12v Battery advice: recharge, replace, etc?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by fpfpfpfpfp, Mar 24, 2021.
  1. fpfpfpfpfp
    fpfpfpfpfp Junior Member
    United States
    The battery was tested at a shop and they said it was still good (according to their device) just recommended that i drive it/power it more often so, not buying a battery for the time being.
    (but, according to a link posted earlier in this thread, 'truestart' is [also] oem. fyi)
    thx tho!
  2. fpfpfpfpfp
    United States
    understood. thx.
    juggling a lot of other time sensitive things, as well... but, will try to look into this asap. any brands/models you recommend? acceptable price range to spend? and, new or used?
  3. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    @fpfpfpfpfp I have a cheap Midtronics tester that doesn't work well. The shops and auto parts stores have much better ones is what I meant. You should be good. I would not drive more just get a charger/maintainer as mentioned and recharge the battery occasionally.
    moto g(7) power ?
    fpfpfpfpfp likes this.
    52,863
    ctek is excellent, but most anything on amazon from $25-50. will do the job. you want settings for agm batterry 4 amps or less.
    fpfpfpfpfp and Air_Boss like this.
  5. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    Do you have the v Five ATP or an upgraded or aftermarket camera/head unit? The 2012 v Five has no parking lines.
  6. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Ahh, must be the ATP. My apologies for the mixup.
  7. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    I did the same thing 3 years ago..... but I didn't need a battery. It was the invertor.
  8. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Well, decided to search what types of adapters are available to connect that U1 battery up. I could not find a direct U1 flag to pencil terminal. I did find U1 flag to top post, then you can use the SAE to pencil post (JIS). Pretty sure your uncle could help. For me as long as it doesn’t involve soldering I could as well.
    Just for future reference....
  9. koco
    koco Member
    113
    38
    Las Vegas
    If you got an AGM battery that is close to the same specifications, it will work the same as the "Toyota" battery that is made by Johnson Controls. AGM is just a type of sealed lead acid battery that the Prius charging system is designed for. The car won't know the difference. If you don't care about spending more money, then get an OEM battery.
    A digital battery analyzer can be had for around $20, and will save you a lot of guesswork and running around with all your car battery needs.
