12v battery / charging questions
Discussion in 'Gen 2 Prius Main Forum' started by misterdean, Jan 12, 2024.
  1. bisco
    52,776
    looks good. will be interesting the next few days
  2. misterdean
    misterdean Member
    204
    29
    FL
    12.44 car off trunk open
    12.38 accessory mode
    12.25 ready mode
    13.97 engine running
    12.54 after after 7 hours doors locked crawled through window
  3. misterdean
    misterdean Member
    204
    29
    FL
    does that look normal? going from 12.72 to 12.44 with the car off seems like a big dip.
    52,776
    can you clarify the timeline in post 22?
  5. misterdean
    misterdean Member
    204
    29
    FL
    i tested the battery in my home and it was 12.72. since i got 12.72 two days in a row i put the battery in car and did all those tests immediately after except the one where i waited 7 hours.
  6. bisco
    52,776
    so it dropped from 12.72 to 12.44 after you hooked it up?
  7. misterdean
    misterdean Member
    204
    29
    FL
  8. bisco
    52,776
    so that's everything in the car powering up that normally stays powered up with the car off.
    that it continues to drop as more things get powered up through the mode transition, the the inverter kicks in and is charging the battery, then it settles into a resting voltage at 12.54 and there will be a continual drain with the car off.
    so you want to start with the 12.54, and check it each morning before starting the car to see how much it drains each day.
    a good battery won't fall much from the 12.54 over a week or so, but a tiny amount every 24 hours.
    and if you drive everyday, it should hold at the 12,54
  9. misterdean
    misterdean Member
    204
    29
    FL
    correct. hooked up the battery and then proceeded to test in the order listed. i know there is going to be drain on the battery. i just wasn't sure if that amount that quick was concerning.
  10. bisco
    52,776
    i can't say how much is normal. most likely, the weaker the battery, the more it drops on load.
    that's why a load test is the final word.
    but more importantly, it's how the 12.54 holds up now.
  11. misterdean
    misterdean Member
    204
    29
    FL
    12.54 was crawling through the window after 7 hours. i can't do that test daily cause i don't have a garage and i can't leave my window down for a week. my daily tests have to be like the first one, car off and trunk open.
  12. bisco
    52,776
    rereading your first post to refresh my memory, i see it's a new battery. if it's agm, it should have been at least 12.8 volts so i would say it's lost a little something already. does it have a date on it?
    and 12.54 is definitely too low for a new battery in the car. mine was still reading 12.7x in the morning after a few years. but it's garaged in a fairly mild climate. heat does a number on them.
  13. misterdean
    misterdean Member
    204
    29
    FL
    it is AGM, the one that's suppose to be in it S46B24R date 10/23.
    i thought 12.7X was low after a fresh charge. i read a few threads that said a new battery should be in the 12.8-12.9 range. i also read a few threads that said batteries that were several years old sat in their car that wasn't driven at all for 3-6 months and started right up. mine is brand new and 11.8X in 2 months with light driving.
    #33 misterdean, Jan 18, 2024
  14. bisco
    52,776
    are you using a charger with agm capability?
    misterdean likes this.
  15. misterdean
    misterdean Member
    204
    29
    FL
    yes
    good thought
  16. bisco
    52,776
    did you get readings yesterday and this morning?
  17. misterdean
    misterdean Member
    204
    29
    FL
    yes sir, was waiting until i have more results.
  18. Mendel Leisk
    42,265
    Reading voltage gives very little indication of the battery’s resilience; consider a conductance test. Watch video in post #19.
  19. misterdean
    misterdean Member
    204
    29
    FL
    i watched the video. i understand voltage is only half the story. the same can be said about the CCA. when i was messing with the previous battery, i took it to a shop, they tested the CCA and the voltage. it passed, and the shop told me the battery was good. the CCA was actually slightly above what it was rated at. it wasn't until i tested it daily and you guys saw the voltage dropping that it was determined to be bad. i will be bringing it to a shop for a load test the next time i'm using the car. i'm willing to be thorough. daily tests is part of being thorough.
    #39 misterdean, Jan 19, 2024
  20. misterdean
    misterdean Member
    204
    29
    FL
    nobody has said anything about it, but something that has been on my mind. my first test with the car off and the trunk open, was 12.44. but the last test, crawling through the window, came back 12.54. does this not seem strange to anybody? i know i had the engine running for the previous test, but it was only running for a full minute at the most, and 7 hours had past so surface charge was gone. is going from 12.44 to 12.54 in a minute normal? that seems like a significant bump for such a small amount of time.
