12v battery charged by traction battery while off?
Discussion in 'Gen 3 Prius Technical Discussion' started by Terrell, Dec 22, 2019.
  1. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    I've been having a discussion with someone who claims that the 12v battery gets charged by the traction battery even when the car is fully off. My experience is that when the car is off, it's off. When the "Ready" light is on, then the traction battery will charge the 12v battery.
    This is based on my experience of:
    1) Having the headlights on overnight, which caused a low battery alert (below 11.8v).
    2) Forgetting to turn off the overhead lights overnight, which drained the 12v battery so far nothing worked. I had to charge it a bit before the car would start (the 12v needs only enough to run the electronics, the traction battery then starts the car).
    3) Plugging in a 12v refrigerator on a camping trip, which drained the 12v battery enough over three days that the low battery cut-off in the refrigerator shut the refrigerator down, and food had to be tossed, but the 12v had enough to start the car.
    Question: Do some versions of the Prius (later Gens) charge the 12v from the traction battery while the car is fully off? I don't think so, but I may be wrong.
    52,877
    you are correct, none charge the car when off. the two plug ins do charge it while plugged in and charging. but not after charging is done.
    Pluggo likes this.
  3. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    Thanks. That's what I thought.
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    That person should come here and read all the posts about “replacing the low voltage 12v bat with a new one fixed the problem.”
  5. psusi
    psusi Junior Member
    68
    24
    Orlando, FL
    Yea, there is a relay in the HV battery pack that only energizes the high voltage system when the car is in READY mode. This is for safety so someone can't get electrocuted or start a fire working on the car, or cutting into it with jaws of life, etc. If not for that then you wouldn't need a 12v battery at all.
  6. ChapmanF
    19,041
    On the other side of that coin, you'd need to find a 200 volt charger any time something got left on and drained the battery.
