12 volt battery... what am I missing?
Discussion in 'Gen 2 Prius Technical Discussion' started by Al Bundy, Oct 6, 2018.
Tags:
  1. Al Bundy
    Al Bundy Member
    140
    69
    florida
    My Optima yellow top is going on 3 years old and while its not giving me trouble yet I expect it soon and it got me thinking....
    If the 12 volt is used to turn on the computers and not start the car why does it cost $200 to replace and have a 4 or 500 cranking amp rating.
    If thats its only function realistically a $20 lawn tractor battery can get the car going and run the dash,radio ect ..
    maybe Im missing a lot of info but when did car batteries get so expensive?
    its recycled plastic, lead and some chemicals..not silver or gold
    my neighbor just dropped $400 on a caddy battery from autozone .. I dont think his car is worth much more that that..
  2. brdmb
    brdmb Junior Member
    17
    Ohio
    I have wondered the same thing myself. I know AGM is best to help prevent excessive gassing (the battery is inside the passenger compartment after all) but why for example wouldn't this battery work:
    Mighty Max Battery 12V 35AH SLA Battery John Deere Tractor Riding Mower brand product
    Built for vibration, AGM, SLA. It even mentions being used in medical equipment, which would have to have pretty stringent requirements on emissions.
  3. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    300-350 bucks for a 12v battery for my 2016 Prius. That is, if the dealer can even find one.
  4. George W
    George W Senior Member
    937
    520
    San Antonio
    If your Prius has a smart key system, there could a vampire voltage which would destroy a cheap 12 battery in no time.
    A $20 lawn tractor battery is designed for an instantaneous surge for starting, and not for sustained drain.
  5. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Prius camper uses a wheelchair battery in his car. I wonder how long his battery's last?
  6. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    When the ice is running the 12v is getting a small charge, and a non venting 12v is spewing noxious gas in the cabin, the OEM is tiny (not size) but it's a deep cell, meaning it can can be discharged then recharged in a cycle, unlike non deep cell.
    it's easy to leave a light on or a door open.
    it's OEM, the least expensive part placement possible, Toyota is very good at making a profit.
    if the 12v is poor, or dying, it's taking more of a charge than a health 12v that eventually tells the Prius that it's full, so eventually a poor 12v is going to make the ice run more.
    On the other hand, schlepping around a ten pound battery that spews whatever into the cabin beats schlepping around a 40 pound battery, except for the extra ice cycles.
  7. Skibob
    2,912
    1,505
    Northern California
    Typically batteries that are designed to be in the trunks of cars are both pressure sealed and vented. They only vent if the internal vapor pressure goes beyond a certain pressure. The vent tube assures the hydrogen gas gets vented out of the car. Any replacement battery should have those 2 safety devices.
  8. Al Bundy
    Al Bundy Member
    140
    69
    florida
    insanity.. it costs no more to make that batter than one for a mower
    Starship16 likes this.
  9. Al Bundy
    Al Bundy Member
    140
    69
    florida
    a 12 volt gel cell like on a handicap scooter dosent give off any fumes and its a deep cycle ... im sure someone has tried it..
  10. Al Bundy
    Al Bundy Member
    140
    69
    florida
    I guess that was a bad example, I should have said any 12 volt gel cell like on a medical scooter, they are deep cycle, dont give off fumes and are under $70
  11. bisco
    52,801
    likely an economy of scale thing. prius battery is unique, and just aren't enough prius needing replacements to bring the cost down.
    idk why the battery for your neighbors caddy battery was so high, but a normal car battery is around a hundred bucks.
  12. bisco
    52,801
    for instance, if you plug in a 2008 camry into the sears website, theres a ton of batteries for 70 bucks and up
  13. Starship16
    1,348
    1,455
    Beach Christmas
    I will miss those days....
    edthefox5 likes this.
  14. Starship16
    1,348
    1,455
    Beach Christmas
    My 12v is in the engine bay. And it sure looks like a regular ol' battery. Maybe just a bit smaller. I can't tell. Toyota is making a killing on those things. Hopefully it will last for 6 years, if I'm lucky?
  15. Skibob
    2,912
    1,505
    Northern California
    You do understand that this the Gen 2 forum for Prius built from 2004 to 2009 don’t you)
  16. Starship16
    1,348
    1,455
    Beach Christmas
    Doesn't matter, Skibob. Posters cross forums all the time. A Prius is a Prius is a Prius. Just the looks are different. A Disneyland car with a battery under the back seat. :LOL:
    "Can't we all just get along?"
    -- Rodney King
    #16 Starship16, Oct 7, 2018
  17. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    Ah, good point, on the gen2 the air that moves from the cabin to the traction battery for cooling and is then taken via duct directly to the 12vbattery where it has a way to the outside, it's rather efficient, while the gen3 moves air from the cabin to the traction battery then to the rear spare tire area then to the 12vbattery then to the outside, I prefer the gen2 method.
    Of course the gen4 put the 12v up front with the ice, in the boot.
  18. bisco
    52,801
    i've never had to replace a prius battery, so it's not much concern to me
  19. loudes13
    loudes13 Junior Member
    chicago
    My current car came with a yellowtop that the PO said was brand new. It's been discharged twice (my fault for leaving the smatkey on) and now reads bad battery on my charger. Since I don't have a receipt, the local Optima dealer wouldn't warranty it.
    I bought a new normal AGM from a local Interstate Store, but the terminals where on the wrong side and too big. I modified the terminals, but I expected more from the yellowtop. I don't know the age, but I bought the car 10 months ago.
    In my first 2004 Prius, I modified the clamps to use a $30 motorcycle battery. I think I got the idea here.
    Al Bundy likes this.
  20. Skibob
    2,912
    1,505
    Northern California
    So you can supply Zero help? Why you post?
