay in the "run" mode for a while to replenish that......plus the vampire and self-discharge drain over X days. To break even, it might take 15 minutes.
    Regardless, I agree that a new battery is going to be needed soon.
  7. Mendel Leisk
    38,873
    If he's parked at the airport though, for 16 days, likely the kiss of death this time.
    CanyonKid likes this.
  8. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    Don't waste any time trying to charge the thing, it needs a new 12v battery, and soon.
  9. bisco
    49,693
    get an oem, they're the best bet right now. 2010 are notorious for bad batteries. i leave my car every winter for 5 weeks, no problem.
  10. Sierra Mark
    Sierra Mark Junior Member
    30
    Mission Viejo, CA
    Your battery is well past its prime. Same some $ and get a new battery from elearnaid.com and make sure its fully charged before installing. The 16 day trip should be no problem. Battery tender in an airport parking lot. How does that work?
  11. Mendel Leisk
    38,873
    It doesn't. Take a cab or have a friend drive the car back.
  12. GregP507
    3,002
    480
    If I were leaving my Prius parked for 16 days anywhere without the battery on a charger, I'd worry about it the whole time I was away.
    Last summer I had my Corolla parked for a few weeks before I sold it. The brake discs had rusted so badly they had to be replaced, and the battery was so dead, it couldn't take a charge. It cost me over $500, just for not not driving it for a few weeks.
    #12 GregP507, Feb 3, 2015
  13. CanyonKid
    31
    Battery tender would be great, but I have to park at the curb at my house, a long cord coming out of my garage-turned-recording-studio 20 feet up the sidewalk probably won't work ;-)
  14. CanyonKid
    31
    Checking with elearnaid this morning as to whether a new battery from them can go 16 days just sitting. Lucky for me they're a straight shot west on the 210 Freeway, so can buy and get it installed right away.
  15. GregP507
    3,002
    480
    I guess it goes without saying that that batteries nowadays can go flat when left idle for awhile, and when that happens, they can be damaged beyond repair.
  16. CanyonKid
    31
    Since a battery tender is unfortunately out of the question,
    When you say you "leave your car" do you mean just parked, no battery tender or anything?
  17. Mendel Leisk
    38,873
    Besides killing batteries, how are parking rates at your airport, they aren't prohibitive? Up here it's ridiculous; there's an alternative parking with shuttle bus INDUSTRY, people get friends to drive them to the airport, babysit their cars and so on.
  18. CanyonKid
    31
    Yeh, even at a distant car park 16 days will be really expensive, probably take an airport shuttle, although both ways on a shuttle will be about the same price, at least I won't have to take 3 extra buses just to get to the terminal after parking.
    LAX is a total nightmare, I fly out of Burbank now every time, unless going to Europe, even though it means a stop somewhere along the way, still better than the 3 hour trip going to LAX requires. And I just live in Pasadena, not some far away town.
    The trouble with the "friend" scenario is, the only guy I would trust is going with me, he's the guitar player ;)
  19. bisco
    49,693
    yes, i park in an unheated attached garage. shut it off and walk away. my 04 battery lasted 8 years, my 08 battery is still good, but in those cases, i only had them 4 years and gave them to my kids. i contend that the oem batteries are fine, as long as you never drain them. but 2010 was a bad year because cars sat on the lot for awhile, and dealers didn't know you had to keep them charged.
  20. GregP507
    3,002
    480
    It's convenient, especially when your employer pays the expense. The parking compounds are also more secure, with good lighting, closed-circuit cameras and security staff. They should be offering an outlet option for each stall, for block-heaters, battery-tenders and plug-in electric vehicles.
