12V battery alternative
Discussion in 'Prius c Technical Discussion' started by Redjohn, Jun 26, 2022.
  1. Redjohn
    Redjohn Junior Member
    Has anyone replaced the 12V battery with a VLRA AGM sealed battery, which is available from EBAY for $82 instead of $240 for an OEM battery? I recognize that the VLRA battery has gelled electrolyte and likely wouldn't work at very low temp, but I'm retired and don't go out if it's real cold.
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    some have and got good results
  3. DavidK52
    DavidK52 New Member
    Middle East
    I was thinking about putting batteries outside, but I'd prefer them to fit inside the unit. As a result, other chemistries with higher energy densities are being considered. I wondered if there was anything nearby that would still work.
