12V battery died after 8 years
Discussion in 'Generation 1 Prius Discussion' started by bwilson4web, May 3, 2017.
  1. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    I think the skinnier posts are called JIS. JIS (if that's what they're called) battery connectors are hard to find in the US. One can get adapters tho.
    My battery came today. I had a ground wire already made and bending and grinding the positive lug, bolts onto the battery post connector, did the trick. It's in, I ended up putting the foam padding on top. Bob and I are the test subjects, aka guinea pigs, for these batteries. I think they'll have a pretty limited service life just because they aren't built to automotive standards. Who knows, I could be wrong.
  2. bwilson4web
    16,552
    Near as I could 'Google', they should have thicker plates as the automotive versions have to deliver peak current for the starter, the CCA. Also, these should be more tolerant of deep discharge. So I'm of the opinion, let's give them a try.
  3. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
