12V and Electrical Issue
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MashinA, Mar 26, 2018.
  1. MashinA
    MashinA Junior Member
    32
    Its the 2nd sentence of post #1...
    You think its due to low battery voltage as well?
  2. MashinA
    32
    So ive charged the battery and have been driving the car on a daily basis to work and back for about 2 weeks now. I unplug the white cable from the battery when i park it overnight. So far i havent had any problems starting the car so does that eliminate the bad battery issue or no?
  3. padroo
    padroo Senior Member
    2,763
    2,253
    That beeping sound could still be a problem. Do you open the door before you shut the car off?
  4. MashinA
    32
    It has come on in both cases. But i do believe it only comes on when the battery is discharged as an indicator.
  5. bisco
    52,792
    check the battery voltage in the morning at the jump point under the hood, before opening the drivers door.
    jerrymildred and Raytheeagle like this.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Which, I assume, includes planning ahead by unlatching the hood the night before and remembering to leave your keys inside the house and out of range of the car. My brake system pumps up if I even get close to the car.
    SFO and bisco like this.
  7. bisco
    52,792
    that must have been added on the '13.
    jerrymildred likes this.
