12V and Electrical Issue
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MashinA, Mar 26, 2018.
  1. MashinA
    MashinA Junior Member
    32
    Ive been having electrical issues with my 2007 prius for a awhile now and just cant seem to figure out what the problem is. The weird thing when i shut the car off and open the driver door i hear the beeping as if something is turned on when nothing is on. Then when i go to start it again i have to press the Start button then it wont start, i press it multiple times(without foot on pedal) to shut car off then press it again(with foot on pedal) and it then starts. Sometimes i have to go in the back to unhook the battery, hook it back on and it starts. Then it stopped completely and none of these tricks worked. Ive replaced my 12v battery because i thought thats what the issue is and still no good. It worked for about 2 weeks and now its back to not wanting to start. When i checked the voltage on my new battery it was at 3V!!! I dont drive the car anymore it is listed for sale so my mechanic told me that this is normal with these vehicles that if you dont drive it for a week the hybrid battery drains out the 12v which doesnt sound right to me at all. Can you guys suggest anything that might be the issue...i dont know where to start and my mechanic seems to not have an idea. Its really frustrating having to climb in the trunk every other time to open the hatch...
    #1 MashinA, Mar 26, 2018
  2. JC91006
    16,935
    8,646
    Yes your mechanic seems to have no idea
    If you have a warranty on the new 12v battery, you might want to have that battery checked. A good battery should be over 12.6v in a Prius.
    jerrymildred likes this.
  3. MashinA
    32
    I mean i was having the issues with the old battery and the new battery....doesnt seem that the battery is the problem?
  4. JC91006
    16,935
    8,646
    The new battery can be a bad battery? One that has sat around way too long before you got it? Just because it's new, does not mean it is good.
    You can fully charge it and then have it tested. If it tests good, then you can start looking at your car as the problem.
  5. MashinA
    32
    I had the old battery tested and they said it tested good yet the problems continued. Appreciate the suggestion but im 99% sure the battery is not the problem
  6. JC91006
    16,935
    8,646
    There are many threads here regarding battery issues and many times, a new battery will solve the problem.
    I'm not exactly sure how old was your "old" battery that you tested "good". But there aren't that many things that can cause your car to drain the battery.
    1. Do you have anything after market installed?
    2. Do you have any warning lights on the dash? Telling you the DC/DC converter is not charging your battery?
  7. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Would appear the 12v is low (like JC91006 said above).
    If you have the SKS key fob (keyless entry), there is a switch underneath the steering wheel you need to turn off when not using the vehicle for an extended period (else it will drain the 12v battery). Make sure your physical key works in the door lock before turning off your SKS feature.
    If your mechanic doesn't have a proper 'AGM compatible' 12v battery charger, you can let the car charge the battery (it does so slowly while driving or in "ready mode"). Once you have the car in 'Ready' mode, let it recharge the 12v battery by leaving it turned on for 8 to 12 hours (just sitting in park with the emergency parking brake engaged is fine). Make sure you have gas in the tank, as the engine with cycle on and off over that period of time.
    If the 'new' battery refuses to hold a charge, then you should take it back for a refund or replacement.
    Raytheeagle likes this.
  8. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Which battery is installed in the vehicle? Old or New replacement? You never returned the old battery for the core charge, when you picked-up the new replacement?
    1) You don't know how the Prius works. The 12V battery is the most likely culprit.
    2) It is possible the new replacement battery was defective or not fully charged before installation.
    3) Does you car have SKS? Disable it, if the car will be sitting for long periods of time; read the owners manual for How To.
    4) What battery did you purchase as the replacement?
    It should be a 45AmpHr, AGM (Absorbed Glass Mat) battery, available from your local dealership and auto parts stores.
    If you purchased an Optima, you made a bad purchase. The Optima is a 38AmpHr battery. Prius w/ SKS came equipped w/ a 45AmpHr battery. The Opitma has 7AmpHr less capacity, which translates into less stand-by time.​
    5) Many shops and auto parts stores test 12V batteries w/ a Load Tester, that measures CCA (Cold Cranking Amps). This test is worthless for the Prius 12V AGM battery, as it does NOT Crank the engine, like a traditional car. FYI, the Prius High Voltage battery cranks the engine. Many times, load testers return a false positive that the Prius battery is good. The Prius 12V battery is used to power up the various ECUs (think computers) in the car; these computers tell other computers and various mechanical devices what to do.
    6) JC pointed out another culprit draining the 12V battery: aftermarket accessories/modifications.
    Is my inverter coolant pump slowly failing? | PriusChat
    Read post #5- How to apply a load to read the 12V battery SOC (State of Charge)
    Read post #8- Smart AGM compatible battery chargers.​
    A 12V that is in a regular state of discharge, like your battery, will live a shortened life, as yours do. Get a smart AGM charger and maybe just recharge the battery every other week. The CTEK or Noco would be perfect, as these two chargers include a "pig tail" that you can leave permanently attached at the battery terminals.
    #8 exstudent, Mar 26, 2018
    PAUL SCHULTZ and Stevewoods like this.
  9. Stevewoods
    Stevewoods Senior Member
    664
    1,257
    where I am
    Far from being an expert, but your description cries "Bad 12v battery."
    there have been lots of threads on this forum where an auto shop has tested a 12v and declared it good, yet it does not work in the Prius. There is something about it I don't understand, but plenty of the folks here do and maybe one of those will explain it for you.
    I am reluctant to suggest, but, if YOU TAKE ALL THE PRECAUTIONS __ RTFM __ (that is read the FXX manual), you might try a jump start of the Prius and see if starts. That would tell a lot. The problem is you have to make sure you do it properly. I take no responsibility if you do not.
    The battery may have been fine when you installed it, but there may be something that is wrong that is slowly draining the charge from the 12v. As said before, the mechanic advice you got....well....:rolleyes:
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    WOW! A mechanic told you that?! It doesn't sound right to you because it's nonsense.
    As stated before, either the new battery is low due to sitting on the shelf too long, or some accessory is draining your 12V battery.
  11. dolj
    dolj Senior Member
    8,633
    4,387
    Wellington, New Zealand
    Just to reiterate, the 12 V battery may not be the problem, but at 3 V, it is a problem and one you need to rectify before doing anything else. It will be impossible to diagnose the car with the 12 V in this state. It may be too late to recover this battery, depending how long it has sat in this severely discharged state. Once you have good and reliable 12 V supply, you can then determine if that is the only problem, or whether there is some other problem causing a unusual draw on the 12 V system while the car sits idle.
    This is certainly part of the problem. For all the time the car sits idle waiting to be sold, you need to have the 12 V battery on a fully automatic multistage charger that has a maintenance function and an AGM setting. Period. No argument.
  12. bisco
    52,800
    put a battery maintainer on it while it is sitting.
  13. MashinA
    32
    I have nothing aftermarket installed, and i dont have any warning lights related to this issue. The ones i get are usually p1116 and p1121
    i did that today and for about 2 hours of run+drive time it was showing 14v again.
    Once i bought the new battery like 6 months ago and the problem persisted, i went back to the store tested my old battery(which i shouldve done in the first place) and turned out it was good so i got it back but they didnt let me return the new one. So i took the new one out and just kept it. At the time i was having an issue with my HID headlight that kept flickering so i had replaced the ballast and the problem seemed to have gone away for a bit but then it came back on and off. So i decided recently to take it to my mechanic again and he just put the "new" battery back in and the problem seemed to have gone away for about 3 weeks until it started happening again yesterday. Ill have to check on what battery i have but i believe it was the optima as i got it from advanced auto parts. I will look into these chargers you're talking about. Also you said a "12v that is in a regular state of discharge will have a shortened life." Wouldnt something be causing it to be in this regular state of discharge? Meaning a problem other than the battery itself?
  14. MashinA
    32
    I let the car idle for a couple hours and drove it for a bit and when i turned it off and checked the battery voltage it was back up to like 14V. Can you recommend any of these fully automatic multistage chargers? Are the CTEK and the NOKO the ones like the other poster recommended?
    Again thank you all for your replies, its a lot of info that i will need to look into. Im not too savvy when it comes to cars, especially the prius! :eek:
  15. dolj
    dolj Senior Member
    8,633
    4,387
    If your battery was 3 V, then 2 hours is nowhere enough time to fully charge it in car. Try 16-20 hours. Test your battery voltage again two hours after shutting off, that will give you a better idea. The 14 V is just the surface charge.
    Yes, either of those brand are good. Look for one that has a max amperage of 4 Amps.
    #15 dolj, Mar 26, 2018
    jerrymildred and valde3 like this.
  16. exstudent
    2,214
    905
    Torrance, CA
    When the care is READY, 13+-14v is normal, and is expected to be seen; how else would the 12V battery get charged?
    You installed the new battery, that was allowed to sit unused, for at least 6months, and in this time period the battery will discharge normally; the extent of discharge is unknown as you did not measure its SOC before installation. It does not help that you had this new battery installed w/o being fully recharged either.
    I will double down that you have a 12V issue.
    1) You installed an Optima that was in a discharged state.
    2) You don't drive enough.
    3) Assuming you have SKS, the Optima is severly taxed/overworked, b/c it is in a perpetual discharged state.
    4) The Optima is either now damaged and NO LONGER reliable, or it may possibly have some life left if you recharge it.
    5) Invest in one of the three smart AGM chargers I listed, or do your own research and buy your preferred smart AGM charger.
    6) Recharge this depleted Optima w/ a smart AGM charger.
    7) For the love of God, read post #5 & #8 in this link:
    8) Once this Optima is recharged, See what the SOC is the next day, by applying a load as listed in post #5 from the thread, Is my inverter coolant pump slowly failing? | PriusChat
    9) Buy a Digital Volt Meter (DVM), as you most likely don't have one. This is very useful tool, just like a screwdriver, hammer, wrench, socket set, tape measure.​
  17. MashinA
    32
    Btw no one addressed the fact that when i turn the car off and open the door to get out there is a beeping noise(like when there is something turned on still) when everything is off?
  18. bisco
    52,800
    low 12v could cause that.
    SFO likes this.
  19. MashinA
    32
    Got ya, i was thinking that could be why but wasnt sure. Thanks
  20. exstudent
    2,214
    905
    Torrance, CA
    You realize you make no mention of this until Post #17.
