12 volt battery well rusted out- Houston, we've got a problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by priusrust, Feb 10, 2018.
  1. valde3
    valde3 Senior Member
    2,002
    749
    Finland
    But you do life in Florida. They don’t salt the roads there. Salt spray can easily remove grease/oil from undercarriage and then cause rust.
    Of course if it rusts from inside out then almost any rust prevention would have helped a lot. Rust from inside out would have been caused by leaked water or battery acid. Even AGM batteries can (slowly) leak acid I have seen that happen.
    priusrust likes this.
  2. priusrust
    priusrust Member
    205
    74
    MA
    Yes! ...you are right. Mudguards, not mudflaps. Mine are missing....so salty winter tire spray coats battery well. You'd think with all the alleged 729 point checks during oil changes it might have been mentioned. Thanks!
    edthefox5 likes this.
  3. priusrust
    priusrust Member
    205
    74
    MA
    Ya, salt on roads greatly accelerates rust process....and undissolved salt can strip undercoating as it kicks up and peppers undercarriage- sort of a slow "sand-blasting".
    I tended to dismiss battery acid being culprit because no sign of leakage showed on battery, but it does look like that is what did it.....like bottom of pan just dissolved. But since I now know my mudguard is missing- I think that is likely cause....
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Doing something can’t hurt. But what happens with the grease is it creates a road grime that’s greasy
    And very protective.
    That I’ll protect th metal somewhat even in winter. It looks horrible but all you need to do is wipe it off and metal brand new underneath.
    Better than nothing. Modern metal is crap. It rusts instantly if it’s sqeeky clean. Scrub it clean it will have a rust patina on it in days.
    This CSP is designed to stick on to metal. It’s called CORROSION STOP.
  5. Mendel Leisk
    41,488
    Mud flaps? My 2 cents, they are mostly ornamental, actually promote corrosion, since they tend to catch-and-hold crud. They likely were optional, not missing. I too would suspect a leak above, that the battery well was a chronic swimming pool.
    priusrust and edthefox5 like this.
  6. edthefox5
    10,096
    4,833
    Clearwater, Florida
    That’s because there is no checks. That’s all horse poop. Your not getting a SAE mechanic changing your oil your car goes in the back where all the crappy filthy Dino oil vats are and it’s changed by monkeys.
    And it’s usually horribly over filled. And never checked before dumping it to see what it looks like and how low it is. Your car could be and very well may be a oil eating monster. You’ll never know.
    Oil change is a loss leader for them. They just want foot traffic so you can oogle new cars and expose you too non stop up sell
    If yyour getting oil changes at the dealer that usually means your not checking anything in the engine compartment especially the oil. Why would you it’s dealer maintained whoop eee.
    Do me a favor go out and check the oil in your car before starting it. I bet it’s really low.
  7. priusrust
    priusrust Member
    205
    74
    MA
    Not flaps- my mistake ...mudguards. [see above] and these are certainly not ornamental. I would think leak from above- but checked it in rain- looked ok. Leaky battery acid theory seems possible to me.
  8. priusrust
    priusrust Member
    205
    74
    MA
    It wouldn't start. Probably because I could not attach battery because well is rusted out. :~) I check my oil- never uses any. Keep in mind this 2004 only has 105K miles. My dads car....drove it sparingly. He bought a new Prius- claims 75 mpg.
    I agree dealers just want foot traffic from oil changes. Last oil change they suggested I give them $500 because the rotors were rusty. (brakes work fine)
    When I brought in the rusted battery clamp still bolted to a rusty chunk of the actual Prius body...(see original pic) ...I imagine that was foot traffic they were not too thrilled about. I should have paraded it through the showroom (maybe they might have given me a new Prius Prime w/ solar panels to go away?)...but I'm not quite that diabolical.
  9. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Lol good one...
  10. priusrust
    priusrust Member
    205
    74
    MA
    Thinking of scrapping plan A because I need my car. They tow during snow storm so next snow I get hit
    Plan A may be scrapped, and I may go with Edthefox5 suggested tire well plan....for the time being. Winter just too hard to execute this. Besides, I get towed if I don't move car when snow storm hits.....
    Plan A scrapped because rust more extensive on side towards tire well...camera did not show.
    Plan C just emerged***: tape syran wrap to sides of well... Fill with insulation foam.... take hardened foam out....bring to sheet metal fabricator.........have him replicate (slightly shrunk) with lip over edge to rivet. It would be along the idea of those plastic inserts you get for the pans when you roll on paint- only sheet metal.
    hhmmm
    edthefox5 and Mendel Leisk like this.
  11. edthefox5
    10,096
    4,833
    Clearwater, Florida
    yeah I keep forgetting how brutal the winter has been up there this year. We have friends in Raymond NH and they text every few weeks with weather reports. Lots of 9's and 7's and 10 degree F. You cant stay outside working on a car very long in that.
    Good luck with the rebuild.
    Raytheeagle and priusrust like this.
  12. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    Getting a battery pan from a junkyard not feasible?
  13. edthefox5
    10,096
    4,833
    Clearwater, Florida
    You could but it would have to hang on hangers cause there's no bottom for it to sit on and you still have to close up the bottom of the hole afterwards.
    Its a mess. Never seen this before.Its like the whole well had 2 inches of battery acid sitting in it for a long time. Freaky.
    I want to see pictures of the suspension because the car has seen some very corrosive stuff.
    priusrust and Raytheeagle like this.
  14. priusrust
    priusrust Member
    205
    74
    MA
    Man.....on top of everything, my city issued a snow parking ban tonight. I can only off road park, so they tow with no exceptions [$2-$300 total bill after hypothetical tow back] So.....considered hooking up new battery next to battery well, but no good- non of the cable hookups reach. So.....finally suspended new battery into battery well with 2 bungie cords attached from above. Good news is new battery works! [I was never 100% sure battery was the issue]
    As far as getting a battery pan from junk yard, I'd have to cut it out of the car- and it's more than just bottom: inside vertical wall (can't see in pic) is 2/3 rusted out. And size is an issue- I'd want it slightly shrunk to be able to jam into bottom of pan from above. I think I'll cardboard template the bottom (to fabricate sheet metal bottom), with some portion of vertical side flaps to rivet. I'll also have two steel straps sandwiched between...and attached to... sheet metal and battery clamp assembly -these will run up sides, riveted to sheet metal...and on inside edge, bend horizontally over edge of lip - and rivet there. These for added strength. Also- I will possibly suspend battery clamp/ cradle from above in some fashion to relieve some of the battery weight, and also provide a "fabrication malfunction firewall" just in case. I'm thrilled new battery works! Had old one tested- zero charge. [7 years old] Two pics are 1) the well with bottom gone (as posted before) and 2) after I wire-wheeled rust out, applied Ospho to chemically neutralize rust, cleaned, and painted with gray Rustoleum.
  15. bisco
    51,975
    looking good!(y)
  16. ChapmanF
    18,243
    Since I keep misreading the title of your thread anyway, I might as well say it:
    By golly, that really is well rusted out!
    -Chap
  17. Mendel Leisk
    41,488
    To quote Popeye: All's well that ends in a well. :)
  18. priusrust
    priusrust Member
    205
    74
    MA
    So....a year and a half later....was having tires replaced [Atlas Force- highly recommend! $44 and quality rated by Consumer reports with $100-$150 tires -get em thru Walmart] and seeing my battery suspended on its bungee cord swing above the speeding road below reminded me to finish battery well repair. Latest plan. make a cardboard mock up of bottom of battery well, and have a sheet metal place fabricate a pan to rivet on (with a couple of supportive metal straps) The other pic is of rust. I have to deal with this. Once I figure out how to prop car up (dig a center trench?) I'll wire wheel out loose rust......wipe clean with alc rag......apply Ospho.....paint black rustoleum.....than apply the CRC lube from home depot.
  19. bisco
    51,975
    wow, i thought you were done! :cool:
  20. priusrust
    priusrust Member
    205
    74
    MA
    Constructed the mockup of battery well correcting catastrophe. The two metal straps are rthe supportive key. (real ones will be unyielding/ substantial) . The sheet metal (cardboard in mockup) will replace missing prius metal on bottom of well and half of one side. I'll screw/ bolt all 4 ends of 2 metal straps in place- but that is just to hold them in place- not truly essential, as the last horizontal inch of all 4 metal straps/ bars will be resting/ supported on sold material. In other words, the weight of battery should keep it in place. That said, I'll screw/ bolt in place 4 ends of 2 bars.....likely rivet or screw vertical piece of sheet metal to still existing metal.
