12 volt battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by speedo, Dec 9, 2009.
  1. speedo
    speedo New Member
    I own a 2005 prius that has 44,000miles.Runs excellent so far.But seeing the 12 volt battery is 5yrs old, I made an appointment to
    have a new one put in about 180.00$.Do you think it's a good idea
    or do prius battery's last longer than in a normal auto.
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Absolutely it's the right thing to do. If the 12v battery dies on you, you're stuck. You can start the car, you can't shift into neutral, and if you try a jump start and accidently reverse the polarity, you're going to spend some big bucks. The small 12v battery has a typical life span of 4-5 years
  3. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
    Mine had a bad cell at 5.5 years all king of strange stuff starts to happen mine was shutting down the car, mine cost 138.00 at a dealer the minute it was in the gremlins stopped.
    DO IT Now!
  4. richard schumacher
    7,663
    1,038
    United States
    That amount is reasonable for dealer replacement. But you can check the battery yourself before spending the money.
    If you have a voltmeter, measure the "12V" battery voltage at the jump point under the hood with the car off. 12.6V is normal; if it's less than 12.0V, it's dying.
    Otherwise use the built-in self test procedure given here:
    http://priuschat.com/forums/gen-ii-...has-cold-weather-done-my-beautiful-prius.html
  5. don_chuwish
    don_chuwish Well Seasoned Member
    816
    180
    Southern Oregon
  6. derkraut
    derkraut Member
    299
    27
    SAN
    I agree with Mr. Schumacher; don't buy a new battery just because it's 5yrs old. In some parts of the country (like San Diego, where I live) batteries may last 8-10yrs. Test it periodically, and replace it when voltage drops below 12V.:)
  7. resoh02
    resoh02 Member
    140
    Northern OHIO
    I have a voltmeter but where do I check the voltage, at the battery terminals or somewhere under the front hood.
  8. Patrick Wong
    18,200
    6,464
    The accurate place to check would be at the battery terminals.
    Alternatively, you can measure at the dedicated jump start terminal located under the red plastic cover within the main relay/fuse box near the inverter. However the voltage might be slightly lower there due to resistance in the battery cabling.
    When you measure battery voltage, you first need to wait several hours after the car has been IG-OFF so that surface charge will dissipate. If the battery reads only 12V, it is very close to dead at that point and you have been running a risk of no-start for some time.
    If you would be unduly inconvenienced by failure of your car to start, you might choose to replace the battery sooner, rather than waiting for the battery voltage to decline to 12V.
  9. kenmce
    kenmce High Voltage Member
    1,512
    496
    NY
    If you are north of the Mason/Dixon line, I would consider five years a reasonable life expectancy for the 12 volt battery. If you are some lucky Son-Of-A-Gun who lives in SoCal, then perhaps more.
  10. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    If you chose to replace the 12 vdc battery, ensure you fully charge it with a good automatic battery charger, before installation
  11. richard schumacher
    7,663
    1,038
    United States
    As Patrick wrote, leave the car off for several hours before measuring. Measuring at the jump point under the red cap under the hood is convenient and, with the car off, it will be sufficiently accurate (with the car off the current and therefore the voltage drop are small). If you have a dealer install a new one, the dealer is *supposed* to charge it fully immediately before installing it. If you buy the eLearnaid Optima battery they will charge it immediately before shipping it to you.
  12. Patrick Wong
    18,200
    6,464
    I recently bought the correct 12V battery for my 2004 from my local Toyota dealer and the battery measured 12.9V out of the box. I was pleasantly surprised to find that.
    I also bought a 12V battery for my HiHy from the dealer, and that one measured 12.6V (which is supposed to indicate 75% charge) so I charged it up before putting it into service.
  13. ambrothe
    ambrothe Junior Member
    99
    Columbus, OH
    I had to replace the 12v battery in my 2005 Prius today because the car displayed the CEL and suddenly felt like it had no power while driving on the freeway, along with the engine shuttering severely like it was trying to turn off at every stop. The battery monitor went from 5 blue bars to 2 purple bars, then back to green. I made it home, replaced the battery, and problem solved! I am at 146k miles.
  14. DIG
    DIG Junior Member
    Costa Mesa, CA
    Our 12 volt battery died over night. We have 35,000 miles on a 2007. AAA doesn't seem to carry the battery. It's 4th of July weekend and our mechanic called Toyota and they told him it would take a day - which means next Tuesday the 5th.
    I'm wondering why AAA doesn't carry that battery.
  15. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    You could have tried charging the battery. :eek:
