12 Volt Lithium Battery...Possible ?
Discussion in 'Gen 3 Prius Technical Discussion' started by TruSound, Feb 24, 2012.
  1. TruSound
    TruSound Member
    246
    32
    The 818
    Being my first Prius I assumed it had a standard size 12 volt battery, apparently it doesn't.
    My brief look at a few posts tells me it's a very small battery, just wondering how small, is it the size of a motorcycle battery ?
    If it is...can it be replaced with a lithium equivalent ?
    http://www.shoraipower.com/
  2. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    I'd never heard of these guys but http://www.shoraipower.com/t-faq.aspx says
    There was some discussion of li-ion 12 volt batteries at http://www.mynissanleaf.com/viewtopic.php?p=114815 and a pointer to http://www.porsche.com/usa/aboutporsche/pressreleases/pag/?pool=international-de&id=2009-11-23-02. 1904 Euros = $2545 USD
  3. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Your 12V battery is fairly large for a motorcycle battery, 38 A-Hr. It does look like one though, complete with a vent tube. But for a different reason. It's in the cabin so must vent outside (ALL batteries may vent, even "sealed" ones).
    Do some research, and you'll find you -can- buy lithium rechargeable cells. The ones large enough for direct replacement cost in the area of $100-$200 per cell. You would need four cells. You would also need a charging circuit as lithium cells are charged differently than lead acid cells.
    Not very practical at this time.
  4. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    DO NOT change out your 12V battery for a Lithium-based battery!!!:eek:
    The 12V battery is a standard Lead-acid automotive type battery. The nice thing about these batteries is that they are very robust and can be deeply discharged and are forgiving of over-charging.
    On the other hand, Lithium-based batteries are relatively more finicky about their charge and discharge levels. If one should over- or under-charge a Lithium battery by just a couple of volts, it will undergo a chemical change that will ruin the battery. These batteries require special controllers to prevent this problem. Also, if they overheat, they can explode.
    ONE CANNOT SIMPLY DROP A LITHIUM-BASED BATTERY INTO A SYSTEM DESIGNED FOR A LEAD-ACID BATTERY!
    So, get your head out of the clouds.
    If you really want to make such a change, consult a qualified battery engineer first.
    Note I said a battery engineer, not an automotive technician.
    'Nuff said.
    Rescue2cop likes this.
  5. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I have to ask, what problem you you trying to solve?
    Until we know that, we can't be helpful, only discouraging. Lead Acid is such a known, refined technology, that it will be 'better' than better technologies until they get as experienced.
  6. jdenenberg
    jdenenberg EE Professor
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Actually the 14 volt "constant voltage' charging in our Prii is just above the "Float" voltage for SAFE LiFePo batteries (3.4 volts per cell times 4 cells) so a 4 cell battery would get charged safely but slowly. The price is steep for 4 cells (about $1500 for 80-100 amp hours for 4 cells, why do it to just match capacity with the OE battery?) and unless you regularly take long drives, you will need an external balancing charger and a Battery Management System (BMS) to help maintain cell balance over time to preserve your investment.
    The Valence U1-12XP is a fully implemented 40 am-hour,12v, replacement Lithium Iron Phosphate battery with built-in BMS, but it also costs about $1500.
    http://www.valence.com/energy-storage/lithium-phosphate-battery-data-sheets
    They are slightly smaller than an Optima, weigh half as much, and have slightly higher capacity. The built-in BMS prevents discharging below 10v so they would survive in a Prius.
    JeffD
    alekska and andyprius like this.
  7. TruSound
    TruSound Member
    246
    32
    The 818
    Wasn't trying to solve any problems, and my head wasn't in the clouds...it was just a curious question, wondered if anyone might have done it. I've seen some of you geeks with battery packs, flux capacitors and all kinds of other shit under your hoods, so just though one of you pocket protector boys might be running one... all you frickin geeks need to chill, didn't need all the BS, just the facts would have worked.
    usnavystgc and CreigMac like this.
  8. tincmulc
    tincmulc Junior Member
    Slovenia
    I think all he wanted to do was to stop you from setting your car on fire. Even if you weren't trying to put a Li-ion battery in your car, someone else reading the thread might get the idea. And better to be safe than sorry when it comes to such things.
  9. TruSound
    TruSound Member
    246
    32
    The 818
    Well then, I should thank him for preventing me from burning up my car...I'll be sure to check with him before I just start throwing random parts at my car.
    The post title reads...POSSIBLE ?, not...don't do this it'll burn up you car.
  10. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    We all have the right to ask any question!. I wish I could get my head in the clouds...............:rockon:
  11. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Uh oh...
    I thought the question was valid. And the some of the answers a little combative.
    But to the OP? You might not want to come back with calling us freeking geeks and pocket protector boys....
    Prius Chat is a diverse community.
    Now if you'll excuse me, my ball point pen just broke in my shirt pocket.....
    usnavystgc likes this.
  12. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Actually I have replaced most of my UPS batteries with LiFePO4 batteries. Have not had any issues with them yet. Only down side is that they dont get fully charged so you dont get full capacity but on the other side that will make them last longer.
    This would most likely be the best option for a replacement 12v battery for the Prius. Its about $500.
    LiFePO4 Prismatic Battery: 12.8V 40Ah (512Wh, 100A) with Balancing PCM (48.0)
    I dont like the whole BMS idea but since its being charged with lower voltages the BMS should be relatively safe. If you plan on getting the above battery and use it in an automotive environment you will want to take it apart and use Nord-Lock washers for the connections.
    [email protected] and andyprius like this.
  13. TruSound
    TruSound Member
    246
    32
    The 818
    A nice straight answer...thanks Force.
    It was not my intention to stereotype the intire community here Electric, thanks for the support on the original question...I hope that ink stained shirt wasn't a favorite, TeakWierd probably has a stain removal procedure he can give you, once he pulls his head out of his nice person...I mean the clouds.
    Sorry gang...couldn't help myself.
  14. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    And so far as I know we have the right to give honest answers.
  15. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    That's what you got, the facts.:rolleyes:
    You just did not want to hear them.:bored:
  16. TruSound
    TruSound Member
    246
    32
    The 818
    I have no problem with honest answers Jimbo, my only issue was with the tag line...and come on, was the question really that far fetched.
  17. andyprius
    2,212
    188
    From a innocent question you sort of got caught in the midddle. Everybody has a right to ask any question on this forum AND everybody has the right to a honest and sincere answer. It is very easy to interpret just one word in the wrong way. Agreed? :D
  18. andyprius
    2,212
    188
    NO, Not at all!
  19. andyprius
    2,212
    188
    Very interesting read so we are getting to a better, stronger and lighter starter battery (finally). So the OP had a very valid point. :rockon:
  20. TruSound
    TruSound Member
    246
    32
    The 818
    Actually Teak, I did hear your facts, and appreciated your imput...the last half wasn't really necessary...was it.
    I think you finished with..."NUFF SAID"
