12 volt battery?
Discussion in 'Gen 5 Prius Main Forum' started by Robmoo, Nov 17, 2022.
  1. Hammersmith
    Hammersmith Senior Member
    2,487
    2,546
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    That's the back side of the center console. A few of the announcement videos from the LA Auto Show have pointed it out. I believe it will be on all Priuses. The promotional images from Toyota's US newsroom show the switch on the dashes of both the Prius(Limited) and the Prime(XSE Premium), and the inverter is not listed on the option sheet for the different trim levels. That suggests it's standard on all trims.
    Terrell likes this.
  2. ChapmanF
    19,025
    Gen 3 has a 125 amp fuse, rather inconveniently buried inside the under-hood fuse box, between the DC/DC converter and the cable back to the battery. There is a 140 amp fuse in the + battery clamp end of that same cable. If an inverter connection is made (as I've suggested in the past) on the cable side of that battery-clamp fuse, then the added connection is protected both from the converter (by the 125 amp fuse) and from the battery (by the 140 amp fuse). Also, it is then only one fuse drop away from the converter, whereas it would be two if connected right at the battery + post.
    In Gen 2, the fuse at the front end of the cable is 100 amps (it's part of the long white multi-fuse-link), and the one at the battery clamp is 120 amps. The principles are the same.
  3. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    If it works. Hydrogen pretty much leaks through everything.
  4. paulsmith
    paulsmith New Member
    Seattle, WA
    2019 Aqua
    Four Touring
    Prius' 12v batteries, like all car batteries, have a limited lifespan. They can last for five to six years, if not longer. However, if you don't use them for an extended period of time, they weaken, and if you don't drive your Prius on a regular basis, they deteriorate and die.
  5. ChapmanF
    19,025
    In this case it hasn't got much incentive to, as the far end of that hose is hanging open to atmospheric pressure.
    You could maybe count the molecules that are going to permeate through the rubber hose instead of going right where it's easy to go, but you're not likely to notice breathing them or igniting them.
