12v Battery drain and DOME fuse
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by LBH, Aug 13, 2019.
  1. LBH
    LBH Junior Member
    30
    San Jose, CA
    Need some advice for troubleshooting:
    2004 Prius 300K+ miles.
    Background problem: battery drain and cannot start if not driving for a few days.
    I hooked up a digital ampmetter in series with 12v battery ground terminal to check on the current consumption when the car is off. It is read 0.3A, then I removed each fuse to check for possible short. Only the DOME fuse (once removed) can reduce to 0.01A about 10mA.
    Checking all the interior lights and none was shorted.
    I thought i could leave the DOME fuse removed (not using lights) could solve the battery drainage problem. But to my supprise, i can't start the engine with this fuse removed. Seems like DOME fuse is connected to more than just dome lights.
    What should be my next step to diagnose the drainage problem and possible cause & solutions.
    Thanks in advance !!
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    When measuring current were all the doors closed including the rear hatch?
    Doors have lights in them when open.
    Also if your car has SKS key system you must turn it off using the button
    Under the steering wheel because if the fobs in your pocket near the car it wakes up the ant/radio system for the fob.
    Hundreds of posts over the years with people thinking there’s a draw on there 12 volt battery. Don’t think anyone’s ever reported they found one.
    Usually they have killed the battery and then jump started it and it came back to life but if you discharge to 0;volt lots of times it becomes sulphated
    And will not Hold a charge.
    Do a load test. Measure 12 bolt battery at front jump point with car off.
    Write that voltage down
    Then with car still off turn on headlights in high beam and leave on for 5 mins.
    At the end of 5 minutes with headlights still on what voltage is it reading now?
    LBH likes this.
  3. edthefox5
    10,096
    4,840
    Clearwater, Florida
    My 3 year old yellowtopdoes not drop 1 volt with the headlight test.
    LBH likes this.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    A third of an amp seems pretty high if it's an accurate reading and the car is in its normal "off" state. Are you certain that the dome/courtesy lights are actually off when the car's off?
    Another possibility, if the load measurement is not right for some reason, could be just an old 12V battery that's not holding a charge.
    LBH likes this.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Some things stay "hot" for a few minutes after turn-off and then shut down.
    As batteries age, they "self discharge" internally.
    That looks a LOT like an external discharge.
    Time to get your 12 V battery tested.
    If it is over 5 years old, probably should just replace it.
    LBH likes this.
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    With the car off, connect your meter as you had it for testing parasitic drain. Have the meter oriented so you can read it. Open the driver door and verify the courtesy light on the door bottom is on. Press the small button in the door jamb, see if the light goes off. Obviously, your current readings should change when operating the button. Try it again to make sure it works, but use the door this time. This courtesy lamp /button has been known to fail on.
    The black box next to your battery is a capacitor bank for backup power to your brakes. It also has been known to cause excess parasitic draw. With your meter connected as before, unplug the wire connectors to the box and see if the excess draw goes away. If so, sounds like a bad cap.
    LBH and jerrymildred like this.
  7. LBH
    LBH Junior Member
    30
    San Jose, CA
    Thanks all for your replies and suggestions.
    Few more info. which i did not mentioned:
    1. Battery is fairly new ( replaced couple months ago)
    2. Doing the voltage test on the MFD: 12.3v, acc on 12v, engine on 14.4v. Drop below 11.3v when not use 2-3 days.
    3. When i did the current draw measurements: SKS on/off make no difference, did also check door open/close still no difference.
    I will try other suggested tests and post findings soon.
    Thanks again.
    Somehow this board didn't notify me of any reply to this thread. I will check back regularly!
  8. TMR-JWAP
    6,404
    6,099
    Columbia, SC
    If you are measuring milliamp draw, with the car off, I would like to think the lower door courtesy light turning on/off WOULD make a difference. Was the light at the bottom of the door "on" with the door open? Did it turn "off" when you pushed the door jamb button in?
  9. sam spade 2
    7,035
    2,804
    2017 Prius c
    But if you have the meter set to the wrong function.....or to the wrong scale......you might not be able to SEE the difference.
  10. LBH
    LBH Junior Member
    30
    San Jose, CA
    I did checked again: it is still 0.01A when the DOME fuse removed (no change) and 0.3A with DOME fuse (no change) whether door open or close, and light on and off. My meter can't go to mA range to deltect small changes, but 0.3A vs 0.01A is alot. DOME fuse circuits might go to other places/device.
    Thank you
  11. LBH
    LBH Junior Member
    30
    San Jose, CA
    I normally wait few minutes till reading stable. Yes the light on/off didn't change the reading.
    I checked the black box cap suggestion but no changes either. Only remove DOME fuse will reduce the current draw.
    Thanks
  12. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Didn't someone have the same problem when one of the light bulbs in the door was burned out? I remember him saying he replaced the burned out bulb and the problem went away.
    LBH likes this.
  13. Patrick Wong
    18,213
    6,530
    LBH, are the doors locked when you are taking these current measurements?
    Yes, the DOME fuse feeds other circuits that need constant 12V. For example, the combination meter.
    Sharkey and LBH like this.
  14. dolj
    dolj Senior Member
    8,655
    4,406
    Wellington, New Zealand
    You would have to wait at least 20 minutes after all doors were closed and the make sure the key fobs are well away from the car before it will quiesce to 0.02 A.
    So set up your ammeter so that you can read it from outside the car without disturbing it, otherwise the car will wake up and current draw will be a lot higher.
  15. LBH
    LBH Junior Member
    30
    San Jose, CA
    Yes, i have extended the ampmeter lead wires so that i can read it outside. I will try with 20min wait. Thanks
  16. LBH
    LBH Junior Member
    30
    San Jose, CA
    Yes all doors are closed when talking these measurements.
    Do you have schematic diagrams for the DOME fuse? Where is the combination meter located? easy access?
    Thanks
  17. LBH
    LBH Junior Member
    30
    San Jose, CA
    All of my interior bulbs were replaced with LED, and they are all ok.
    Thanks
  18. Skibob
    2,912
    1,505
    Northern California
    But what if the circuit thinks the bulb is burned out due to the low draw of the LED bulb? Did the problem start after you changed out the bulbs to LED?
  19. VFerdman
    VFerdman Senior Member
    1,200
    1,221
    Western Massachusetts
    Combination meter is the display that shows your speed, odometer, etc. I hope you are able to find the drain. I have replaced my door and dome lights with LED and have has no issues with the battery dying, but I have not taken any measurements.
    LBH and Skibob like this.
  20. jerrymildred
    11,517
    14,171
    Tampa, FL
    While the doors are closed, the interior lights are off anyway, so they are not a factor once the timer turns them off. You could stick a wire in the socket and make a dead short and it wouldn't matter UNTIL you opened a door or otherwise activated the lights.
    There's a thought. Just because the doors are all closed doesn't necessarily mean the interior lights are off.
