12V battery charging
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by lpf, Jun 1, 2020.
  1. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Thank you for your understanding!
    I wish I could say the state of my country is "civilized" right now, but sadly not.
    I did notice you said voltage drops below 13.0 V while the car is in motion. (If I read your post correctly). This is a concern.
    EDIT-. I think you mean acc mode shows 12.3 V. That seems okay to me.
    Do you have the battery model/specifications? Is it AGM or (flooded) lead acid?
    moto g(7) power ?
    #21 jzchen, Jun 2, 2020
  2. Mendel Leisk
    42,320
    Electronic load test, then charge or replace, depending on test results.
  3. lpf
    lpf Member
    139
    39
    Greece
    We often hear that police made this or that, killed a boy or a man etc. I believe that you have to start from prohibiting possession of weapons, and then educate the police stuff.
    Now, back to our subject, no, all measurements made with the diagnostics procedure when the car was static (sorry for my bad English).
    The battery is a sealed flooded one.
    diplomatic likes this.
  4. Mendel Leisk
    42,320
    With the car "on", using the dash displays? Virtually meaningless.
    At the least: measure the battery voltage with a digital volt meter, first thing in the morning, with the hood popped the night before (if possible). If it's not possible to leave the hood unsecure, pop it in the morning, but go in through the passenger door, to avoid waking the car up, as much as possible.
    Better: assess the battery with an electronic load tester. These must be clamped to the battery posts, check the voltage AND determine the battery's CCA (Cold Cranking Amps). While the Prius battery doesn't "crank", this measurement is still the best for determining the battery's health. These testers typically will have you set up various parameters, the battery type, the CCA spec, then you do the test, and it'll give a verdict, how viable the battery is.
    In North America an example of such testers is Solar BA9. Dealerships, aftermarket retailers of batteries, usually have a pro-level tester of that ilk. The aftermarket retailers will likely run such a test for free, hoping to get your business if you do need to replace.
    Jess Sullivan likes this.
  5. lpf
    lpf Member
    139
    39
    Greece
    Have I to disconnect the battery cables before any of the tests? Thanks
  6. Jess Sullivan
    Jess Sullivan New Member
    New England
    Wow, never considered a load tester, looks like these go for ~$50. This would have saved me pretty much my whole weekend angrily fuzzling at my multimeter xD
  7. Mendel Leisk
    42,320
    No. Toyota does say to disconnect before charging, but I've never done that, no problems.
    Do look into smart chargers too, if car has lots of down time.
  8. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    15 hrs per day or week should be enough to maintain a healthy 12v battery, be it AGM or flooded.
    Always keep the vehicle in 'Ready' or OFF, never is accessory or standby.
  9. Jess Sullivan
    New England
    Flooded for Prius through? I've assumed the gen ii has a harder time maintaining flooded batteries, thus AGM. Anyone tried?
  10. lpf
    lpf Member
    139
    39
    Greece
    Hey, I'm not a taxi driver, it is 15h a week!
    Just opened the boot and measured with volt meter, shows 12,49V. I will repeat first thing in the morning and get back to you.
  11. Mendel Leisk
    42,320
    A battery in good shape will usually show CCA well above spec. When they're getting on the CCA will start to drop, and the at-rest voltage. If (for example) rated CCA is 325, and the battery's testing at 375~400 CCA plus volts around 12.7, it's in the pink. If it's 275~300 and voltage inexorably dropping, to around 12.3~!2.4, and the tester's saying viable but recharge needed, or fail, it's time.
    The tester will show this, and a verdict, either "good", "good but could use charging", or "fail". I'm paraphrasing, it's something like that. After hook up you need to enter a few stats, the rated CCA and battery "type". There's a sticker on the back clarifying which is which. I use previous Solar BA5, similar tester. Dealerships and automotive retailers will have pro-level of the same ilk, more robust, full featured and often capable of thermal printout. But prosumer like BA9 are fine for DIY'r.
  12. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
  13. lpf
    lpf Member
    139
    39
    Greece
    Morning results: Volt meter #1 12.38V & volt meter #2 12.28V.
  14. Mendel Leisk
    42,320
    That's "moderately" low. Coonsidering it's only 18 months old I would try charging first. Even you ultimately need to replace, it's worth a try, and an appropriate smart charger, used regularly, would be good for maintaining the next battery. Look for a charger around 3.5 max rating.
  15. lpf
    lpf Member
    139
    39
    Greece
    Looking now for a tender/charger. Thanks
  16. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    One does not need a tender that claims to be "AGM compatible".
    They are all compatible enough.
    And it won't charge very fast in "ready" mode.
    Not necessarily a good idea to leave it that way for 12 hours or more.
  17. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    A smart charger will limit the current as needed, and is recommended for AGMs.
    How fast is very fast, and what do you feel is a safe continuous amperage to charge at which includes "very fast" as an end goal?
    Though it could've been overlooked, not sure anyone mentioned 12 hours or more o_O
  18. sam spade 2
    7,035
    2,804
    2017 Prius c
    No, I'm not taking the troll bait.
    Charging a battery "very fast" is NOT a good thing to do.
    Toyota recommends no more than 4 amps, I think......but a bit more than that should be OK for a short time.
    A completely dead (or almost so) 12 V car battery might take 12 hours or more to charge at the recommended 4 amps max.
  19. lpf
    lpf Member
    139
    39
    Greece
    Update
    After many volt meter readings the conclusion is that the battery is around 12.24V, verified also with the Torque app (OBD II connected when car was powered off). After all measurements I tried to see what the MFD diagnostics screen says, every time the reading was around 11.8V, I don't know why.
    I found a two functions device, tester and charger with bluetooth app and I'm going to get it to test and charge. The only think is that how this tester works and calculates CCA and charging state , because actually there is no alternator or cranking.
  20. Mendel Leisk
    42,320
    The car is using the battery in the process of displaying it's "diagnostics", in short: it's less than useless: it's only displaying volts (not testing Cold Cranking Amps), and it's drawing down the volts in the process of measuring them.
