12V Battery Died after a surprisngly short time...
Discussion in 'Prime Main Forum (2017-2022)' started by stevepea, May 3, 2020.
  1. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    Well, I've only had my Prime for about 14 months, but I've never heard any fan run when the car is off and it isn't being charged. If fact, if I've been driving in hot weather, I'll often hear the fans running when I stop the car. (Prime & PiP have two battery fans.) When I shut off the car, the fans stop. I'd rather they ran a little while like the radiator fan did on my last motorcycle when I shut it off.
    benagi likes this.
    51,948
    mendel has it right. it runs about four hours after shutting the car down. not sure for how long, never timed it.
    many people have commented on it over the years. i'm not sure prime has it, just assuming.
    but other than that, i can't think of anything the 12v would run with the car off, except the usual suspects
  3. CraigCSJ
    CraigCSJ Active Member
    287
    144
    San Bernardino, CA
    1. no, I usually hear the fan in afternoon when the car is off and the traction battery charger is plugged in but not actively charging. My routine is to plug in charger when turn off car but set it to be charged by 7:00 next morning.
    2. If a fan is operating, it would be 12 volt and drawing down the 12 volt battery unless the car was in ready or perhaps being actively charged.
  4. ChapmanF
    18,214
    I like that this is actually on page 8 of the manual. According to one of my mom's stock phrases, that would mean Mendel does know his @ss from page 8. (The phrase is usually about somebody who doesn't.)
  5. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    From all the information available, I really don't think what you heard is the traction battery cooler fan running. There is no mention in the manual that this fan running when the hybrid system is off and not being charged. Even if it was the traction battery fan, it would be hard to believe, the fan would run from traction battery power in one operation mode and then from 12v power source in a different time. A fuel evaporation leakage check mentioned above maybe the noise you heard. That I believe only happens once after you turn off the car, not every day, and having the 12v battery disconnected would not hurt the car if this function is not running.
    That being said, I do not like the idea of disconnecting 12v, for it would erase some data in ECU and requires re-initialization when you re-connect. Keeping the 12v battery connected and putting it on a maintainer would be preferable.
    jerrymildred likes this.
  6. bisco
    51,948
    according to o/p's post 59, he's not going to buy anything aftermarket, so, short of running the car often enough to keep the 12v charged, disconnecting the neg until the car is needed may be worth having to reset a few unimportant functions.
    Salamander_King likes this.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    You have no way of knowing what is REALLY happening with the batteries and charging at a time like that.
    If it is plugged in, it could be supplying 12 V charging current without telling you about it.
    Assumptions are often wrong.
  8. bisco
    51,948
    it has been established that a minimum amount of charging of the 12v takes place while the hybrid battery is wall charging. much less than the pip, for what reason has not been established.
  9. jerrymildred
    11,517
    14,152
    Tampa, FL
    I'm sure that's true. But that would make this car behave differently than other cars in that regard. That would lead to unnecessary confusion.
  10. stevepea
    stevepea Senior Member
    535
    581
    Update: Thanks for the replys, everyone (though it seems to have gone off in a different direction).
    Because the car was literally just days out of warranty I called Toyota. They worked out something with the dealer. Got the car jumped and 2nd time, took it to the dealer, where they performed tests on the battery. Said it doesn't need replacing, just needs to be re-charged, which they did for me as a courtesy.
    Some thoughts:
    (1) The first time I needed a jump the lights were flickering and going crazy (but there was just a bit of charge left to at least have flickering, dying lights before it died completely). However just 6 days later, there was NOTHING. Not even a flicker. The first time I got a jump I didn't reset the clock. But just 6 days later for the 2nd jump, everything reset (12:00 clock -- and even the "check engine" light went on, I guess associated with complete power loss. Dealership turned it off).
    (2) Had I needed a new battery, dealer wanted about $348 out the door (incl tax) to install a replacement battery. Wow. Local mechanic I've gone to for years wanted $141 out the door for a decent battery brand (5yr warranty). Talk about rip off. Sicne it's offtopic, I might make a post about dealer markup elsewhere. I'm curious about some things, like if when a dealer is reimbursed from Toyota for in-warranty repairs, there's a set fee schedule (ie, what Toyota would have paid to the dealership for a battery replacement if needed vs what the dealer charges their retail customers)...
    (3) When AAA came to jump a 2nd time, it was from a BIG local towing shop that's been around for years. They offer batteries themselves for customers. But the Prime must use an unusual one, as he said "nope, this is one we don't carry ourselves." Found that a little disconcerting.
    (4) So now that it's charged, I'm not sure how often to take it out to keep it charged in a period where I don't need to drive the car at all. It only took 6 days to completely drain the battery after it had been jumped and driven 20mins. I know that's not a lot per se, but just 6 days to where it went so dead the entire system reset? Assuming it got a real good charge now from the dealer (it was plugged in for a couple hours), would taking it out once every 2 weeks for 20 mins be enough? Once a week for 20mins? It might be a few months before I actually need to use the car again (if I had needed a new battery I would've waited until the end of the summer and just left it parked in the garage). With no "real" or "actual" need for the car, what do you guys think is the minimum driving (assuming the 12v is decently charged now) to keep it from needing a jump again?
  11. Elt31987
    Elt31987 Active Member
    205
    155
    Derry, NH
    Grab a float/ smart charger and connect it to the battery once a week and let it fully charge. That's what I have been doing
    jerrymildred and Hicksite like this.
  12. Hicksite
    Hicksite Member
    176
    2020 Prius Prime
    I recommend getting a charger.
  13. Elt31987
    205
    155
    Derry, NH
  14. Salamander_King
    11,019
    8,954
    New England
    You don't have to actually drive the car. All you need is to start the car and let it sit at READY. If you charge up the traction battery prior to this, then the car does not need to run engine at all. In my experience with my 2020 PRIME, almost brand new 12v battery, 1-1.5hr once a week keeps the 12v battery charge above 12.4v, but each week, the SoC would be bit lower after charge. After 3 weeks, the resting voltage got lower than 12.3v, so I charged the battery fully using a smart charger. With your 3 years old battery that has been deeply discharged more than once, you may need more frequent and/or longer charges. If I were you, just buy a battery tender/maintainer and hook it up until you need to drive the car again.
    Mark57 likes this.
  15. Mendel Leisk
    41,463
    We're driving (our 2010 Prius) very infrequently, often just once a week. On the day after it's been driven I hooked it up to a smart charger (CTEK 4.3), in the car (no removal), and leave it connect 'till next time the car is needed.
    For convenience I've installed a quick connect, so I'm not dealing with alligator clips: make the connection, plug charger into wall, lower the hood, just ajar. I do have a secure garage, which helps.
  16. jerrymildred
    11,517
    14,152
    Tampa, FL
    I'm singing in the battery charger chorus, too. Sure, you can put it in ready now and then and charge it back up. If you remember. And then you have to check & see if it's charged enough. Royal pain in the patootie. Just hook up a battery tender type charger and get on with life.
    Hicksite and Mendel Leisk like this.
  17. Hicksite
    Hicksite Member
    176
    2020 Prius Prime
    Yep!
  18. sam spade 2
    7,035
    2,803
    2017 Prius c
    If I were you.......that would have been the FIRST sentence in my post instead of the last. :)
    And for the OP: Just because a shop tells you your battery is "good" doesn't necessarily mean that is true.
