Featured 12V Battery Died Suddenly
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Daniel Pincus, Jul 5, 2023.
  1. Daniel Pincus
    Daniel Pincus Junior Member
    NYC
    So, I arrive at my car this morning to discover that there's no electricity. I used the key to get in and open the rear door so someone could get in and dig down below the cargo tray to reach the battery and give me a boost.
    Two questions: could I have started the car without the jump, and why did the designers at Toyota not provide a low battery warning light?
  2. Doug McC
    Doug McC Senior Member
    1,087
    428
    Midwest
    2022 Prius
    If the battery was basically dead (ie: extremely low voltage), then no there’s no way you could have started the car. Since from your description you are talking about the 12 volt battery (not the actual “hybrid” or traction battery), you need 12 volt power to activate the relays that connect the hybrid battery to the Motor Generator to start the car.
    I don’t know about the 3rd generation, but my 4 generation has a charging system warning light that might help. But really, if you’re doing proper preventive maintenance then you should be checking the 12 volt battery periodically and pretty much know if it’s going to give you trouble.
    With your car being a 2013 and from your comments, I’m going to assume you still have the original 10 year old battery in it.
    Brian1954 and Daniel Pincus like this.
  3. Daniel Pincus
    NYC
    Thank you for your comprehensive answer. I did have the original 10 year old battery, until I changed it today.
    Doug McC likes this.
    52,891
    some people get warnings. i didn't, and idk what the software is looking at, that it sometimes works and sometimes doesn't.
  5. Brian1954
    Brian1954 Senior Member
    2,694
    1,077
    South Central PA, USA
    Yes you needed to jump start the car to get it running again or you needed to replace the 12v battery.
    FYI, you can jump start the car in the fuse box under the hood. Look at the car manual for more information.
    Doug McC and Daniel Pincus like this.
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Impossible to jump start the hybrid battery. Prius is not a smartphone that will alert you when battery is low.
  7. Daniel Pincus
    NYC
    I tried to edit the title of my post once I realized I was talking about the 12 V battery. Couldn't figure out how to do it.
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    :ROFLMAO: Too much to read syndrome :ROFLMAO:
  9. CR94
    CR94 Senior Member
    2,839
    1,244
    Northwestern S.C.
    Too much useless and irrelevant verbiage separating the occasional tidbits of useful information.
  10. rjparker
    rjparker Tu Humilde Sirviente
    11,140
    6,985
    Texas Hill Country
    1. The mfd display has a diagnostic screen with realtime 12v readings.
    2. A lithium jump box under the driver's seat will save the day.
    3. Knowing how to use both is key.
    #10 rjparker, Jul 6, 2023
  11. Kostomarov
    Kostomarov New Member
    Киев
    2012 Aqua
    The original battery is the best !!!
  12. Priipriii
    Priipriii Member
    231
    67
    I jump it from the front fuse box. Its the little red slot you flip up thats the + then ground it to whatever bolt you can reach in distance.
    The 12V battery tends to die if not used in a while. Especially being since the prius 12v is a lot smaller since its not used to power a starter.
  13. Doug McC
    1,087
    428
    Midwest
    2022 Prius
    Check your Owners Manual under the section “If the 12 volt battery is discharged” (or something like that, probably in section 7) for instructions on anything that may need to be reset to avoid strange electrical issues that might pop up.
    While the Manual is a little cumbersome, it does have a wealth of very useful information.
  14. Doug McC
    1,087
    428
    Midwest
    2022 Prius
    Don’t worry about it. If it bothers the Powers that Be it will get changed. Plus, it kind of helps separate useful responses from the not so.;)
  15. Mendel Leisk
    42,376
    How often do you use the car, and how long are your drives?
    How do you park, garage, parking lot of some sort, street?
  16. Tideland Prius
    16,683
    Fixed the title for you.
    Priipriii and Doug McC like this.
  17. Kostomarov
    Киев
    2012 Aqua
    I didn't know that parking space was important.
  18. Mendel Leisk
    42,376
    Was wondering if you're able to hook up a charger; I should have clarified.
