12V Battery Cable help ASAP
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by priuspubescent, Nov 16, 2020.
  1. Likeawind
    Likeawind Member
    109
    Houston
    I have ordered a genuine inverter coolant pump, was questioning about the engine water pump.
    I’m confused about the second pump. Where does this one go? What’s the difference between G9020-47031 & 16670-21010?
    Also can I use the Lisle funnel to bleed the inverter coolant pump?
    Best way to drain the engine water pump? Is it by the driver’s side under the bumper?
    #161 Likeawind, Mar 19, 2023
  2. alftoy
    alftoy Senior Member
    1,132
    519
    Saskatchewan, Canada
    Estimate shows required part numbers, have no idea where you see engine water pump.
    Google or search PC
    Prius replace coolant control valve
    Prius replace inverter coolant pump
    Prius bleed inverter coolant pump
    #162 alftoy, Mar 19, 2023
  3. Likeawind
    Likeawind Member
    109
    Houston
    Update! I have drained the inverter coolant, waiting for the pump to arrive. Car is sitting on the ramp, will drain the engine coolant as well to replace the other coolant pump Anything I can do to speed up the process or prep up in the meantime? Oh one more thing, will replace the serpentine belt today. Will probably swap the spark plugs as well. I watched a video where the guy didn’t unplug the coils just removed the bolt and replaced the spark plugs, the hardest one to swap is the last one from the right I guess. Recommended spark plugs pls?
    #163 Likeawind, Mar 22, 2023
  4. dolj
    dolj Senior Member
    8,646
    4,397
    Wellington, New Zealand
    Probably ok to do as long as you're not putting any undue strain on the cable of each plug. If you can't get the plug out easily with the cable attached then you are as well to just unplug the coil, it only takes a couple of seconds after the first one where you figure out how the unlocking mechanism works. In any case, it's not rocket science.
  5. Likeawind
    Likeawind Member
    109
    Houston
    I’ve replaced both pumps and took it for state inspection, they said there is an error code for inverter pump failure which I just replaced. He cleared the code and asked me to drive for 100 miles. Does the code go away automatically when the pump was replaced and it has be erased? There are no lights on the dash.
  6. Longinus876
    Longinus876 Member
    105
    Long Island
    '05 Prius, no smart key. Broken thin single wire at pos terminal.
    I broke a wire (accidentally). It was that very thin one with the small white plastic housing that plugs into the pos side of the battery (the black plastic housing).
    Could you tell me what that is and what I should do about fixing or not fixing it. If we start there, this could get interesting.
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Pretty sure that is the voltage sensing line for the inverter circuit that charges the 12v battery. Although there's many ways to jerry rig it, an easy option is to grab one from a salvage yard, just cut the wire far back as you can to make it easy to splice.
    That small plug connects to a busbar inside the plastic which connects to the (+) terminal. It also has a 5 amp fuse in the circuit.
    It can easily be made to work just by adding a length of wire to the broken wire and then connecting it to the (+) terminal. I wouldn't use it as a permanent repair, but only long enough until you get the piece to fix it properly.
  8. ChapmanF
    19,025
    That's the voltage sense wire. It lets the DC/DC converter under the hood put out the right voltage for the 12-volt battery, by measuring it right at the battery to sidestep the voltage drops along the current-carrying wires.
    If I remember right, a gen 1 would pretty much ignore having that wire disconnected (its converter would just make a reasonable guess what voltage to put out), but a gen 2 cares a little bit more and may set a trouble code. (There is also a 5-amp fuse in that black plastic housing that goes with this sense wire; sometimes people doing a jump backwards will blow that fuse, which of course sets the same code. Sometimes a mechanic will see that trouble code and try to sell you a whole inverter instead of a 5-amp fuse.)
    I would pick up the correct repair terminal at a Toyota dealer, splice it to the broken wire, insert it in the plug, plug it back in, make sure the 5-amp fuse is good, and call it a day.
    For more on how to get the right terminal and do the splice repair, see, for example, this post.
    Yes, picking up the complete plug and adequate length of attached wire from a salvage yard is another way to get it. The mechanics of splicing it on are the same either way.
  9. maleko
    maleko Member
    102
    36
    Central FL
    My sense wire just gave up the ghost the other day from all the plugging/unplugging while troubleshooting my recent issues.
    I used a dental pick to remove the metal pin tip from its plastic housing, cut a piece of 22AWG solid copper wire w/PVC insulation. stripped the tip, laid it right over top of the old factory (stranded) wire (I couldn't manage to open up the crimp wings without risking damaging the structure/integrity of the delicate pin body itself or stabbing myself), fluxed and soldered the 22AWG solid wire using my TS-100 [portable] iron, threw a couple layers/sizes of heat shrink on, then soldered my home-made pigtail onto the main portion of the sense wire coming out of the harness junction.
    Not factory, but should last plenty long for the amount of life my Prius has left in it.
  10. Longinus876
    Longinus876 Member
    105
    Long Island
    Can you identify the wires connected to the plugs?
  11. ChapmanF
    19,025
    There's only one wire connected to the smaller, voltage-sense wire plug. It's the voltage sense wire.
    The single heavy-gauge wire connected to the other, larger plug is what carries the power between the battery and the rest of the car.
  12. Longinus876
    Longinus876 Member
    105
    Long Island
    How'd you make out finding that Prius battery cable/terminal? I heard someone say to call Toyota America or something like that. They seem to be helpful. The Toyota dealers just seem to wanna gouge the hell out of us. I don't know what the story is but I try to stay away from them. My closest one can't even be trusted to do an oil change properly, and then argues when I complain. Try calling that Toyota number and see where that leads. I'd give you the one off my car but I kinda need it. Best of luck.
