12 Volt Battery
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by andyprius, Apr 6, 2012.
  1. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    All good points except the thing about being locked in the car.
    Which brings me to repeat my custom of plugging in a permanently attached Battery Tender. That requires no disturbing of anything. When the light on it turns to green, the battery is fully charged. This is more than a test. It is assurance that the battery is in good health. They are not expensive and will add years to the life of this small battery.
  2. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    My Gen 3, not PIP, says 11.2v on service screen and measures 12.75v both at the battery and the jumper point under the bonnet, quite a difference.
  3. crewdog
    crewdog Acting Ensign Prius Prime
    492
    388
    Woodstock, GA
    On my GenII, I had 12 gauge wire and a set of Anderson PowerPole connectors wired permanently into the 12v aux battery.
    I used this primarily to power a 2m/70cm amateur band transceiver. If the 12v batt went out, which it did about 4 years in, i could easily use the powerpoles to connect to an Optima blue top marine battery in a plastic battery case and set off without waiting to charge. I also have a battery tender jr. rigged with power pole connectors that could use the same connection to maintain the 12v charge overnight.
  4. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    In the 7+ years I owned my 2005, I never once had a 12V battery problem. The car still has the original 12V battery and is still going strong.
  5. CharlesH
    2,797
    1,163
    Roseville, CA
    About two years ago the 12v battery in my 2002 Prius died.All sorts of very intimidating fault indicators on the MFD with lots of big exclamation points. I was having visions of a dead traction battery. The dealer replaced the 12v battery and reset the fault indicators, and everything has been fine since.
  6. Allannde
    874
    138
    Washington State
    Few short trips and no parasitic drain and we should be fine. But this is a weak spot and it is painful if the 12v battery fails. You are stuck. If you have an available 12v battery, a "jump" is simple. It doesn't need to be a large battery.
    But I have peace of mind with a Battery Tender available for an occasional charge. It is not hard or expensive. Any lead acid battery is happier if it is kept at a full charge.
  7. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Hello JBrad, since I now have a PIP I can verify that it is much easier to access the 12 V, I also accessed the 12 V post under the hood. After just buying the car and driving home, the SOC was 12.85 Volts, that is OK. JBrad: In regards to the above procedure, are you speaking of the PIP? I can find no info button on the display of the PIP. ? ? ? :D
  8. jbrad4
    jbrad4 Active Member
    474
    148
    Rowlett, TX
    By the way, SOC (State of Charge) is a Percent and applies to the Traction Battery.
    Maybe you have the Basic Trim PiP.
    Mine is the Advanced Trim PiP. Here is my INFO button:
  9. tomkessler
    tomkessler Junior Member
    28
    Campbell, CA
    I did some measurements and verified that the 12v battery charges while the pip is plugged in. So if you plug in daily you shouldn't need a battery tender
    I am here: http://tapatalk.com/map.php?5jc4sm
  10. Allannde
    874
    138
    Washington State
  11. tomkessler
    28
    Campbell, CA
    6 people like this.
  12. Allannde
    874
    138
    Washington State
  13. tomkessler
    28
    Campbell, CA
    I suspect that there is some drain from the smart key proximity features. Those would all be active if I am near the car with my keys. Next time I am experimenting I will hook things up and take the keys inside the house.
    I am here: http://tapatalk.com/map.php?icbn3b
  14. o2cool
    o2cool o2cool
    48
    Palo Alto, CA
    Anyone know how to do this on the PIP Base Model?
  15. andyprius
    2,212
    188
    My original question, before getting the Pip. Did Toyota deny the very simplistic diagnosis that Gen II and gen III had ? :mad:
  16. andyprius
    2,212
    188
    On the plus side the 12V is reading 12.9 Volt under the hood.:D
  17. andyprius
    2,212
    188
  18. CraigCSJ
    CraigCSJ Active Member
    287
    144
    San Bernardino, CA
    On my base model, I followed advance directions except instead of pushing INFO, I pushed the Audio button. Also, I only turned on the daylight running lights, not the headlights.
  19. andyprius
    2,212
    188
    Not totally clear, are you saying this worked ? :D
  20. andyprius
    2,212
    188
    Craig, you are a genius. I guess I will have to read the Advance potion of the Manual! For others: Put Pip in acces mode, do not step on brake, click lights on and off three times from DRL position.....and up will pop a page which shows various diagnostics and other somewhat useless information although if there is a problem, it may be valuable . What you are looking for is Vehicle signal check = 12. Something. I didn't bother with, but if you go to full power from there it will show full charging voltage= ~ 14 volts.
