12v battery / charging questions
Discussion in 'Gen 2 Prius Main Forum' started by misterdean, Jan 12, 2024.
  1. misterdean
    misterdean Member
    204
    29
    FL
    posted few months ago about 12v that kept dying. we did parasitic draw testing and determined that's not an issue. after charging the battery and testing it outside the car over a few days it was determined the battery was bad. i bought a new battery about 2 months ago. i tested it yesterday while in the car and saw 11.8. i just charged it, 12.83. i'm going to daily test it outside the car for a week. i'm assuming it's going to drop a bit, wondering how much should i expect it to drop? i know there is no alternator, but also wondering if whats charging the battery is a problem. i believe it's a motor in the transaxle, what is this part called, and is there a way to test that?
  2. Tombukt2
    Tombukt2 Senior Member
    13,809
    2,504
    Durham NC
    Yeah the motor generator that does the generating generates the 211 volts to charge the HV battery The HV battery when the car is ready sends power to the inverter the thing up on top of your transmission right under your nose when you open the hood that has a circuit in it that takes 211 volts and inverts it or changes it to 14.5 volts DC to charge the battery That's why when you're sitting there with the battery in the car hook connected and you hook up your test meter and the car is not on ready or running you see battery voltage let's say 12 volts You leave those terminals connected to your DVLM and sit it up on the back headrest so you can see it get in the car and ready the car the minute you ready the car you see the 12 volt battery voltage where your test leads are connected immediately jump up to say 14.3 to 14.5 volts something like that then if you push the button again and turn the car off that 14 disappears and immediately turns back to right around 12. That 14 you're seeing when the car is ready is the circuit charging your car and if it's doing like it's stated here it's probably in great shape nothing further needs to be checked need to deal with the battery itself the terminals connections whatever could be just a crappy battery that's very easy and very normal little short trips starting the car and going nowhere Prius is not happy with that that's just a fact Make it a 20 minute trip or something along those lines maybe the Prius is not the best choice and best fit for your driving needs That's a great possibility.
  3. misterdean
    misterdean Member
    204
    29
    FL
    had to use the car, i tested the battery before putting it in the car - 12.79. drove the car for 30 minutes, took battery back out and tested - 12.9.
    52,776
    start with a free load test of the battery at auto zone.
    once confirmed good, it should barely drop at all out of the car for a week.
    to check the charging circuit, measure the battery with the car ready. it should read 13+ to 14+. and will fluctuate as the battery needs charge.
    if all passes, check the battery with in the car with the car off every morning until you get a handle on how fast it's draining.
  5. misterdean
    misterdean Member
    204
    29
    FL
    will do that testing you suggested, thanks for tips.
    i asked about a load test at 2 different places with the last battery. both of them looked at me puzzled and told me they don't know what i'm talking about. they only have the little hand held device.
  6. bisco
    52,776
    sorry to hear that, i hope one wasn't auto zone. either way, might make sense to call ahead, and a load tester is a hand held device:
    ref=asc_df_B000AMBOI0
  7. misterdean
    misterdean Member
    204
    29
    FL
    i see the description says it tests CCA. is that the only difference between my volt meter and a load test? that device at one of those shops did test the CCA.
  8. bisco
    52,776
    yes, it's check available 'cranking amperage', as if it were trying to start an engine with a starter motor, even though prius uses the hv battery. the starting load on the 12v is pretty light.
  9. pasadena_commut
    pasadena_commut Senior Member
    3,011
    937
    Southern California
    When testing 12V batteries after use it is important to remove the surface charge before measuring voltage. Otherwise the readings are not very meaningful. Also on this car (in particular) the computers do all sorts of things for quite a while after the car is "off" and those loads can change the voltage if present during testing.
  10. misterdean
    misterdean Member
    204
    29
    FL
    not sure what you mean remove the surface charge. you just telling me to wait a certain amount of time after turning the car off? how long?
  11. bisco
    52,776
    about 4 hours, or turn the headlights on for a minute or two.
  12. pasadena_commut
    3,011
    937
    Southern California
    BU-804c: Acid Stratification and Surface Charge - Battery University
    Wait 4 hours or overnight. Another wrinkle is that the car wakes up if any of the doors are opened and that pulls a current out of the 12V dropping the voltage (slightly). So to measure it without that complication one must leave the hood released, then open it fully (without touching the fob or opening a door or hatch) and measure at the jump point in the fuse box behind the driver's side headlight. To measure directly at the battery the hatch has to be left open (easier than crawling in through an open window), which normally counts as a "door open" state and will run down the battery. To avoid that, jam an appropriate sized carabiner into the slot where the loop on the hatch normally goes. If done right the latch will audibly "click" and the car will think the hatch is closed because the hatch lock is engaged. To release the carabiner press the button on the hatch as one would normally do to open it. Be really careful not to try to close the hatch with the carabiner in place!
  13. misterdean
    misterdean Member
    204
    29
    FL
  14. bisco
    52,776
    sounds like your good. just check it every morning until you're comfortable.
    best way is to pop the hood the night before so you don't turn anything on in the morning before testing.
    if you can't do that, lean in from the passenger side, that only turns on the interior lights.
  15. pasadena_commut
    3,011
    937
    Southern California
    Passenger door open is 500 mA draw from the 12V with the car off and the car unlocked (for a "long" time). Unlocking the car with a fob right before the door is opened might wake up some computers for a while.
  16. misterdean
    misterdean Member
    204
    29
    FL
  17. bisco
    52,776
    Sounds good
  18. misterdean
    misterdean Member
    204
    29
    FL
    want to keep track of it so i can compare when it's back in the car. i'll put it all in the last post so this doesn't top post every day.
  19. Mendel Leisk
    42,266
    Just start an off-line log; the ability to edit a post only lasts a few hours.
    Too: voltage is just the tip of the iceberg. I'm using the "conductance tester" shown in this video:
    Current iteration is Solar BA9.
    #19 Mendel Leisk, Jan 14, 2024
  20. misterdean
    misterdean Member
    204
    29
    FL
    it finally bottomed out and i got the same reading 2 days in a row. going back in the car today.
    12.77
    12.74
    12.73
    12.72
    12.72
