120K Service - Need advice!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Preeeus, Jan 15, 2016.
  1. Mendel Leisk
    42,384
    Repair Manual instruction is pretty typical in this regard. Before starting to fill, loosen "Air Release Valve", start pouring in coolant at the reservoir. You will likely be able to hear/feel air coming out as you fill. When coolant starts coming out of the valve, shut it, and continue pouring.
    There's a spigot on the valve you could push on tubing, catch the overflow. If you're careful it'll just be a tablespoon or two spillage, hardly worth the hassle of tubing.
    (At right side of engine, pretty far back, near EGR valve. The white cap on top is what you unscrew, has a slot. Spiggot on the right.)
    FWIW, @NutzAboutBolts got through this with no mention of the air release valve, but maybe it'd go a little quicker, less air trapped?
    #61 Mendel Leisk, Sep 26, 2016
    Glee217, Raytheeagle and Tbkilb01 like this.
  2. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Toyota removed the bleeder valve at some point. It's on Mendel's 2010 but not on my 2012. Just squeeze the hoses to get the bubbles out. You can tell when you squeeze them because you can feel the bubbles gurgling at first, then the gurgling stops.
    I changed these fluids at 80,000 mi and strained the fluid thru a coffee filter just for fun. There was very nearly no sediment at all, and it easily could have fallen off the bottom of the car while draining. The fluid looked very clear. So I don't think it's critical to expel every last ounce and I think you'll have little difficulty getting all the air out. Don't over-think it.
    #62 Rebound, Sep 26, 2016
    Raytheeagle likes this.
  3. Mendel Leisk
    42,384
    Yeah that's what I was thinking. For anyone that's got it though, I would use it.
    Does yours still have the black plastic connector, with electrical connector, but not the white screw cap on the top?
    Tbkilb01 likes this.
  4. Mendel Leisk
    42,384
  5. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Good advice.
    That would never happen:rolleyes:.
  6. Tbkilb01
    Tbkilb01 Active Member
    218
    187
    Louisiana
    I guess It does.
  7. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    My 2012 Prius don't have the air bleeder valve. They removed it for the 2012 and up, and everyone should have a Lisle 24680 Spill-Free Funnel, it saves you so much headache on this simple maintenance.
