123 Sub Code on P0A80?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Willwortman, Jul 26, 2023.
  1. Willwortman
    Willwortman Junior Member
    25
    Gainesville, Florida
    Can anybody tell me what the 123 sub code is on a P0A80 code?
    My 2010 base model with 302,000 on the clock has been intermittentantly throwing the code for the last four months.
    I clear it and it will run flawlessly sometimes for several days(some times for 30 miles) and then trip again. Rinse and repeat:(
    All of my mystery started about six months ago when I had to slam on the brakes and in the process must have killed the ABS module. I replaced that using my X-Tool to do all of the bleeding and calibration:). I was hoping that that was the cause of the P0A80, but, alas, it was not.
    Then, I got the code P0AA6 with sub code 612 I think. I forget, but it was the code that pointed to the battery pack. Took the pack cover off and found that the terminal plates were fairly green and corroded. Cleaned them with sulfuric acid, polished them to a mirror finish with 2500 wet, put the pack back together and that code has gone away, but I still get the the intermittent P0A80.
    I have the Torque App and moniter the battery on long trips(150 mi) and all of the banks stay within .5 of each other, mostly .1-.3
    When I park it with the A/C on and load the battery, 6,7,8 will eventually get up to about .8 difference before the engine cranks.
    I know that the battery has been worked on before because they are numbered and some bolts were missing on the case.
    All of the modules have (K) on them, 2009 I think? so I don't know if they are original to the car or not. If they are, they are rightous modules:) I do have the hybrid automotive grid charger and balance/condition as precribed.
    Oh yeah, shortly after I bought her,(can we say her anymore:) I had to replace the head gasket. That was at about 230,000 miles.
    I know that I am going to have to re-pack her fairly soon, but I realy would like to squeeze/massage her a little farther down the road first.
    Back to my original question, 123?
    Oh, I do have techstream, that is how I got the sub codes but for what ever reason, it won't do live data, so that is why I use the torque app. Plus it is a lot more convenient than having a mini vci cable around your feet while driving.
  2. ChapmanF
    19,033
    123 is, AFAIK, the only subcode that P0A80 ever comes with, in a 2010 anyway. Therefore, in the information-theory sense, it has entropy of exactly zero, and tells you nothing (that you don't already know from the P0A80).
  3. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
  4. Willwortman
    25
    Thank you. I kind of figured since nothing came up in a search. What the hell does AFAIK stand for?
  5. bisco
    52,862
    As far as I know, it stands for as far as I know
    burebista likes this.
  6. Willwortman
    25
    Ok then. I know somthing now that I did not know 10 minutes ago. Thanks.
  7. Willwortman
    25
  8. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    Yeah on these things you always check the battery ECU look at the pins unplug the orange plug look at it real good You see any corrosion any funny business try and clean it up or go to another car and cut the plug out or whatever you got to do unplug the other end or something.
  9. DanThePriusMan
    DanThePriusMan New Member
    Saturday
    The Boondocks
    I’m building B.E.T.S.Y. (Battery, Engine & Toyota Scanner for You), an open-source Android app for Prius diagnostics, and I need some help from Gen 2 and Gen 3 owners.
    B.E.T.S.Y. can already read the raw Toyota INF/detail codes directly from the hybrid ECU using a bog-standard Bluetooth ELM327 adapter. Mine cost about $3.50 on AliExpress.
    It can read the codes, but it can’t decode them yet. That’s what I’m working on next, and just being able to retrieve them is already one step further than Dr. Prius currently goes.
    What I need now is real-world data.
    I’m looking for captures from Gen 2 and Gen 3 Priuses (roughly 2004–2015), especially cars with an active or stored fault code.
    P0AA6, P3000, P3019, or really anything with an INF/detail code would be especially useful. Healthy cars help too, since they let me compare different cars and model years and verify the read method works consistently.
    You’ll need:
    • A Gen 2 or Gen 3 Prius
    • Android 8.0+
    • A Bluetooth ELM327 adapter
    Then:
    1. Install B.E.T.S.Y.
    2. Connect the ELM327
    3. Run the capture
    4. Tap Share to submit the raw data
    It should take about two minutes.
    The project is fully open source. The source code and APK are both published on GitHub, and the APK is built automatically from that source by GitHub Actions. The app does not upload your VIN, location, or other identifying information.
    The goal is to use these captures to build and verify the decoder and create a crowdsourced dataset, so Prius owners can eventually read Toyota INF/detail codes without Techstream or Mini-VCI.
    So if you have a Gen 2 or Gen 3 Prius, triangle or no triangle, I’d love to borrow about two minutes of your car.
    Stored fault code? Even better.
    ⬇️ Download B.E.T.S.Y. v0.0.2 here:
    Release v0.0.2 — data gathering release · alrighdee/BETSY · GitHub
