120000 Servicing
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Stephen Ross, Feb 11, 2018.
  1. Stephen Ross
    Stephen Ross Junior Member
    Lagunitas
    I
    My Toyota Dealer wants $967 for the 120000 servicing on my 2014 Prius! Seems quite excessive, eh?
    Raytheeagle likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    Was this for the Work specified for the 120 k mile change or additional items? Have you tried other dealers for comparison? Any other shops? Are you the DIY type?
    Keep us posted (y).
    SFO likes this.
    52,767
    welcome!
    not horrible, but maybe a little spendy. it's the biggest service until 240k, so, it's not going to be cheap anywhere, but you may finder cheap(er).
    whatever you do, don't ignore it, the first 120k were cheap.
  4. padroo
    padroo Senior Member
    2,763
    2,253
    What is on the list for 120,000 mile service. You could do some of it yourself and that should lower the cost or maybe have an independent garage do the work.
    Grit likes this.
  5. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Well, it depends what you are looking to have done. I am currently quoting out a 120k for someone and I am close to that number once I include the optional coolant, transaxle and brake fluid changes.
    The factory specified 120k basic service includes an engine oil and filter change, both air filters, spark plugs, tire rotation and full inspection. I would expect to pay about $500-$600 to have this performed at the dealer. The spark plugs alone bill out at 1.5 hours (yes, we know they can be done in much less time) and the remainder of the service can probably be charged at around 1 hr. Expect to pay around 2.5 hours of labor at dealer rates and around $150 in parts.
    NutzAboutBolts and FuelMiser like this.
  6. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,784
    Bay Area
    All of those maintenance are doable by yourself too, you would be saving more than 1000$ since they charge a lot for labor at the dealers for those services. We do all of those services ourself.
    Raytheeagle and Grit like this.
  7. The Critic
    3,193
    2,333
    CA
    Right - but not everyone is wanting, capable or willing to do those services themselves. It is a perfectly fair for a member to ask us for an appropriate price to have those items done professionally. This is not a forum for DIYers only.
    Raytheeagle and NutzAboutBolts like this.
  8. Mendel Leisk
    42,251
    Loaded question. Do you know what's involved? Why not itemize it, do the math?
    Grit and padroo like this.
  9. NutzAboutBolts
    1,756
    1,784
    Bay Area
    Probably cost more because of labor. But they add fluids, disposing the fluids, and the 2 washers?
  10. Mendel Leisk
    42,251
    Raytheeagle and Prodigyplace like this.
  11. Prodigyplace
    12,710
    11,848
    Central Virginia
    Another on-post wonder.
    NutzAboutBolts likes this.
  12. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I think it rather depends on how up to date the servicing happens to be on your vehicle. My 2009 Gen II now has 129,000 on the odometer, and I remember when I took it to the local dealer for the 120k service, it was ~$200 which included new sparking-plugs, and during the service, the service manager called me and offered to replace the PCV as it needed replacing and as they were working in that area of the motor, they'd replace the PCV for the cost of the part (~$12). I think there might have been a transmission-fluid change too, although without looking back through my logs, I can't be sure, but I'm sure the engine oil and filter were changed, and the cabin and ICE air-cleaners I changed myself, - hope this helps - Wil
    Stephen Ross likes this.
  13. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Prodigyplace and Mendel Leisk like this.
  14. Stephen Ross
    Lagunitas
    I
    Yes, I will do that, thanx....
  15. Stephen Ross
    Lagunitas
    I
    Yes, the main items are: spark plug change, oil change and cabin and engine filter . . . I'm capable of inspecting the mat :) . . . Is there anything special in changing the plugs on a Prius?.... thanks . . .
  16. Stephen Ross
    Lagunitas
    I
    If you like Redwoods and being closer to Pt Reyes, more beautiful :)
  17. Stephen Ross
    Lagunitas
    I
    Yes, have itemized it: main things: oil change, air and cabin filter change and plug replacement . . . the only thing I'm not sure of doing myself is changing the plugs...anything special to know about spark plug change on a 2014 Prius? Thanks....
  18. Stephen Ross
    Lagunitas
    I
    Yes, just for the recommended items: oil change, air and cabin filter replacement and spark plug replacement . . . good on DIY except for spark plug replacement....anything special about plug replacement for 2014 Prius? Thanky
  19. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Follow the @NutzAboutBolts video in the Gen3 maintenance section and you be good to go;).
    I would add an egr cooler cleaning while the windshield wiper cowling is removed:).
    Good luck and keep us posted(y).
