120K Service - Sanity Check Shop's Recommendations
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jboehm, Feb 19, 2024.
  1. jboehm
    jboehm Junior Member
    PDX
    My 2012 Prius is somewhat new to me. I know that 120,000 miles is a significant service. I located the previous owners service shop and asked them for the todo list. I want to sanity check the list as some things are not in the Toyota recommendations list. I've got no problem doing extra wise-maintenance but wanted to double check with the community. Car is running great. No oil consumption and no service/check lights. I'll do most of the work below myself.
    The shop did not recommend the EGR cleaning but it is in my longer term todo list. I would like to pull the entire system with an intake manifold from a parts-puller, clean, and swap them in at a later date. How urgent is the EGR system cleaning?
    Shop's recommendation:
    • Oil, filter, washer
      [COMMENT] - Yep planned
    • Replace Water Pump & Coolant, (recommended to help prevent head gasket failure as maintenance at 120,000 miles.)
      [COMMENT] - Really, water pump? I do plan to do coolant.
    • Prius Inverter (HV) Coolant Change (DUE EVERY 100,000 MILES OR TEN YEARS)
      [COMMENT] - Yep overdue
    • Remove & Replace Spark Plugs, Gen3 Prius (RECOMMENDED EVERY 120,000 MILES)
    • Brake Fluid Flush, Gen3 Prius (DUE EVERY 5 YEARS)
      [COMMENT] - Ugh, I hate Techstream brake fluid change. Will probably have the shop do this.
    • Clean HV fan intake, install upgraded intake screen, clean HV blower assembly, Gen3 prius
    • HV Transaxle fluid change, Prius (DUE EVERY 60,000 MILES)
      [COMMENT] - I don't see Toyota recommend this be changed
    • Clean throttle body and MAF, Prius (RECOMMENDED EVERY 30,000 MILES)
      [COMMENT] - Really??
    Where do people buy the water pump, HV Transaxle fluid, and Toyota coolant? Amazon seems to have an OK price.
    Water Pump - AISIN WPT-190 is the OEM part. Amazon sells the OEM part without the Toyota stamp. Everything I read it is the exact same part. Current price $153
    Toyota ATF WS transmission fluid - Current price $53 for 4
    Toyota Super Long Life Pink Antifreeze Coolant 50/50 - Amazon has for $30 a gallon
    Thanks!!
  2. Tombukt2
    Tombukt2 Senior Member
    13,809
    2,504
    Durham NC
    All that is not out of this world The transaxle fluid I think is maybe considered permanent but hell what is permanent for the car apparently around $150,000 mi smart intelligent people will be out of a generation 3 and on to a new car payment maybe a new sienna hybrid because they've got a kid now or something of the like Toyota's today aren't made to go $350,000 miles or better at least the Prius generation 3 certainly is not generally speaking in a normal sense of the word If you're running a taxi cab or constantly in the wind with Uber eats and that sort of nonsense you have a very good chance of making $385,000 mi That's the car never sitting until Sunday every week 52 weeks out of the year I don't know many people that run like that except for cabs and the crazies during the pandemic our car made 360 or 376 they're under those conditions our 2013 persona failed miserably in blue and engine head gasket etc at you know 180 90 somewhere in their thousand normally for the last 45 years that I've been with Toyota I have never seen anything happen at 180 or 90,000 miles other than regular maintenance schedules or not so there's always that so in my eyes Toyota took a dump on me with a generation 3 and they will never be trusted again without full due diligence on my part which I didn't have to do until this model I could just go pick up a Corolla a Scion XA whatever any of that kind of stuff back in the olden days and not have any issues 2010 seemingly all the silly issues have started with all of Toyota in general they've become planned obsolescence and are very Americanized now they are not the Toyota t o y o d a that many of us might have grown up with or at least I did so they can no longer be trusted they are like the folks on some of the other side of the aisle now and grandios lots of television that sort of thing.
  3. Mendel Leisk
    42,271
    You’re talking yourself into head gasket failure; better get on it soon.
    Nope, according to Toyota USA it’s 150k miles or 15 years, whichever comes first. The Toyota USA Warranty and Maintenance Booklet is a VERY tricky read on this, follow the postscripts.
    to be fair, Toyota Canada recommends to change coolant on both, at 10 years or 100k miles. Funny thing: on the inverter coolant reservoir of mine, there’s a US spec label, saying don’t change till 150k miles. No mention of months.
    Repair Manual has a non-Techstream instruction; see my signature. On a phone turn it landscape to se signature.
    Maybe do change, sooner than later. Ditto for inverter coolant pump. They have proven failure prone around these miles.
    I would do this, at least once. See my signature.
    Why not, takes about an hour, easy DIY. I’d recommend to disconnect throttle body and lift off the intake manifold (leave coolant hoses connected), to clean more thoroughly. Do in conjunction with the EGR? Torque specs are quite low, see intake manifold attachment in first link in my signature.
  4. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    Myth, unproven, unsubstantiated.
    Brian1954 and Mendel Leisk like this.
  5. jboehm
    PDX
    Thank you all. I appreciate the feedback.
    Too bad there isn't a water pump rebuild kit available. The failure tear down I saw on youtube showed how trivial a rebuild it would be. The epoxy failed exposing the magnet to coolant. The rusting magnet deformed and pushed the epoxy into the sides of the pump wall. Pump stopped but the pump wall is not significantly damaged by the failed, much softer ,epoxy. Replacing the spinning magnet is a fairly simple job assuming such a kit existed.
    About the EGR cleaning -- For down time reasons, I really want to swap known good clean parts in then clean and stash the parts I pull out. Is this a common approach? What is the frugal but still safe way of buying the parts? Feels like someone could have a pretty cool core-charge based business doing a rotating parts swap-n-clean service.
  6. Brian1954
    Brian1954 Senior Member
    2,660
    1,062
    South Central PA, USA
    You can buy the water pump impeller from Amazon or eBay for $25 to $30. You should also buy a new water pump gasket.
  7. Mendel Leisk
    42,271
    The only part I’d consider replacing is the cooler, and the longer the cleaning has been delayed, and accordingly the more carbon-choked the cooler, the more necessary this would be.
    I did a first EGR cleaning around 65k kms, and a second (fall before last) around 90k. We don’t drive much, I’ve got lots of time, and at least in part it’s my science experiment.
    I learned a lot the first time ‘round, and forgot a few things too, lol. Anyway, second time around, knowing that the cooler is by far the biggest cleaning chore, I made a point of getting it out and filled with a water-based carbon-busting solution, plugged and propped up in a corner of our laundry sink.
    set a timer for an hour, then carried on dealing with EGR valve and pipe, and the intake manifold and ports in the cylinder head.
    each time my alarm went off I flushed out and replenished the coolers solution. By the time I was into reassembly I’d done about 5 cycles thus with the cooler, and it’s interior was virtually like new.
    In my scenario a replacement cooler was unnecessary, but it’s debatable with one more cabonned up. Still, i was only using Oxi-clean solution. For a more heavily impacted one, perhaps hydrogen peroxide (lye) solution, wire passed through and a pressure washer, and it would clean even faster?
  8. amarino
    amarino Active Member
    144
    105
    99
    I think that was popular back in the day on the forums when these cars were new. Cheapest now would probably be going to a junkyard and you can practice pulling it off yourself. Next cheapest would be buying another set off eBay. For both of these options you would have to clean the used parts before swapping them in. Last option is to just buy the EGR parts new, clean your old ones and keep on a shelf, then in the next 60k-100k miles swap them around.
  9. jboehm
    PDX
    Thanks all for the continued Q&A. .....Thinking more about intake/EGR cleaning
    I plan to reuse all my hard gaskets as long as the OEM paint/finish is still in place and they don't get bent/damaged.
    Soft Gaskets - Here is my question. Should I plan on replacing them? Any concern over OEM vs Fel-pro? My guess is that I will be advised to replace them as they are 12 years old with 120K. I count 3 soft gaskets on the intake.
    1 - Throttle body to Intake
    2 - EGR to Intake
    3 - Intake to Head
    thanks!!
  10. jboehm
    PDX
    Are these 3 crush washers the same part? 90430-18008 alt# 90430-A0003
    * Oil fill and drain on Transaxle (2)
    * Inverter coolant drain (1)
    I guess that would make sense as they are all physically on the Transaxle
  11. Mendel Leisk
    42,271
    yes. Last time I cleaned mine I opted to change them. Info from my Amayama order, in CDN dollars; the only extra was $14~ shipping:
