12v Battery drain and DOME fuse
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by LBH, Aug 13, 2019.
  1. Patrick Wong
    18,210
    6,513
    The car must be locked as well, to ensure the lowest possible quiescent current draw. If your car has the Smart Entry/Smart Start system then keep the fob at least 15 feet away from the car.
    Electrical wiring diagram: techinfo.toyota.com which is a subscription website
    Combination meter: it is located within the dashboard. Easy access: not really, you must remove the dashboard for access.
    LBH, Skibob and jerrymildred like this.
  2. greasemonkey007
    greasemonkey007 Active Member
    287
    106
    South Central Arkansas
    I've got an 07 that's doing almost the exact same thing. I'm waiting for tis to activate my account so I can pull a schematic. For some reason, I can't log in.
    The draw is .3A until I open a door. It goes up some, and then drops back to .3A when the timer shuts the light off after closing the door. I'll post what I find as soon as possible.
    LBH likes this.
  3. Patrick Wong
    18,210
    6,513
    Have you tried pulling the DOME fuse to see how that changes the quiescent current draw?
  4. greasemonkey007
    287
    106
    Yes, just like LBH's, it goes to 10 mA with the fuse pulled. That's the only fuse that caused a drop in amperage.
    All the door switches are opening and closing and causing the amperage to increase/decrease as expected. I'll go check the front door courtesy lights. I don't remember if they came on or not.
    LBH likes this.
  5. LBH
    LBH Junior Member
    30
    San Jose, CA
    Hi All,
    Thanks again everyone for your suggestions. I have tried all of your suggestions and results are same. I even took out each and all LED bulbs but no help.
    Hopefully Geesemonkey will find out what wrong and possible DIY solutions.
    Thanks again
  6. Patrick Wong
    18,210
    6,513
    The 15A DOME fuse feeds many circuits that require continual 12V power:
    ABS, TRAC and VSC
    Air Conditioning
    Automatic Glare–Resistant EC Mirror
    Automatic Light Control
    Back–Up Light
    Clock
    Combination Meter
    Cruise Control
    Door Lock Control
    Engine Control
    EPS
    Garage Door Opener
    Headlight
    Headlight Beam Level Control
    Interior Light
    Key Reminder
    Light Auto Turn Off System
    Luggage Compartment Door Opener
    Multi–Display and Audio System (Built–in Amplifier)
    Multi–Display and Audio System (Separate Amplifier)
    Power Window
    Push Button Start System and Hybrid Vehicle Immobiliser System
    Rear Window Defogger and Mirror Heater
    Seat Belt Warning
    Shift Control System
    Smart Key System and Wireless Door Lock Control (w/ Smart Key System)
    SRS
    Taillight and Illumination
    Theft Deterrent
    Tire Pressure Warning System
    TOYOTA Hybrid System
    Wireless Door Lock Control (w/o Smart Key System)
    The electrical wiring diagram shows various junction connectors which distribute the power from the DOME fuse. So you would first have to understand the nomenclature for the connectors, then find where they are, then take apart one at a time to see where the 0.3A current draw is coming from. That would help you to narrow down the circuit causing the problem.
    Overall this is going to be a very big PITA to figure out.
    *Goldfinger* and LBH like this.
  7. LBH
    LBH Junior Member
    30
    San Jose, CA
    Wow, it is too complicated and much more than just DOME alone.
    Thanks Patrick
  8. greasemonkey007
    287
    106
    Door light
    Ohhh yeahhhh!!!!!
  9. greasemonkey007
    287
    106
    Gonna be one of those back burner projects!
  10. LBH
    LBH Junior Member
    30
    San Jose, CA
    Hi Patrick,
    Do you have wiring diagram? Do you know those junction connectors locations? Thanks
  11. Patrick Wong
    18,210
    6,513
    techinfo.toyota.com to get the electrical wiring diagram.
    I do not know the locations, you will have to do some homework to figure that out.
    LBH likes this.
  12. LBH
    LBH Junior Member
    30
    San Jose, CA
    Thanks Patrick
  13. greasemonkey007
    287
    106
    Ok, got an update that hopefully will help here, LBH. I decided to drop the car off at the dealership since I have more projects than time, and I have a dealership/technician that I can count on. The tech found the drain in the combo meter late yesterday evening. This is for a car that I have a buyer coming for Monday, so I immediately called Matt at Texas Hybrid Batteries. He was able to send me one overnight today, so I'll have it in time to install before Monday. That was a big life saver!
    The tech said that he has encountered a handful of parasitic drains in the Prius, and most of them have been the combo meter. Matt shared some insight on some that he's seen blowing a small internal fuse. Makes sense if the combo meter can potentially have a draw on it. I'm sending my core in for him to examine and hopefully find what's causing the draw.
    In a nutshell, hook up you ammeter and then unplug the combo meter to see if the draw goes away. If so, call Matt at Texas Hybrid Batteries and he'll get you fixed up. If not, keep checking the rest of the stuff powered by the dome circuit. Good luck with it!
  14. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Thanks for actually replying, your answer will someday help others here. How does one unplug the combo meter? Can it be done without removing the upper panel?
  15. LBH
    LBH Junior Member
    30
    San Jose, CA
    Wow Thanks geesemonkey!
    Not easy for novice to do this. But i will try soon. Thanks hope your is fixed
  16. greasemonkey007
    287
    106
    You're very welcome Skibob.
    I wish I could say yes, but I can't. Gotta raise the dash panel. Be careful with the a/c vents. They can be broken when trying to pull them out.
  17. greasemonkey007
    287
    106
    You're welcome. I hope this fixes yours. Take your time and be careful and you should be ok. If you still feel it's over your head, acquire some help. Contact Matt if you need a new meter. MUCH, MUCH LESS than buying from a dealership, the miles will be matched to your existing meter, and it will have a lifetime warranty!
    LBH likes this.
  18. LBH
    LBH Junior Member
    30
    San Jose, CA
    My odometer reading is 299,999 !!
    What is the price range? Thanks
  19. greasemonkey007
    287
    106
    Call Matt at (817) 629-8394. You'll want to swap it for a newer one so it will start registering miles again. You just have to change 2 boards instead of one. Piece of cake.
    LBH likes this.
  20. LBH
    LBH Junior Member
    30
    San Jose, CA
    Haha yeah Thanks
