12 volt charger fuse
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by bigmichaelkim, Jan 4, 2017.
  1. bigmichaelkim
    bigmichaelkim Member
    70
    US
    I just wanted to make sure that the fuse I should check is labeled as power outlet no1? That one looked not blown. Is this the correct fuse for me to check? The owners Manual was not so clear about what the different fuses power.
  2. Prodigyplace
    12,670
    11,829
    Central Virginia
    Which 12V charging outlet? The one on the console or the one on the back of the console for rear passengers?
  3. bigmichaelkim
    70
    US
  4. Prodigyplace
    12,670
    11,829
    Central Virginia
    Did you mean the Qi wireless charger? That is likely a separate fuse.
    I am having issues finding any fuse location reference in the 2016 manuals.
  5. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    You have missed the original posting PP. Read the above and you'll see it's nothing to do with the Qi. :)
  6. Prodigyplace
    12,670
    11,829
    Central Virginia
    They could have called the QI a 12 volt charger. Technically, there is no 12V charger that is driver-accessible. If the circuitry that charges the 12 V battery from the Traction battery had issues, they would have bigger problems.
    There are 12V power outlets, though.
  7. krmcg
    2,592
    2,392
    Whittier, CA
    Did anyone ever find which fuse controls the two cabin 12V charging outlets? The one on the console and the one on the back of the console for rear passengers?
  8. Prodigyplace
    12,670
    11,829
    Central Virginia
    krmcg likes this.
  9. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    A person reading this post cold will have NO IDEA what you are talking about.
    You should have put this in the same thread as where you originally explained your problem.
    P.S. Often those power outlets are designed to have power ONLY when the car is "running".
  10. Elektroingenieur
    2,515
    3,287
    Three Touring
    It seems to be a popular subject:
    Power sockets only 10 amps. Is this "normal?" What's it fused for? | PriusChat
    Accessory Outlet fuses | PriusChat
    12v cigarette lighter not working | PriusChat
    Replace Front 12v Outlet Problem | PriusChat
    RCO and Prodigyplace like this.
  11. padroo
    padroo Senior Member
    2,763
    2,252
    I found that fuse in the wiring diagram it is a 15 amp fuse, goes straight to the power outlet and then to ground.
    It looks like the accessory relay has to be energized to make it work.
    I am looking at a MitchellsDIY wiring diagram for a 2016 Prius 4.
    That fuse is a dedicated fuse just to power that outlet.
    #11 padroo, Feb 17, 2018
    RCO likes this.
  12. Prodigyplace
    12,670
    11,829
    Central Virginia
    There are two power outlets. One near the USB plug and one for the rear seat passengers.
  13. padroo
    2,763
    2,252
    Yes, I found the No. 2 also and it is 15 Amp and looks like it is hot all the time.
    My diagram doesn't say which is which but my guess would be the front one is number 2.
    RCO likes this.
  14. Elektroingenieur
    2,515
    3,287
    Three Touring
    Both power outlets are switched (ACC), and No. 2 is in the rear. Please see the last two paragraphs of the first posting I linked above.
    RCO, Prodigyplace and krmcg like this.
