12V Battery Cable help ASAP
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by priuspubescent, Nov 16, 2020.
  1. alftoy
    alftoy Senior Member
    1,132
    520
    Saskatchewan, Canada
    Why are you worrying before even trying to remove it?
  2. ChapmanF
    19,056
    While that attachment does come from the repair manual, you also find in the repair manual that those "standard" values are only for use when the thing you're tightening does not have a specific torque shown in the part of the manual that's about tightening that thing.
    The specific torques given throughout the manual can take many more factors into account—what materials are being joined, what's between them, what's the purpose of the joint, and so on—than the "standard' charts in the front.
    alftoy likes this.
  3. alftoy
    1,132
    520
    Noted, HV battery fastener torque values are quite different.
  4. Likeawind
    Likeawind Member
    109
    Houston
  5. Likeawind
    Likeawind Member
    109
    Houston
    Why did they give me the big socket? It’s already present in the my old battery
  6. alftoy
    1,132
    520
    Use the new one, why would you use anything from the old battery if the new battery has all the parts, just move the electronics.
  7. Likeawind
    Likeawind Member
    109
    Houston
    I just finished striping the electronics, what should be torque spec for that power socket?
  8. Likeawind
    Likeawind Member
    109
    Houston
  9. alftoy
    1,132
    520
    48 inch lb
  10. Likeawind
    Likeawind Member
    109
    Houston
    Thanks
  11. Likeawind
    Likeawind Member
    109
    Houston
    Wonder why the battery number is different. I hope dealership won’t make a fuss about returning G9280-47110 as a core. This is the original battery came out. They gave me G9510-47031.
  12. Likeawind
    Likeawind Member
    109
    Houston
  13. Likeawind
    Likeawind Member
    109
    Houston
    All done, fuel economy is fluctuating with stop and go, is that normal?
  14. dolj
    dolj Senior Member
    8,655
    4,406
    Wellington, New Zealand
    How are you monitoring this fluctuating fuel economy? Via the consumption screen, the Energy screen, or something else?
  15. Likeawind
    Likeawind Member
    109
    Houston
    Energy screen
  16. dolj
    dolj Senior Member
    8,655
    4,406
    That is not really the screen to use, that shows instantaneous MPG, so of course it will fluctuate as the energy demands change second by second.
    The screen you want is the Consumption screen.
    When you fill the tank up and press the Reset button it will zero the average MPG and the miles driven so in the beginning this will fluctuate too. It usually starts very low and then gets higher and closer to your true average for the current tank as you put the miles on.
  17. Likeawind
    Likeawind Member
    109
    Houston
    Thanks, I will switch. Is that the screen most people usually have it on all the time?
  18. dolj
    dolj Senior Member
    8,655
    4,406
    I can't speak for everyone, but I actually have the Energy Monitor screen most of the time and occasionally flip to the Consumption screen briefly from time to time to check the average MPG (L/100km in my case). I get more information from the Energy Monitor. But that's just me.
  19. Likeawind
    Likeawind Member
    109
    Houston
    MFD blew second time, wonder why?
  20. alftoy
    1,132
    520
    Brian1954 likes this.
