12 Volt for 16 Prius 2
Discussion in 'Gen 4 Prius Main Forum' started by Edward Kennedy, Mar 13, 2018.
  1. Edward Kennedy
    Edward Kennedy New Member
    25
    Los Angeles
    Hi guys. Brand new. I need to replace the 12 volt in my ‘16 prius 2. There’s only one made that I am aware of through dealer. It’s the Truestart H4. Problem is I don’t want to spend $260 for it (cheapest I can find and only through dealers). Is there any updated info on people using other batteries. Its not the lithium version for the eco trim. Base standard Prius 2. Here’s the only battery on earth I can find so far :
    truestart 00544-h4052-470
    No luck at the salvage yards.
  2. Prodigyplace
    12,711
    11,848
    Central Virginia
    The 12 volt battery is the same on a ll Gen 4s. The high voltage traction battery differs though.
    Have you let your 12 volt battery run dead? What makes you think it needs to be replaced?
    Here it is for $185 but I do not know what they charge for shipping.
    2016 Toyota Prius Parts - metrotoyotapartsnow.com
  3. Edward Kennedy
    25
    Los Angeles
    Had the battery tested. Have to replace soon. Just looking for alternate options if any before buying this one.
  4. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    275
    Harrisburg, PA
  5. Edward Kennedy
    25
    Los Angeles
    That battery is for the Eco trim. Not standard. Different battery. But thank you
  6. booke02
    booke02 Active Member
    391
    415
    Israel
    Not covered by warranty? I had a problem with my 12V battery - it wouldn't hold charge for more than a few days - took into the dealer and they replaced it on the spot - no questions, no charge.
    Andyprius1 likes this.
  7. Prodigyplace
    12,711
    11,848
    Central Virginia
    Except Optima says their battery on that page does not fir the 2016 or 2017 Prius. I would be very wary unless the specs, including size, match exactly.
  8. Prodigyplace
    12,711
    11,848
    Central Virginia
    If a light was left on and drained the battery that is not a defect covered under warranty. That is expected behavior.
  9. Prodigyplace
    12,711
    11,848
    Central Virginia
    All Gen 4 use the same 12 volt battery anyway. That is what I would likely buy for my 2017 Two if shipping were reasonable.
    RCO likes this.
  10. Edward Kennedy
    25
    Los Angeles
    Does anyone have a ‘16 Eco model that can post the sticker specs on their 12 volt. Their is two different part numbers and two different different prices. Not sure how they can be the same battery. $100-$150 difference in price.
  11. Edward Kennedy
    25
    Los Angeles
    Battery is out of warranty.
  12. bisco
    52,822
    battery should not be not out of warranty, check with another dealer. pretty sure it's 8 years, prorated after the first two.
  13. Edward Kennedy
    25
    Los Angeles
    Battery is 3 years\36k. It’s out of warranty.
  14. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I think you'll find that it's only the traction battery with 8yrs warranty
    Prodigyplace likes this.
  15. bisco
    52,822
    interesting. not true for a replacement.
  16. bisco
    52,822
    along with a new battery, you ought to investigate cause of failure.
    RCO likes this.
  17. Edward Kennedy
    25
    Los Angeles
    It’s well used. It’s not a failure. And it still works. Just the 12 volt warning pops up on every startup. And battery testing shows I need a new one soon. Strong batteries. Just not $330 at the dealer strong. Ha. :)
  18. alanclarkeau
    7,045
    7,593
    Agreed - I was thinking of asking if there is a reason why it is failing? There were some posts about this a while back.
    From memory, the issues mentioned included
    • car sitting idle for a long while (was it several weeks)
    • car with FOB close-by
    • car left for long periods in ACCESSORY MODE
    What signs have you had that the battery is going to fail?
    [Incidentally - your comment that it "isn't lithium" would only be relevant to the ~200+ volt Traction battery in some models.]
  19. Edward Kennedy
    25
    Los Angeles
    If anyone who sees this thread has replaced a ‘16 Prius 2 (non-eco) with the Prius ‘16 Duracell Ultra Agm with success let me know! Thanks!
  20. bisco
    52,822
    does 'well used' mean you have a large aftermarket draw like a stereo or dash cam, or does it mean you have intentionally drawn down the 12v many times when not in ready, or something else?
    eric1234 and RCO like this.
