12V Battery Cable help ASAP
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by priuspubescent, Nov 16, 2020.
  1. Likeawind
    Likeawind Member
    109
    Houston
    And now red triangle and ABS sign popped up. I’m so frustrated
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Brian1954 likes this.
  3. Likeawind
    Likeawind Member
    109
    Houston
    Sorry my bad, it’s not the ABS sign it’s the circle sign with with an exclamation sign. I think the battery is working ok because this time I didn’t have a loss of power and no loud fan kicked in. All signs are indicating toward the inverter, here we go again lol. I still have lot of patience haha to deal with this problem. I guess this car is teaching me how to keep cool :LOL:. I will run the diagnostics and report back.
  4. Likeawind
    Likeawind Member
    109
    Houston
    I see no movement in the intervener coolant. I made couple of videos but don’t know how to upload them here.
  5. rjparker
    rjparker Tu Humilde Sirviente
    11,027
    6,916
    Texas Hill Country
    If you have a youtube video just post the link and make sure it is not Private in the youtube settings.
    Most likely the mfd or other load connected to the blown fuse is bad.
    I guess you are starting to see why spending a few hundred more would have been the right thing to do. The FIRST thing they would have done is read and diagnose your codes. You still need to do that.
    #145 rjparker, Mar 13, 2023
  6. Likeawind
    Likeawind Member
    109
    Houston
  7. Likeawind
    Likeawind Member
    109
    Houston
    Anyone had a chance to watch the videos I posted? Thanks
  8. rjparker
    11,027
    6,916
    Texas Hill Country
    I watched them. Sounds like something is very wrong with that clunking but it is hard to say because videos sometimes amplify normal sounds. Codes.
  9. Likeawind
    Likeawind Member
    109
    Houston
    It needs an inverter pump for sure because the reservoir is a Dead Sea.
  10. Brian1954
    Brian1954 Senior Member
    2,665
    1,066
    South Central PA, USA
    What are the trouble codes!!!
    Until you read and report the trouble codes, the only thing that people can do to help is to guess what your problem is. You should have read the trouble codes before you purchased the new HV battery.
  11. Likeawind
    Likeawind Member
    109
    Houston
    Dealership told me first diagnostic is free so taking the car in today. Will report back when I get the car.
  12. dolj
    dolj Senior Member
    8,633
    4,387
    Wellington, New Zealand
    The second video clearly has a coolant control valve (CCV) "seeking but not finding" and so it is constantly seeking forwards and backwards. You need to replace the CCV.
  13. Likeawind
    Likeawind Member
    109
    Houston
    Thanks, that clicking noise is for seeking and not finding?
  14. Likeawind
    Likeawind Member
    109
    Houston
    Dealership said it needs both coolant pump, how hard it is to replace the main engine coolant pump?
  15. Brian1954
    2,665
    1,066
    Can you please tell everyone the exact trouble codes that the dealership found? This would be very helpful so that others can give you some advice how to proceed.
    I have read that there are 3 or 4 different cooling pumps used on a Gen 2 Prius.
    Please list all the trouble codes!
    #155 Brian1954, Mar 17, 2023
  16. alftoy
    alftoy Senior Member
    1,132
    518
    Saskatchewan, Canada
    No estimate sheet from dealer? Main engine coolant pump, meaning water pump, CHS tank pump ?
    Google
    Prius replace coolant control valve
    Prius replace inverter coolant pump
    #156 alftoy, Mar 17, 2023
  17. Likeawind
    Likeawind Member
    109
    Houston
    I will post the codes after I pick up the car from the dealership this evening.
    They called me this morning and gave me a brief description of what it needs.
  18. Likeawind
    Likeawind Member
    109
    Houston
  19. Likeawind
    Likeawind Member
    109
    Houston
    They didn’t give me the codes so I asked them for some sort of paperwork so they gave me Repair estimate sheet.
    I have ordered most of the parts already. Should I buy original water pump as well or after market is ok?
    I will replace the inverter coolant pump and water pump.
  20. alftoy
    1,132
    518
    Original Toyota parts, aftermarket don't last.
    G9020-47031 Engine Cooling Inverter Water Pump
    16670-21010 Coolant Control Valve Coolant Water Valve
