12 Volt battery
Discussion in 'Prime Technical Discussion' started by Andyprius1, Nov 22, 2017.
  1. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Im looking for the procedure that shows the health of the 12 V Battery. Can this be done on the Prime?
    52,878
    was it available on the pip?
  3. Andyprius1
    2,327
    859
    Cool CA
    Absolutely.
    52,878
    how? i did not know that. would love to see how it compares to my volt meter.
  5. Andyprius1
    2,327
    859
    Cool CA
    Look it up on the threads for Pip
  6. Andyprius1
    2,327
    859
    Cool CA
    It was in the first year 2012
  7. bisco
    52,878
    will do, thanks. you know how that goes, i'd be better off asking the question in a new thread.:p
    priuscatprimeguy likes this.
  8. Andyprius1
    2,327
    859
    Cool CA
    I sort of think that since Gens 1/2 are being repaired and overhauled more now and that response may be timely. The procedure was similar to my 2005, but also slightly different.
  9. Andyprius1
    2,327
    859
    Cool CA
    Ask Patrick.
  10. Elektroingenieur
    2,515
    3,288
    Three Touring
    The Repair Manual (available by subscription to techinfo.toyota.com) has a battery inspection procedure, under Power Source/Network: 2ZR-FXE Battery/Charging: Charging System: On-Vehicle Inspection. It includes checks of the battery cables and terminals, electrolyte level, and terminal voltage, which should be 12.0 V or higher, with the power switch off, at 20 °C (68 °F), after operating the high beam headlights for 30 seconds to remove the surface charge from the battery.
    The Toyota Warranty Policy and Procedures Manual requires claims for defective 12-volt batteries, whether original equipment (Policy 4.10) or service parts (Policy 4.11), to be substantiated with a failed test result from the GR8 Battery Diagnostic Station (00002-MCGR8), Toyota’s version of the Midtronics GR8 diagnostic charger, or the handheld Digital Battery System Analyzer (00002-V8150).
    Or were you, perhaps, asking about the diagnostic mode of the Navigation Receiver Assembly (Entune head unit), which includes a readout of the auxiliary battery voltage? The methods to access this on the Prius Prime are the same as on the fourth-generation Prius, except for vehicles with the 11.6-inch display, on which the HOME switch, rather than the AUDIO switch, is used for Method 1.
  11. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Plug one of these into your 12v power port...then without pressing the brake pedal, push the Power button once to give the battery voltage with minimal current draw--should be above 12.0V. Press the power button again without brake pedal to show battery voltage with all car accessories on--should drop into the high 11.x volts. Finally, press power button with brake pedal depressed to put car in Ready mode, and now shows the recharging voltage--should be above 14.0 volts.
    #11 FuelMiser, Nov 26, 2017
  12. Mendel Leisk
    42,364
    Google "Solar BA5".
  13. Andyprius1
    2,327
    859
    Cool CA
    Thanks, Good idea.
  14. Andyprius1
    2,327
    859
    Cool CA
    Actually this was a video, done by Professor...……? using 3 multimeters
    showing 12V, Current in to 12V, and current consumption. He says this check can be used on any Prius . 2000 - 2017. This of course checks the Converter Output.
    I have looked in Prius Technical, but cannot now find it, anybody know?
  15. bisco
    52,878
    see post #10
